Forum Index : Microcontroller and PC projects : Help with Arrays
| Page 1 of 2 |
Little lost here, can someone explain what I'm doing wrong? Original Code:- '1-Wire Serial Number Search - One Device ONLY Attached. 'Code by Jman 02 April 2016 Option Explicit Dim OW1,OW2,OW3,OW4,OW5,OW6,OW7,OW8 Dim PinNbr PinNbr = 22 OneWire Reset Pinnbr OneWire Write PinNbr, 1, 1, &H33 ' Issue Read ROM command OneWire Read PinNbr, 2, 8, OW1,OW2,OW3,OW4,OW5,OW6,OW7,OW8 Print "Temp Sensor Should be 28 / ";Hex$(OW1);"H" Print "Ser# ",Hex$(OW2,2);Hex$(OW3,2);Hex$(OW4,2);Hex$(OW5,2);Hex$(OW6,2);Hex$(OW7,2);"H" Print "CRC ";Hex$(OW8,2);"H" My Attempt to implement an Array:- Option Explicit Dim OW(9) Dim PinNbr PinNbr = 22 OneWire Reset Pinnbr OneWire Write PinNbr, 1, 1, &H33 ' Issue Read ROM command OneWire Read PinNbr, 2, 8, OW(1),OW(2),OW(3),OW(4),OW(5),OW(6),OW(7),OW(8) Print "Temp Sensor Should be 28 / ";Hex$(OW(1);"H" Print "Ser# ",Hex$(OW(2),2);Hex$(OW(3),2);Hex$(OW(4),2);Hex$(OW(5),2);Hex$(OW(6),2);Hex$(OW(7),2);"H" Print "CRC ";Hex$(OW(8),2);"H" Returns:- [10] OneWire Read PinNbr, 2, 8, OW(1),OW(2),OW(3),OW(4),OW(5),OW(6),OW(7),OW(8) Error: Invalid variable > Thanks Phil. |
| Justplayin Guru Joined: 31/01/2014 Location: United StatesPosts: 330 |
From the Micromite manual concerning 1-Wire Communications: Sorry
--Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
Thanks Curtis, Skipped over that block when I read "For users of MMBasic on earlier devices". |
Still like to get all my Serial Numbers into an array, even though I will need to convert them to variables inside the sub for use. Ie:- Dim Float Ts(7,6) 'Serial Numbers for 6 sensors. Then use something like OW1=Ts(1,1),OW2=Ts(1,2),...... Not sure how to load the array; getting variable type errors just trying to get hex values into the array. Option Autorun On
Option Explicit Option Default None Option Base 1 'Serial#'s & CRC of DS18B20 Temp Sensors. 'Const Ts1a=&H24,Ts1b=&H72,Ts1c=&H4A,Ts1d=&H07,Ts1e=&H00,Ts1f=&H00,Ts1g=&H1B 'Temp Sensor 1 Const Ts2a=&HC9,Ts2b=&H5D,Ts2c=&H4B,Ts2d=&H07,Ts2e=&H00,Ts2f=&H00,Ts2g=&H60 'Temp Sensor 2 Const Ts3a=&H46,Ts3b=&HB9,Ts3c=&H4A,Ts3d=&H07,Ts3e=&H00,Ts3f=&H00,Ts3g=&HE4 'Temp Sensor 3 Dim Float Ts (7,3) Ts(1,1)=&H24,Ts(2,1)=&H72,Ts(3,1)=&H4A,Ts(4,1)=&H07,Ts(5,1)=&H00,Ts(6,1)=&H00,Ts(7,1)=&H1B 'Temp Sensor 1 The Code using Constants works, just think it's a bloated approach. 10 Sensors for example, will need 10 lines of 7 variables. Would be better with a 7x10 Array & then convert the aray values over to something like:- Ts1, Ts2,...... Ts7 inside the sub Any thoughts? Thanks Phil |
Also wonder is I could use something like DATA & READ, to get the serial numbers from a list like this? [Code]DATA &H24,&H72,&H4A,&H07,&H00,&H00,&H1B, &HC9,&H5D,&H4B,&H07,&H00,&H00,&H60, &H46,&HB9,&H4A,&H07,&H00,&H00,&HE4 [/code] Don't know if there is an operator that will allow the data to be split over multiple lines, but it would be good if it could as it makes the above list very easy to read. Cheer. |
You have a couple of errors here... Drop the Float, its the default data type. No space between Ts and (7,3). And instead of commas between each statement you need colons. Dim Ts(7,3) Ts(1,1)=&H24: Ts(2,1)=&H72: Ts(3,1)=&H4A: Ts(4,1)=&H07: Ts(5,1)=&H00: Ts(6,1)=&H00: Ts(7,1)=&H1B 'Temp Sensor 1 And if your want to use DATA statements you will need to start each DATA line with the DATA statement. --Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
So with Data using multiple lines, how do I choose which line to READ? [Code] DATA &H24,&H72,&H4A,&H07,&H00,&H00,&H1B 'Sensor1 DATA &HC9,&H5D,&H4B,&H07,&H00,&H00,&H60 'Sensor2 DATA &H46,&HB9,&H4A,&H07,&H00,&H00,&HE4 'Sensor3 [/code] Presume that's what the first bit would look like. Can't find a lot of detail on READ. Cheers. |
If you label each line, you can RESTORE to the line you want. Alternatively, if you want to step through all devices in turn, you don't have to worry about RESTORE for each device. Jim VK7JH MMedit |
Phil, Although you can use RESTORE to reload your DATA, it is generally not done unless you are effectively restarting your program by going back to the beginning. Once you load your data into an array you are done with the DATA statements and you simply reuse the data in the array over and over, reading from any location in the array at any time. Sorry... In the example below I switched your array order around to something more logical to me. I had already written the example before I saw the switch and I'm too lazy (and in a bit of a rush) to fix it right now. Dim Ts(3,7) ' Ts(sensor #, id data) DATA &H24,&H72,&H4A,&H07,&H00,&H00,&H1B 'Sensor1 DATA &HC9,&H5D,&H4B,&H07,&H00,&H00,&H60 'Sensor2 DATA &H46,&HB9,&H4A,&H07,&H00,&H00,&HE4 'Sensor3 For i = 1 to 3 'sensor # count For j = 1 to 7 'id byte count Read Ts(i,j) 'read the data in the array Next j Next i '** We no longer need the DATA statements, it's now all stored in the array '** Show the array contents For i = 1 to 3 For j = 1 to 7 Print "Ts("; i;",";j ;") = "; Ts(i,j); " "; Next j Next i '** output a couple of values from the array Print Ts(2,4) ' sensor 2, byte 4 Print Ts(3,5) ' sensor 3, byte 5 Print Ts(1,2) ' sensor 1, byte 2 End Arrived at my destination so I can post a update with the array like your original: Dim Ts(7,3) ' Ts(id data, sensor #)
DATA &H24,&H72,&H4A,&H07,&H00,&H00,&H1B 'Sensor1 DATA &HC9,&H5D,&H4B,&H07,&H00,&H00,&H60 'Sensor2 DATA &H46,&HB9,&H4A,&H07,&H00,&H00,&HE4 'Sensor3 For i = 1 to 3 'sensor # count For j = 1 to 7 'id byte count Read Ts(j,i) 'read the data in the array Next j Next i '** We no longer need the DATA statements, it's now all stored in the array '** Show the array contents For i = 1 to 3 For j = 1 to 7 Print "Ts("; j;","; i;") = "; Ts(j,i); " "; Next j Next i '** output a couple of values from the array Print Ts(4,2) ' byte 4, sensor 2 Print Ts(5,3) ' byte 5, sensor 3 Print Ts(2,1) ' byte 2, sensor 1 End --Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
Thanks Curtis, That looks like a good approach. This project will ultimately require 4 Sensors, plus integration with 5 existing thermistors in a heat pump unit. The other project on the drawing board will involve at least 8, so having a nice easy to read & edit the serial Number list will be very beneficial. Can the Data & Array contain mixed variables? DATA TempOut,&H24,&H72,&H4A,&H07,&H00,&H00,&H1B 'Sensor1 Outside DATA TempRof,&HC9,&H5D,&H4B,&H07,&H00,&H00,&H60 'Sensor2 Roof Cavity DATA TempLrm,&H46,&HB9,&H4A,&H07,&H00,&H00,&HE4 'Sensor3 Lounge Room Phil |
DATA TempRof,&HC9,&H5D,&H4B,&H07,&H00,&H00,&H60 'Sensor2 Roof Cavity DATA TempLrm,&H46,&HB9,&H4A,&H07,&H00,&H00,&HE4 'Sensor3 Lounge Room Variables within DATA statements in not allowed. DATA statements are great for loading initial values that are the same every time you run a program. Also great for loading large amounts of data such as font tables, CRC tables or names and addresses. After you read the data you can alter the copy stored the variables, but it will not change the original values in the DATA statements Dim Location$(7), Ts(7,3) ' Ts(id data, sensor #)
DATA "Outside" ,&H24,&H72,&H4A,&H07,&H00,&H00,&H1B 'Sensor1 DATA "Roof Cavity", &HC9,&H5D,&H4B,&H07,&H00,&H00,&H60 'Sensor2 DATA "Lounge Area", &H46,&HB9,&H4A,&H07,&H00,&H00,&HE4 'Sensor3 For i = 1 to 3 'sensor # count Read Location$(i) For j = 1 to 7 'id byte count Read Ts(j,i) 'read the data in the array Next j Next i '** Show the array contents For i = 1 to 3 Print "Sensor #"; i; " - ID#: "; For j = 1 to 7 Print Hex$(Ts(j,i),2); Next j print " - "; Location$(i) Next i End In this example I have added a string array for the location description and added the data to the DATA statements. Simply make sure you read the DATA in the same order as it is found in the DATA statements. This does exactly the same as above but with DATA in laid out differently: Dim Location$(7), Ts(7,3) ' Ts(id data, sensor #)
DATA &H24,&H72,&H4A,&H07,&H00,&H00,&H1B 'Sensor1 DATA &HC9,&H5D,&H4B,&H07,&H00,&H00,&H60 'Sensor2 DATA &H46,&HB9,&H4A,&H07,&H00,&H00,&HE4 'Sensor3 DATA "Outside" , "Roof Cavity", "Lounge Area" '** Read Sensor ID bytes For i = 1 to 3 'sensor # count For j = 1 to 7 'id byte count Read Ts(j,i) 'read the data in the array Next j Next i '** Read Location Description For k = 1 to 3 Read Location$(k) Next k '** Show the array contents For i = 1 to 3 Print "Sensor #"; i; " - ID#: "; For j = 1 to 7 Print Hex$(Ts(j,i),2); Next j print " - "; Location$(i) Next i --Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
Thanks Curtis, That helped a lot. Can anyone see where I'm going wrong from there. These first portions of code work Ok.... [Code] 'Serial#'s & CRC of DS18B20 Temp Sensors. Const Ts1a=&H24,Ts1b=&H72,Ts1c=&H4A,Ts1d=&H07,Ts1e=&H00,Ts1f=&H00,Ts1g=&H1B 'Temp Sensor 1 Const Ts2a=&HC9,Ts2b=&H5D,Ts2c=&H4B,Ts2d=&H07,Ts2e=&H00,Ts2f=&H00,Ts2g=&H60 'Temp Sensor 2 Const Ts3a=&H46,Ts3b=&HB9,Ts3c=&H4A,Ts3d=&H07,Ts3e=&H00,Ts3f=&H00,Ts3g=&HE4 'Temp Sensor 3 Sub GetTemps OneWire Reset PinTmp OneWire Write PinTmp, 1, 10, &H55,&H28,Ts1a,Ts1b,Ts1c,Ts1d,Ts1e,Ts1f,Ts1g,&H44 'Sensor1 StatusCheck 'check sensor is ready OneWire Write PinTmp, 1, 10, &H55,&H28,Ts1a,Ts1b,Ts1c,Ts1d,Ts1e,Ts1f,Ts1g,&HBE 'Sensor1 OneWire Read PinTmp, 2, 2, LTemp, HTemp TempCalc 'Work out the temp in C TmpCur=Value OneWire Write PinTmp, 1, 10, &H55,&H28,Ts2a,Ts2b,Ts2c,Ts2d,Ts2e,Ts2f,Ts2g,&H44 'Sensor2 StatusCheck 'check sensor is ready OneWire Write PinTmp, 1, 10, &H55,&H28,Ts2a,Ts2b,Ts2c,Ts2d,Ts2e,Ts2f,Ts2g,&HBE 'Sensor2 OneWire Read PinTmp, 2, 2, LTemp, HTemp TempCalc 'Work out the temp in C TmpInp=Value OneWire Write PinTmp, 1, 10, &H55,&H28,Ts3a,Ts3b,Ts3c,Ts3d,Ts3e,Ts3f,Ts3g,&H44 'Sensor3 StatusCheck 'check sensor is ready OneWire Write PinTmp, 1, 10, &H55,&H28,Ts3a,Ts3b,Ts3c,Ts3d,Ts3e,Ts3f,Ts3g,&HBE 'Sensor3 OneWire Read PinTmp, 2, 2, LTemp, HTemp TempCalc 'Work out the temp in C TmpOut=Value End Sub [/code] But when I try to use the array data, just one the 1st sensor at this stage, it fails to read Sensor1. [Code] Dim Float Ts1,Ts2,Ts3,Ts4,Ts5,Ts6,Ts7,I,J Dim Float Ts (7,3) DATA &H24,&H72,&H4A,&H07,&H00,&H00,&H1B 'Sensor1 DATA &HC9,&H5D,&H4B,&H07,&H00,&H00,&H60 'Sensor2 DATA &H46,&HB9,&H4A,&H07,&H00,&H00,&HE4 'Sensor3 For I = 1 to 3 'Sensor # count = 3 'Load the data into the Array For J = 1 to 7 'id byte count Read Ts(J,I) 'read the data in the array Next J Next I Sub GetTemps Ts1=Ts(1,1):Ts2=Ts(2,1):Ts3=Ts(3,1):Ts4=Ts(4,1):Ts5=Ts(5,1):Ts6=Ts(6,1):Ts7=Ts(7,1) 'Temp Sensor 1 copied from Array to Variables. OneWire Reset PinTmp OneWire Write PinTmp, 1, 10, &H55,&H28,Ts1,Ts2,Ts3,Ts4,Ts5,Ts6,Ts7,&H44 StatusCheck 'check sensor is ready OneWire Write PinTmp, 1, 10, &H55,&H28,Ts1,Ts2,Ts3,Ts4,Ts5,Ts6,Ts7,&HBE OneWire Read PinTmp, 2, 2, LTemp, HTemp TempCalc 'Work out the temp in C TmpCur=Value . . . . End Sub [/code] Is it something causing the values to be passed to the OneWire command as decimal & not HEX? Trying to reduce the code down to a sub that I can call with the Array data. Thanks Phil. |
Not so much Decimal as Float maybe? I don't know if it's because you've used Float arrays but you don't seem to need them in most of the code so maybe try using integers. John |
Same result when I change Ts1-Ts7 & Ts Array to INTEGER. Totally Miffed now! Just check the array data, it's full of E4 Hex, 228 Decimal. [Code]> Print Ts(1,1);Ts(2,1);Ts(3,1);Ts(4,1);Ts(5,1);Ts(6,1);Ts(7,1) 228 228 228 228 228 228 228 >[/code] Original code loads the data to the array fine. [Code] Dim Ts(7,3) ' Ts(id data, sensor #) DATA &H24,&H72,&H4A,&H07,&H00,&H00,&H1B 'Sensor1 DATA &HC9,&H5D,&H4B,&H07,&H00,&H00,&H60 'Sensor2 DATA &H46,&HB9,&H4A,&H07,&H00,&H00,&HE4 'Sensor3 For i = 1 to 3 'sensor # count For j = 1 to 7 'id byte count Read Ts(j,i) 'read the data in the array Next j Next i '** We no longer need the DATA statements, it's now all stored in the array '** Show the array contents For i = 1 to 3 For j = 1 to 7 Print "Ts("; j;","; i;") = "; Ts(j,i); " "; Next j Next i '** output a couple of values from the array Print Ts(4,2) ' byte 4, sensor 2 Print Ts(5,3) ' byte 5, sensor 3 Print Ts(2,1) ' byte 2, sensor 1 Ts1=Ts(1,1):Ts2=Ts(2,1):Ts3=Ts(3,1):Ts4=Ts(4,1):Ts5=Ts(5,1):Ts6=Ts(6,1):Ts7=Ts(7,1) 'Temp Sensor 1 Print Ts1;Ts2;Ts3;Ts4;Ts5;Ts6;Ts7 End[/code] Can't for the life of me see any difference apart from variable declarations, which if add to the above don't break it. [Code]Dim Integer Ts(7,3) ' Ts(id data, sensor #) Dim Integer Ts1,Ts2,Ts3,Ts4,Ts5,Ts6,Ts7[/code] Edit:- Seems like the FOR NEXT loops in my code are simply being ignored, as if commented out. Added a line to monitor it on the console & get no output whatsoever. [Code] For I = 1 to 3 'sensor # count For J = 1 to 7 'id byte count Read Ts(J,I) 'read the data in the array Print J; I; Ts(J,I) Next J Next I pause 10000 [/code] |
Try For I = 1 to 3 'sensor # count
For J = 1 to 7 'id byte count Read Ts(J,I) 'read the data in the array Print J, I, Ts(J,I) Next J Next I |
And then try For I = 1 to 3 'sensor # count For J = 1 to 7 'id byte count Read t ' read into a temp variable Ts(J,I) = t 'read the data in the array Print J, I, Ts(J,I) Next J Next I Some distant memory from the past about reading directly into arrays. Or it could be related to something entirely different... Jim VK7JH MMedit |
Not sure why, but FOR NEXT is now running. Maybe the Micro didn't update. Added more debug code:- [Code] DATA &H24,&H72,&H4A,&H07,&H00,&H00,&H1B 'Sensor1 DATA &HC9,&H5D,&H4B,&H07,&H00,&H00,&H60 'Sensor2 DATA &H46,&HB9,&H4A,&H07,&H00,&H00,&HE4 'Sensor3 Print "FOR - NEXT loop about to start." For I = 1 to 3 'sensor # count For J = 1 to 7 'id byte count Read Ts(J,I) 'read the data in the array Print J;I;Ts(J,I) Next J Next I Print "FOR - NEXT loop completed" Print "Array Data:-" Print Ts(1,1);Ts(2,1);Ts(3,1);Ts(4,1);Ts(5,1);Ts(6,1);Ts(7,1) Print Ts(1,2);Ts(2,2);Ts(3,2);Ts(4,2);Ts(5,2);Ts(6,2);Ts(7,2) Print Ts(1,3);Ts(2,3);Ts(3,3);Ts(4,3);Ts(5,3);Ts(6,3);Ts(7,3) [/code] This is the output I see in the Console:- [Code] RUN [2J[?25lFOR - NEXT loop about to start. 1 1 36 2 1 114 3 1 74 4 1 7 5 1 0 6 1 0 7 1 27 1 2 201 2 2 93 3 2 75 4 2 7 5 2 0 6 2 0 7 2 96 1 3 70 2 3 185 3 3 74 4 3 7 5 3 0 6 3 0 7 3 228 FOR - NEXT loop completed Array Data:- 228 228 228 228 228 228 228 228 228 228 228 228 228 228 228 228 228 228 228 228 228 [/code] Edit: notice the 228; E4 Hex, it is also the last value in the DATA statement. |
What is strange is this piece of code works perfectly in a separate program file. [Code] Dim Integer Ts(7,3) ' Ts(id data, sensor #) Dim Integer Ts1,Ts2,Ts3,Ts4,Ts5,Ts6,Ts7 DATA &H24,&H72,&H4A,&H07,&H00,&H00,&H1B 'Sensor1 DATA &HC9,&H5D,&H4B,&H07,&H00,&H00,&H60 'Sensor2 DATA &H46,&HB9,&H4A,&H07,&H00,&H00,&HE4 'Sensor3 For i = 1 to 3 'sensor # count For j = 1 to 7 'id byte count Read Ts(j,i) 'read the data in the array Print j;i;Ts(j,i) Next j Next i Pause 5000 '** We no longer need the DATA statements, it's now all stored in the array Do Print "Array Data:-" Print Ts(1,1);Ts(2,1);Ts(3,1);Ts(4,1);Ts(5,1);Ts(6,1);Ts(7,1) Print Ts(1,2);Ts(2,2);Ts(3,2);Ts(4,2);Ts(5,2);Ts(6,2);Ts(7,2) Print Ts(1,3);Ts(2,3);Ts(3,3);Ts(4,3);Ts(5,3);Ts(6,3);Ts(7,3) Ts1=Ts(1,1):Ts2=Ts(2,1):Ts3=Ts(3,1):Ts4=Ts(4,1):Ts5=Ts(5,1):Ts6=Ts(6,1):Ts7=Ts(7,1) 'Temp Sensor 1 Print "Sensor1 Values from variables" Print Ts1;Ts2;Ts3;Ts4;Ts5;Ts6;Ts7 Loop[/code] Outputs this to the console:- [Code] RUN 1 1 36 2 1 114 3 1 74 4 1 7 5 1 0 6 1 0 7 1 27 1 2 201 2 2 93 3 2 75 4 2 7 5 2 0 6 2 0 7 2 96 1 3 70 2 3 185 3 3 74 4 3 7 5 3 0 6 3 0 7 3 228 Array Data:- 36 114 74 7 0 0 27 201 93 75 7 0 0 96 70 185 74 7 0 0 228 Sensor1 Values from variables 36 114 74 7 0 0 27 Array Data:- 36 114 74 7 0 0 27 201 93 75 7 0 0 96 70 185 74 7 0 0 228 Sensor1 Values from variables 36 114 74 7 0 0 27 Array Data:- 36 114 74 7 0 0 27 201 93 75 7 0 0 96 70 185 74 7 0 0 228 Sensor1 Values from variables 36 114 74 7 0 0 27 Array Data:- 36 114 74 7 0 0 27 201 93 75 7 0 0 96 70 185 74 7 0 0 228 Sensor1 Values from variables 36 114 74 7 0 0 27 [/code] Really can's see I'm doing anything different in the two blocks. |
This probably indicates that you needed a RESTORE statement somewhere. Hard to know without the full program. Jim VK7JH MMedit |
Thanks Jim, As I'm only reading the data statement once I presumed I didn't need the restore command. Data_to_Array.zip is the code that works as expected. Thermistor_Read.zip is the miss mush of various test code where things don't go as planned. Ah well, might call it quits for a while & go spend a few hours cutting firewood.... Thanks Phil. |
| Page 1 of 2 |
