Forum Index : Microcontroller and PC projects : Test AUTORUN setting?
| Justplayin Guru Joined: 31/01/2014 Location: United StatesPosts: 330 |
Is there a way for a program check if AUTORUN has been set? OPTION LIST will show if has be set, but I don't see a way to capture the result of that query. --Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
I wish that all of the OPTION LIST items were testable. I asked for this, but it never happened. It would be nice to know - in the program - if the touch was configured, too. Even A = OPTION LIST where A is set to a value where the bit positions represented options. b0 equal to 1 would be AUTORUN is on, b1-b3 would be LCD display type, etc. Or a PEEK? Is there a PEEK for this? Micromites and Maximites! - Beginning Maximite |
Another thing I'd like to test for is if a supported RTC is present. Since it is a fatal error if is not, it would be nice to know before trying to access it. Just had one of my RTC modules fail, it would have be nice if the software could have simply failed over to the internal clock instead of crashing. --Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
| Zonker Guru Joined: 18/08/2012 Location: United StatesPosts: 772 |
Maybe a Cfunction to do this..? |
| Geoffg Guru Joined: 06/06/2011 Location: AustraliaPosts: 3369 |
As it happens, the option table is one of the few places in MMBasic where PEEK() is useful. To discover the AUTORUN setting you can use: peek(byte peek(word &H9D000090)) This will return 1 if AUTORUN is ON or 0 if it is OFF Other things that you can discover are: The current display type
peek(byte peek(word &H9D000090) + 20) where: No Display = 0 SSD1963_4 = 1 SSD1963_5 = 2 SSD1963_5A = 3 SSD1963_7 = 4 SSD1963_7A = 5 SSD1963_8 = 6 ILI9341 = 7 ILI9163 = 8 ST7735 = 9 The display orientation (1 = landscape, 2 = portrait, 3 = RevL, 4 = RevP) peek(byte peek(word &H9D000090) + 21) The I/O pin used for touch CS (zero means that touch is not configured) peek(byte peek(word &H9D000090) + 22) The I/O pin used for touch INT (handy if you want to set an interrupt on touch) peek(byte peek(word &H9D000090) + 23) Is the touch calibrated? Zero means no, non zero yes. peek(word peek(word &H9D000090) + 28) The I/O pin used for the LCD CS (zero means that the LCD is not configured) peek(byte peek(word &H9D000090) + 45) The I/O pin used for the LCD CD peek(byte peek(word &H9D000090) + 44) The I/O pin used for the LCD reset peek(byte peek(word &H9D000090) + 46) The I/O pin used for the SD card CS (zero means that the SD card is not configured) peek(byte peek(word &H9D000090) + 48) What MMBasic thinks is the width of the console in characters peek(byte peek(word &H9D000090) + 5) What MMBasic thinks is the height of the console in lines peek(byte peek(word &H9D000090) + 4) These work on all versions after 5.0 and for both the MX170 and MX470 variants. Also, they will not change in future versions of the Micromite firmware. You can do this with the following code in BASIC: ' test if the RTC is present
I2C Open 100, 200, PU I2C Write &H68, 0, 1, 0 If MM.I2C <> 0 Then I2C Write &H51, 0, 1, 2 If MM.I2C = 0 Then ' Yes, the RTC is present RTC GetTime If Date$ = "01-01-2000" Then Print "RTC has invalid date and time" Else ' RTC not found Print "No RTC found, time is not set" EndIf Geoff Graham - http://geoffg.net |
Thank you Geoff! You made me very happy, and I'm sure a number of other people will also be glad to see this handy/useful information!
