Forum Index : Microcontroller and PC projects : Maximite issue
| larny Guru Joined: 31/10/2011 Location: AustraliaPosts: 349 |
I wrote the programme below in order to test the Maximite interface hardware that I designed & built. It is intended to light LEDs in sequence - LED1 for 3 seconds, then LED1 goes off & LED2 lights, etc. But, when I ran the programme, all LEDs remained dark. So I removed the interface & connected my DMM to one of the outputs. But the voltage remains at 0 when the appropriate output is supposed to be high. I can't see anything wrong with the programme. I ran the datalog.bas programme. It detects & displays the voltage at each of the pins 1 ~ 10. So I don't think there is anything wrong with the Maximite. Any assistance will be appreciated. 100 FOR i = 1 TO 20 : SETPIN i, DOUT : NEXT i 'DOUT or 8 for digital outputs
110 'Pins 1 ~ 20 digital outputs 120 PRINT "Start" : PRINT 130 For i=1 to 20 140 PIN(i)=1 150 PRINT i, 160 Pause 3000 170 PIN(i)=0 180 NEXT i 190 PRINT "Stop" 200 end |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10039 |
I don't think you can use the setpin command in a loop like that, can you? IE: You have to define your setpin commands separately, one after another. Smoke makes things work. When the smoke gets out, it stops! |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6604 |
What version of MMBasic are you using? Line numbers suggests an early version. DOUT was only introduced in later versions so try 100 FOR i = 1 TO 20 : SETPIN i, 8 : NEXT i 'DOUT or 8 for digital outputs
Jim VK7JH MMedit |
Thanks Jim, That worked. I have MM Version 2.7B. I have not used the MM for about 2 years. Thanks for the responses. Len |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1769 |
Hi Len, I strongly recommend the latest MMBasic version (4.5). It's very easy to update. Regards Michael ‚My name is Ozymandias, king of kings Look on my works, ye Mighty, and despair!‘ Nothing beside remains. Round the decay Of that colossal wreck, boundless and bare The lone and ... |
Thanks Michael, I have downloaded the 4.5 version. I'll install it shortly. Regards, Len |
