Forum Index : Microcontroller and PC projects : Trying to implement swipe!
| Bizzie Senior Member Joined: 06/07/2014 Location: AustraliaPosts: 192 |
Hi all, I would like to be able to change screens by swiping side ways on the display. Here is my setup - > Micromite Plus MMBasic Ver 4.7 Beta 36 Copyright 2011-2015 Geof> > option list OPTION BAUDRATE 115200 OPTION LCDPANEL ILI9341, LANDSCAPE, 21, 22, 23 OPTION TOUCH 18, 14 OPTION SDCARD 49 > list Option explicit
Dim Last = 0 GUI INTERRUPT PenDown,PenUp Sub PenDown Print "Down Touch(X),Touch(LASTX) => ";Touch(X),Touch(LASTX) Last = Touch(LASTX) End Sub Sub PenUp Print "Touch(LASTX), Last => ";Touch(LASTX),Last End Sub Do Loop > run Down Touch(X),Touch(LASTX) => 43 -1 Up Touch(X),Touch(LASTX), Last => -1 -1 Down Touch(X),Touch(LASTX) => 42 -1 Up Touch(X),Touch(LASTX), Last => -1 -1 Down Touch(X),Touch(LASTX) => 164 -1 Up Touch(X),Touch(LASTX), Last => -1 -1 > I do not seem to be able to pick up a true value for LASTX (or Last)! What do I not understand? Rob Rob White |
TOUCH(LASTX) does seem to be faulty (Beta 37) Any use of the touch screen will be difficult to master due to the inconsistent nature of our touching methods. This code seems to do a fairly good job of detecting 'swipes' It might conflict with any other code such as GUI buttons. ' TassyJim
' ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' OPTION EXPLICIT DIM Last = 0, Last1 = 0 GUI INTERRUPT PenDown ' ,PenUp DO LOOP END SUB PenDown Last = TOUCH(X) IF Last > -1 THEN GUI INTERRUPT 0 ' make sure we don't call again until finished processing PRINT "Down Touch(X) => ";Last SETTICK 100, swipe ' check touch position 100 ms later ENDIF END SUB SUB swipe LOCAL n SETTICK 0, swipe ' make sure we don't call again until finished processing FOR n = 1 TO 100 ' keep trying for a positive touch Last1 = TOUCH(X) IF Last1 > -1 THEN EXIT FOR NEXT n IF Last1 > -1 THEN IF (Last1 - Last) < -5 THEN ' moved at least 5 pixels PRINT "Swipe left ";Last1;" < ";Last ELSEIF (Last1 - Last) > 5 THEN PRINT "Swipe right ";Last1;" > ";Last ENDIF ENDIF GUI INTERRUPT PenDown ' turn the touch interrupt back on END SUB A button might not look as fancy but it will be more reliable. Jim VK7JH MMedit |
No offence at all intended, but if you need swipe, perhaps you should be writing code for Android devices instead.
The ARM CPU/GPU thing has the juice to be able to do this kind of thing, whereas the PIC32 does not, really. I use buttons to navigate between menus(just as Jim suggests) - see my thread about numberboxes erasing background text to see how I have one of my menu screens setup. Simple, but effective. Not to discourage you though - I will be watching this thread to see if you(or others) come up with something that works. Smoke makes things work. When the smoke gets out, it stops! |
As JFK would put it: “We choose to go with the swipe in this decade and do the other things, not because they are easy, but because they are hard." Jim VK7JH MMedit |
I deliberated whether to use the word swipe or not. I was only intending to pick up whether movement was from left to right or vice a versa and then display the next or previous page. No scrolling of image - yes not enough horse power! Rob White |
Here is an implementation of TassyJim's code above. Which pages through 8 pages using swipe left or right. ' Example of a GUI setup using horizontal swiping to change pages (screens)
' Written by Rob White with help from TasyJim ' ' This is an example of presenting various pages to the user. No variables ' are actually set. Option EXPLICIT GUI DEFAULT HIDDEN GUI INTERRUPT guiAction Const MaxWhls = 6 Const MaxPages = 8 Const CtrlColor = RGB(Yellow) Const BckColor = RGB(Black) Const CtrlTextColor = RGB(White) Dim CurrPage As integer = 1 Dim Last As integer = 0 Dim Last1 As integer = 0 CLS Font 1,2 ' NOTE controls for each screen must be ordered (as far as #ref is concerned) ' I believe it could be done better with arrays BUT that would mean getting ' Geoff to change the way GUI SHOW works. - To take an array of #ref numbers ' instead of an optional number of references. The UBOUND(array,dia) would ' also be handy. ' Controls that are on the screen all the time or for more than 1 screen Const gui0Go = 1 Const gui0Max = 1 GUI BUTTON gui0Go, "GO",265,185,50,50,CtrlColor,RGB(Green) ' Controls for page 1 - Reset counts & Save interval Const pg1Frm = 10 Const pg1ResetY = 11 Const pg1SaveInt = 12 Const pg1Cap1 = 13 Const pg1Cap2 = 14 Const pg1Max = 14 GUI FRAME pg1Frm, "Setup", 0,13,MM.HRes,MM.VRes,CtrlColor GUI CAPTION pg1Cap1, "Zero counts",10,60,LT,CtrlTextColor,BckColor GUI CHECKBOX pg1ResetY, "", 250,50,40,CtrlColor GUI CAPTION pg1Cap2, "Save freq.",10,130,LT,CtrlTextColor,BckColor GUI SPINBOX pg1SaveInt, 160,120,150,40,CtrlColor,BckColor,1,1,120 ' Controls for page 2 - Set date Const pg2Frm = 20 Const pg2Yr = 21 Const pg2Mth = 22 Const pg2Day = 23 Const pg2Cap1 = 24 Const pg2Cap2 = 25 Const pg2Cap3 = 26 Const pg2Max = 26 GUI FRAME pg2Frm, "Date", 0,13,MM.HRes,MM.VRes,CtrlColor GUI CAPTION pg2Cap1, "Day",10,30,LT,CtrlTextColor,BckColor GUI SPINBOX pg2Day, 150,40,140,40,CtrlColor,BckColor,1,1,31 GUI CAPTION pg2Cap2, "Month",10,90,LT,CtrlTextColor,BckColor GUI SPINBOX pg2Mth, 150,90,140,40,CtrlColor,BckColor,1,1,12 GUI CAPTION pg2Cap3, "Year",10,140,LT,CtrlTextColor,BckColor GUI SPINBOX pg2Yr, 150,140,140,40,CtrlColor,BckColor,1,15,30 ' Controls for page 3 - Set time Const pg3Frm = 30 Const pg3Hour = 31 Const pg3Min = 32 Const pg3Cap1 = 33 Const pg3Cap2 = 34 Const pg3Max = 34 GUI FRAME pg3Frm, "Time", 0,13,MM.HRes,MM.VRes,CtrlColor GUI CAPTION pg3Cap1, "Hour",10,30,LT,CtrlTextColor,BckColor GUI SPINBOX pg3Hour, 150,40,140,40,CtrlColor,BckColor,1,0,23 GUI CAPTION pg3Cap2, "Minute",10,130,LT,CtrlTextColor,BckColor GUI SPINBOX pg3Min, 150,130,140,40,CtrlColor,BckColor,1,0,59 ' Controls for page 4 - Units Const pg4Frm = 40 Const pg4Counts = 41 Const pg4Revs = 42 Const pg4Distance = 43 Const pg4Cap1 = 44 Const pg4Cap2 = 45 Const pg4Cap3 = 46 Const pg4Max = 46 GUI FRAME pg4Frm, "Units", 0,13,MM.HRes,MM.VRes,CtrlColor GUI CAPTION pg4Cap1, "Counts",10,40,LT,CtrlTextColor,BckColor GUI RADIO pg4Counts, "", 200,40,40,CtrlColor GUI CAPTION pg4Cap2, "Revs",10,90,LT,CtrlTextColor,BckColor GUI RADIO pg4Revs, "", 200,90,40,CtrlColor GUI CAPTION pg4Cap3, "Distance",10,140,LT,CtrlTextColor,BckColor GUI RADIO pg4Distance, "m", 200,140,40,CtrlColor ' Controls for page 5 - Colours Const pg5Red = 50 Const pg5Green = 51 Const pg5Blue = 52 Const pg5Wheel = 53 Const pg5Frm = 54 Const pg5Cap1 = 55 Const pg5Cap2 = 56 Const pg5Cap3 = 57 Const pg5Cap4 = 58 Const pg5Max = 58 GUI FRAME pg5Frm, "Graph colours", 0,13,MM.HRes,MM.VRes,CtrlColor GUI CAPTION pg5Cap1, "Red",10,40,LT,CtrlTextColor,BckColor GUI SPINBOX pg5Red, 100,40,140,40,CtrlColor,BckColor,5,0,255 GUI CAPTION pg5Cap2, "Blue",10,90,LT,CtrlTextColor,BckColor GUI SPINBOX pg5Blue, 100,90,140,40,CtrlColor,BckColor,5,0,255 GUI CAPTION pg5Cap3, "Green",10,140,LT,CtrlTextColor,BckColor GUI SPINBOX pg5Green, 100,140,140,40,CtrlColor,BckColor,5,0,255 GUI CAPTION pg5Cap4, "Wheel",10,190,LT,CtrlTextColor,BckColor GUI SPINBOX pg5Wheel, 100,190,140,40,CtrlColor,BckColor,1,1,MaxWhls ' Controls for page 6 - Totals graph Const pg6Frm = 60 Const pg6Max = 60 GUI FRAME pg6Frm, "Totals graph", 0,13,MM.HRes,MM.VRes,CtrlColor ' Controls for page 7 - 24 hour Graph Const pg7Frm = 70 Const pg7Max = 70 GUI FRAME pg7Frm, "24 Hour graph", 0,13,MM.HRes,MM.VRes,CtrlColor ' Controls for page 8 - Stop Const pg8Frm = 80 Const pg8stop = 81 ' Stop button - close down Const pg8Max = 81 GUI FRAME pg8Frm, "Exit program", 0,13,MM.HRes,MM.VRes,CtrlColor GUI BUTTON pg8stop,"Stop",(MM.HRes/2)-25,(MM.VRes/2)-25,50,50,CtrlColor,BckColor '''''''''''''''''''''''' MAIN LINE '''''''''''''''''''''''''''''''''''''''' Do Loop ' Swipe code by TassyJim ' ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' Sub guiAction Last = Touch(X) If Last > -1 Then GUI INTERRUPT 0 ' make sure we don't call again until finished processing 'Print "Down Touch(X) => ";Last SetTick 100, swipe ' check touch position 100 ms later ' 100 ms delay seems to work OK but should experiment with this. EndIf End Sub Sub swipe Local n SetTick 0, swipe ' make sure we don't call again until finished processing For n = 1 To 100 ' keep trying for a positive touch Last1 = Touch(X) If Last1 > -1 Then Exit For Next n If Last1 > -1 Then If (Last1 - Last) < -5 Then ' moved at least 5 pixels 'Print "Swipe left ";Last1;" < ";Last CurrPage = CurrPage -1 If CurrPage < 1 Then Currpage = MaxPages ElseIf (Last1 - Last) > 5 Then 'Print "Swipe right ";Last1;" > ";Last CurrPage = CurrPage + 1 If CurrPage > MaxPages Then Currpage = 1 EndIf EndIf ''''''''''' Code below added by me to redraw pages Print "CurrPage = ";CurrPage GUI HIDE ALL ' Show Ctrls which appear on all screens For n = 1 To gui0Max GUI SHOW n Next ' Now show Ctrls specific to a page. Select Case CurrPage Case 1 For n = 10 To pg1Max GUI SHOW n Next Case 2 For n = 20 To pg2Max GUI SHOW n Next Case 3 For n = 30 To pg3Max GUI SHOW n Next Case 4 For n = 40 To pg4Max GUI SHOW n Next Case 5 For n = 50 To pg5Max GUI SHOW n Next Case 6 For n = 60 To pg6Max GUI SHOW n Next Case 7 For n = 70 To pg7Max GUI SHOW n Next Case 8 For n = 80 To pg8Max GUI SHOW n Next End Select GUI INTERRUPT guiAction ' turn the touch interrupt back on End Sub Rob White |
| centrex Guru Joined: 13/11/2011 Location: AustraliaPosts: 320 |
Bizzie What display are you demonstrating this on, all works with some position mods on a 2.8 ILI9341 lcd. cliff Cliff |
Sorry I should of stated that my setup is :- Micromite Plus MMBasic Ver 4.7 Beta 37 Copyright 2011-2015 Geof> > option list OPTION LCDPANEL ILI9341, LANDSCAPE, 21, 22, 23 OPTION TOUCH 18, 14 OPTION SDCARD 49 > It is essential that you use Beta 3.7 - see http://www.thebackshed.com/forum/forum_posts.asp?TID=8237&PN=1 Rob White |
