Forum Index : Microcontroller and PC projects : Wine and MMEdit - using ser2net
Jim, Could you please expand on this a little please? Am running Mint17 on a 32 bit Dell laptop and trying to get MMEdit running under wine. Not having any luck getting COM anything going so would like to try ser2net as you suggest but am wallowing a bit on getting it going. Appreciate any assistance, Regards, Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
First thing is to test MMEdit Connect to the test server. This will check that you can connect using TCPIP. It is also using ser2net (on a Pi) so that will help the confidence levels. On your linux box. Install ser2net I did my Ubuntu system from the command line. sudo apt-get install ser2net That should give you a configuration file /etc/ser2net.conf which needs to be edited using your preferred editor. Use sudo so that you can save any changes From the command line sudo nano /etc/ser2net.conf scroll down to the lines with 2000:telnet:600:/dev/ttyS0:9600 etc... comment out the ones you don't want and edit one to read something like this: This is from the test server. save the file test it by running /usr/local/sbin/ser2net -c /etc/ser2net.conf -n connect MMEdit to localhost or 127.0.0.1 and you chosen port number Jim VK7JH MMedit |
Thanks Jim, Hope to get at it tomorrow arvo - greatly appreciate the advice, Regards, Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
