Local Time 18:06 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Console menu
Phil23
Posted: 12:06pm 01 May 2016
Playing with the idea of being able to control my MM from the console as well as the touch screen, so it I want to change something remotely, from a terminal app on my phone, I can.
Looked over a few related threads, but looking for suggestions as to if I'm on the right track, or taking the wrong approach.
The few bits of code I've added:-
IF INKEY$="m" THEN DoMenu
LOOP
Sub DoMenu
'Output Stuff to console for debugging purposes
Print Esc+"[2J";
Print Esc+"[f";
Print "1. Change Target Temperature"
Print "2. Change Differential"
Print "3. Change Solar Level"
Print "9. Stop & Shutdown"
Print "0. Exit"
pause 5000
Print Esc+"[2J";
End sub
Normally the console displays some data similar to this, but relevant to the appliation:-
DS18B20 Number 1 Temp 21.25
DS18B20 Number 2 Temp 21.87
DS18B20 Number 3 Temp 21.81
Thermistor Voltage = 1.77
Thermistor Resistance = 9497.47
Thermistor Temp Beta Coeff 21.23
Thermistor Temp Steinhart 21.28
Device Time is 07:51:20
I've got as far as changing it to display this, if I press the "m" key in the console:-
Options Menu.
9. Stop & Shutdown
0. Exit
The code here is just temp sensor test stuff & very untidy, but the final code will go in the Spa & Room heating controllers.
2016-05-01_220535_Thermistor_Read.zip
Phil
Posted: 05:24pm 01 May 2016
The are many ways to do menus and it depends a lot on the flow of your main program.
The one big issue with the method you are using is the PAUSE statement.
This halts the full program for 5 seconds and prevents any keyboard entry.
This adaption lets the program continue while the menu is displayed.
You can choose to process INKEY$ input only while the menu is displayed (as in the option 9) or at any time.
The menu will close with the zero key or after 5 seconds.
DIM Esc AS STRING
Esc = CHR$(27)
DO
k$ = INKEY$
SELECT CASE k$
CASE "m","M"
DoMenu
CASE "1"
PRINT "Changing target Temperature"
CASE "2"
PRINT "Changing Differential"
CASE "3"
PRINT "Changing Solar Level"
CASE "9"
PRINT "Stop & Shutdown"
IF menu = 1 THEN END ' only end program if menu is showing
CASE "0"
PRINT "Exiting"
EndMenu
END SELECT
LOOP
SUB DoMenu
SETTICK 5000, EndMenu,4 ' set menu timeout
PRINT Esc+"[2J";
PRINT Esc+"[f";
PRINT "1. Change Target Temperature"
PRINT "2. Change Differential"
PRINT "3. Change Solar Level"
PRINT "9. Stop & Shutdown"
PRINT "0. Exit"
menu = 1 ' a flag so you know when the menu is active
END SUB
SUB EndMenu
SETTICK 0,0,4 ' disable the menu timeout
PRINT Esc+"[2J";
menu = 0 ' reset menu active flag
END SUB
This method may not be the best for you main program flow but it may be of some use.
Phil23
Posted: 05:29pm 01 May 2016
Sorry Jim,
I should of explained in my post that the pause was just in place to test that first bit of coding I did.
Just to see if my inkey$ & the menu it triggered were going to work reliably.
From there I need to capture the option numbers for the menu items & then enter probably a 4 character number, ie 27.5 etc.
Would I not also need some of the case statement you listed inside the DoMenu Sub?
Phil.Edited by Phil23 2016-05-03
