Forum Index : Microcontroller and PC projects : MMEdit update V3.6.6
This is mainly a catchup as I recover from the computer crash 2 months ago. I don't think there are any half done changes that I have forgotten about. Changes include Syntax files for Micromite Mk2 and Micromite Plus V5.1 Formatting and Variable report now recognise DEFINEFONT and CSUB You can now associate BAS files with MMEdit via Preferences/Advanced without the silly batch file method previously used. http://www.c-com.com.au/MMedit.htm If there are any keywords missing from the syntax files, or any other problems, pleas let me know. If you have problems starting MMEdit with a memory allocation error, reinstall and select the 'memory bug fix' option. (Used to be called 'XP fix' but it shows up with W7 as well.) I hope the Liberty Basic author fixes the problem properly soon but it is rather elusive. Jim VK7JH MMedit |
Hi Jim, Just discovered the Variable Report. Very handy for cleaning up unused variables. Just a minor observation, it does catch the standard colours used for example in RGB(green) as variables. Maybe the standard colours within RGB() could be excluded from the variable count in a future version. If you write nice code like Geoff and define your various colour classes then it would show green as only been used once, which in this case is OK. ' colours used in menus Const cTitle = RGB(green) ' title colour Thanks for the update. Regards Gerry F4 H7FotSF4xGT |
Is this suitable for V5.1? |
| circuit Guru Joined: 10/01/2016 Location: United KingdomPosts: 305 |
I cannot seem to install on any of my computers. I am running Windows 7 64bit and after I install MMEdit and try to run it I get a message window as follows; "Smalltalk/V A non-continuable protection violation has occurred. Check ERROR.LOG file." The ERROR.LOG file just reports the same message together with: The registers were: EIP = 0x01e0020d ESP = 0x0018fea8 EBP = 0x00000000 EAX = 0x08814444 EBX = 0xffffe001 ECX = 0x00000100 EDX = 0x0008e3c8 EDI = 0x00000001 ESI = 0x08814444 CS = 0x00000023 DS = 0x0000002b ES = 0x0000002b SS = 0x0000002b End Registers I have tried installing with the "memory bug option" selected but this makes no difference. What can I do? |
Circuit: It works fine here, using Windows 10 X64 |
@disco4now I had considered calling the colours keywords but forgot to do it this time. In the next update. @lew247 "Changes include Syntax files for Micromite Mk2 and Micromite Plus V5.1 " @circuit I haven't had this one for a while. A non-continuable protection violation is Windows' way of protecting us from rouge software and to make life difficult for program developers. Visa made the setting too tight but they relaxed things a bit for Windows7. My W7 had the default setting and all is well but some PC suppliers had things set tight. You can either change your settings or install MMedit into a folder that is NOT in 'Program Files' Please check you DEP settings and if is not set to essential Windows programs only, that is the problem. If you want to leave it set for all programs you can add MMedit as an exception or go the other folder method. The easiest way to find DEP is to search Windows Help for DEP. DEP stands for Data Execution Prevention. I did add a "manifest" which is supposed to stop this from happening but as you have seen, Windows wins the battle some times. Jim VK7JH MMedit |
Hi Jim, Is what I've tried to explain in this thread worthy of considering in a future update. I get that you Clock button passes the PC's time to Time$= & Date$=, would it be worth while having a button or option that sends the PC's time to RTC SETTIME. Alternatively, can I set a macro button up to do that? Cheers Phil. |
I can't do any testing for now, but yes, a macro should be OK. You would have to set the 'mite clock first. And that assumes that your PC clock is somewhere near correct. Considering that setting the RTC would be a rare thing to do, I am not keen on dedicating a button to the task. Jim VK7JH MMedit |
Jim In the next release please could you consider a "SET CLOCK" item on the advanced menu. This would just set the clock without requiring the code to be re-loaded Thanks Peter |
| drkl Senior Member Joined: 18/10/2015 Location: HungaryPosts: 102 |
Hello Jim, In the next release would be better to place the "Run and Load" icon at the beginning of the menu strip. Using vertically divided screen it disappears, must be back to the original size full screen. (Or all menustrip icon can be removable )
drkl |
I will put them both in the Advanced menu. Jim VK7JH MMedit |
Hi Jim, I am not sure if MMEDIT can do it already, but is it possible to #include files when you Load and Run, without them being added to the current source, but just added to the load. e.g. #Include=font4.bas #Include=font5.bas #Include=cfunction1.bas This would be useful if you are fiddling with a font or a Cfunction and doing it by trail and error. i.e many iterations. My understanding is the current #include will include the current file into the source and then does not do it thereafter. Regards Gerry F4 H7FotSF4xGT |
Just a minor thought. A slight change to the icons that appear on the taskbar. I'm currently using MMedit2 as a secondary editor to view multiple other files while what I'm working on is oopen in MMedit1. The task bar, which I never group can be confusing once MMedit, MMchat & MMedit2 are all open. Had a little play with the icon & changed it on my desktop, but that's not reflected on the taskbar. Cheers Phil Minor though I know, but might be worthwhile if not overly time consuming. |
Phil, I assume that you changed the Icon by Right click/Properties/Change Icon. I think this only changes the desktop Icon. If you want to change it everywhere, you need to use a Resource Editor and change it in the executable. I use "Resource Hacker" but there are many programs out there to do the job. Jim VK7JH MMedit |
