Forum Index : Microcontroller and PC projects : VT-100 Control Commands
Hi All, Can anyone point me in a good directions for some VT-100 Command sequences. Have looked at a few data sheets already..... What I want to do is replicate some of the data displayed on the LCD Back Pack on the terminal screen once I've connected the MicroMite remotely. At present I'm just using PRINT & the data continuously scrolls off the screen with each update. Thanks Phil |
A good starting point is Geoff's VT100 terminal http://geoffg.net/terminal.html There are a couple of links at the bottom of the page. Jim VK7JH MMedit |
| Justplayin Guru Joined: 31/01/2014 Location: United StatesPosts: 330 |
Do a Google search for "ANSI escape codes". Lots on info out there just be aware there are a couple of interpretations so you may need to experiment a little. --Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
