Local Time 18:37 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM+ V5.1 Explorer 64 with ILI9341, Touch
atmega8
Posted: 08:46am 26 Jan 2016
for the Micromite Explorer 64 with ILI9341, i cannot find in the manual, where to connect T_DO, T_DIN and T_CLK.
I think this Pins are fixed?!
PLS. help
THX Edited by atmega8 2016-01-27
atmega8
Posted: 09:31am 26 Jan 2016
Table page 17 in Micromite user manual shows only the connections for 28 and 44 pin Micromite, but not for 64 pin.
Posted: 11:37am 26 Jan 2016
There are two manuals.
Micromite manual and micromite plus manual.
The additional commands etc are in the Micromite Plus Manual.
atmega8
Posted: 11:44am 26 Jan 2016
Hi Jim,
i don't have Problem with commands, but with the correct wiring.
I read and searched in both manuals, but could not find how to connect the Micromite Explorer 64 with ILI9341.
The "Touch" related connections are not explained.
disco4now
Posted: 01:41pm 26 Jan 2016
I think you are correct, it is missing. Page 11 of the advanced manual does not carry all the information over from the old MicroMite Advanced Features manual.
The column for the ILI9341 is omitted as is the touch pins.
The description of the SPI panels talks about the ILI9163 when it means ILI9341 I think.
Here is page 4 from the old advanced manual with the information.
2016-01-26_233913_Micromite_Advanced_FeaturesP4.pdf
Gerry
F4 H7FotSF4xGT
atmega8
Posted: 01:45pm 26 Jan 2016
Aha,
i think this will be the correct wiring.
A little bit to late for me now
I will check it tomorrow...
Thank you very much.
  disco4now said   I think you are correct, it is missing. Page 11 of the advanced manual does not carry all the information over from the old MicroMite Advanced Features manual.
Gerry
Posted: 05:31pm 26 Jan 2016
Being SPI, I don't think it matters with respect to the MOSI/MISO/CLK pins.
The all important thing, is that you tell MMBASIC to use the correct SPI driver, and specify the other control pins correctly as you choose.
I have just had a look at an old design, and I wired the MM+ pins 4 and 5 to the SPI LCD, and I know the LCD worked. This was with an ILI9341 LCD.
Therefore, LCD_SDA to MM64_pin05, and LCD_SCK to MM64_pin04.
CS, Reset, and RS(A0) pins are configurable.
Posted: 10:26pm 26 Jan 2016
Thanks @atmega8 and @disco4now, the manual is indeed missing the I/O pin allocations for the ILI9341 display.
I have updated the manual in the V5.1 download and it can also be separately downloaded from:
http://geoffg.net/Downloads/Micromite/Micromite%20Plus%20Manual.pdf
GeoffEdited by Geoffg 2016-01-28
atmega8
Posted: 01:44am 27 Jan 2016
Hello Geoff,
in the meantime touch is running.
Thank you for updating the Manual.
DS
