Forum Index : Microcontroller and PC projects : Boot Loading problem
jeffj
Posted: 10:38pm 23 Feb 2016
MM Bootload problem MM colour and MM mono
Colour MM:-I cannot get the boot load to work Led does not flash when I press the boot load PB.
It does do something as I reprogrammed the MM with Pickit3 then tried to boot load .
The LED stayed on but the Silicon chip driver then appeared in Device manager,it wasn't there before.
I am not sure whether it matters or not as maybe downloading with the pickit3 may be doing the same thing.
The mono MM led flashes continuously (over 1/2 hour) when I press the bootload button
Both computers work ok
Jeff
Posted: 11:08am 24 Feb 2016
It looks like you have loaded the updates with the pickit3.
The updates don't have the bootloader.
You need to load a version with bootloader using your pickit3 and then load the updates using the bootloader.
I will try to find a link to the firmware with bootloader later.
Posted: 06:15pm 24 Feb 2016
Links to the construction packs which contain versions of MMBasic with the bootloader
Mono Maximite
Colour Maximite
Install the versions in the ZIP using the PICKit3 and then update them to the latest version using the USB method.
jeffj
Posted: 05:13pm 25 Feb 2016
Thanks for that Jim
I loaded both of those as described . Unfortunately both are still the same .
I wonder if the problem is related to when I connect the MMs to the computer I get a lot of trouble getting the com4 port to open. It usually ends up working after several loads of tera term and pulling out the usb plug and then it works.Sometimes I have to revert to updating the Silicon chip serial driver.
regards Jeff
Posted: 07:34pm 25 Feb 2016
What version of Windows are you using?
Do you connect directly to the PC or via a hub?
If possible, try both ways.
Also try different USB ports and different USB cables.
The driver is not used during a bootload operation so if you are having problems with bootload and normal comms with both maximites, it points to a PC port or cable problem.
jeffj
Posted: 08:34pm 26 Feb 2016
Thanks for your prompt help Jim
I changed the port and followed the instructions and all went well . Both MMs fire up straight away on Teraterm now.
One point, I had a problem with the Mono colour MM, I tried to run "maximite " bootloader in the construction package This wouldn't work and was asking for the program.
I had a bootloader.exe from way back in 2014.I used this and then was able to use the one with the maximite prefix
Great
thanks Jeff
Posted: 08:41pm 26 Feb 2016
Good to see it working.
USB can be fickle.
jeffj
Posted: 02:45pm 27 Feb 2016
There seems to be a bug in the updated programme.
I went to run a program that has been working ok on both colour and mono
I kept on getting error messages that a pin is not an input.
I reloaded an older version and it works fine.
My test code is as foll
470 For I=1 To 3: SetPin i,AIN:Next I ' pin configure I/O
480 For I=4 To 10 :SetPin I,DIN:Next I
490 For I=11 To 12: SetPin i,CIN:Next I
500 For I=13 To 20: SetPin i,DOUT:Next I
1860 Pincheck:
1870 For i=1 To 12
1880 Print "PIN"(i)"="Pin(i)
1890 Next: Pause 5000
regards Jeff
paceman
Posted: 03:01pm 27 Feb 2016
Take the first set of brackets out of line 1880 as below.
1880 Print "PIN" i "=" Pin(i)
Bizzie
Posted: 09:21pm 27 Feb 2016
Line 1880 should read something like:-
1880 Print "PIN(";i;") = ";Pin(i)
You need the semi colons to separate each expression.
Rob White
MicroBlocks
Posted: 09:30pm 27 Feb 2016
No semi colons needed, although i still use them as i find it more clear.
jeffj
Posted: 10:27pm 28 Feb 2016
Thanks for your comments .
What I can't understand is that the code I listed works ok on the old firmware
but not on the one I downloaded .
The problem seems to be that the setpin command does not work
Jeff.
