Forum Index : Microcontroller and PC projects : Help using touch screen
| Benzol Regular Member Joined: 07/01/2015 Location: AustraliaPosts: 64 |
Hi everyone I am having trouble working out how to use the LCD touch screen. I would like to turn on a relay for lighting when i touch a circle on the screen. There will be four circles for 4 different lighting circuits. Then turn off the relay(s) when the circle is touched again. I just can't figure out the code. Can anybody out there point me in the right direction please. Regards db |
Hi-de-hi.
As far as I know, circular buttons are not supported. Square or rectangular ones are, but circular ones are not. You could use a radio-button box to select the lamp you wanted, and as each radio-button was selected, it would automatically turn the others off. Only one could be on at any one time though, and that might not suit. You can make the radio-buttons any size you like though. Our Cfunction gurus might be able to write something to generate circular buttons. EDIT: Oh, BTW - Standard MM2 or MM+? Smoke makes things work. When the smoke gets out, it stops! |
Hi Grogster I'm using the standard micromite II V5.1 as per the backpack in Silicon Chip. Drawing the circles is easy enough, I figured it would 'look' for the X,Y of the circle to go high on touch to trigger a DOUT high.Maybe I'm just on the wrong track altogether. cheers. |
Hi-de-hi.
Yes, that makes a difference. I thought you meant MM+. I think you can just define an area on the screen where your circles are, and if you touch that area(which will also have the circle on it), then that will trigger the touch interrupt. I will see if I can hook up a screen to a MM2 later on and have a play - I have only really tinkered with the MM+ touch side of things thus far. Others will no doubt chime in with ideas, code snippets and examples I am sure. Smoke makes things work. When the smoke gets out, it stops! |
Grogs, Can you not 'frame' radio buttons in MMBasic? If so, then have four 'frames' and each radio button will work independently of all the others! Just an idea . . . WW |
Just an idea, and a very good one!
Yes, I expect that should work. However, that is MM+ GUI - I don't think radio-buttons and boxes are supported in the 28-pinner are they? Smoke makes things work. When the smoke gets out, it stops! |
Geoff's ParkingAssist program shows some good methods of doing buttons/input etc on the 28 pin LCD backpack. Just comment out the lines for the hardware and you can get a good idea how it runs. There are some nice little routines that would be a good starting point for anything you want to do. Geoff's ParkingAssist program Thread where Geoff upload it Regards Gerry F4 H7FotSF4xGT |
Simple demo: ' OPTION LCDPANEL controller, orientation, D/C pin, reset pin [,CS pin]
' OPTION LCDPANEL ILI9341, RL, 4,5,6 ' OPTION TOUCH T_CS pin, T_IRQ pin ' OPTION TOUCH 7,2 ' GUI CALIBRATE OPTION EXPLICIT OPTION CLOCKTRIM -4 cls SETPIN 26,DOUT ' display brightness PIN(26)=1 COLOUR RGB(GREEN), RGB(BLACK) FONT 1, 3 circle 50,50,40 'button1 circle 50,150,40 'button2 circle 150,50,40 'button3 circle 150,150,40 'button4 main: DO ' IF TOUCH(X) <> -1 THEN tapped LOOP END SUB tapped LOCAL tx,ty tx=TOUCH(X) ty=TOUCH(Y) if ty > 0 and tx > 0 then if tx > 10 and tx < 90 and ty > 10 and ty < 90 then print "Button1" endif if tx > 110 and tx < 190 and ty > 10 and ty < 90 then print "Button2" endif if tx > 10 and tx < 90 and ty > 110 and ty < 190 then print "Button3" endif if tx > 110 and tx < 190 and ty > 110 and ty < 190 then print "Button4" endif endif pause 200 END SUB Not sure if the display brightness pin is correct for your hardware. The conditional statements could easily be improved depending on your layout. Jim VK7JH MMedit |
Hi Jim. that's awesome, I never ceased to be amazed by the expertise on this site. I'm at work and can't try it until I get home. Will let you know. Regards db |
