Forum Index : Microcontroller and PC projects : MMEDIT INCLUDE
| drkl Senior Member Joined: 18/10/2015 Location: HungaryPosts: 102 |
Hello, How can use the MMEDIT Include directive? I try, but it is not operates. My mistake, it is sure. It would be better a sample code drkl |
One for TassyJim when he wakes up - and something I need a little more info about too
@TassyJim - can you please provide me a link to the latest version of MMEdit as I have been 'offline' for a few weeks and am keen to catch up! - Thanks Jim EDIT: Can you also link me to the latest Font Editor too if possible (so much to catch up on )
I missed the INCLUDE section out of the help file when I changed to CHM format. Here is the text from the original help file: I will be changing the INCLUDE section to allow for adding the INCLUDE's during 'load and run', leaving the source file as is. @WW The latest MMEdit is a few weeks old but available from my website. Search here for latest Font Tweak. I will put it and the other utilities on my website eventually. Jim VK7JH MMedit |
Thanks Jim, this will be good. F4 H7FotSF4xGT |
Jim, many thanks, Thank you the quick and exact answer. I tested, it operates well. TassyJim wrote: Beside this, the original solution is remains? drkl |
Yes, it will continue to work the same way as well as the extra option. Jim VK7JH MMedit |
| MikeO Senior Member Joined: 11/09/2011 Location: AustraliaPosts: 275 |
Hi Jim, this include directive does not seem to work with the macro upload function to Teraterm , is that correct. I use that method all the time and the include working with this would be very useful, is it possible? Mike Codenquilts |
Are you using the 'normal' file "lastfile.bas" or the 'crunched' one "lastfile.baz"? I would rather not touch the normal one but I could add the INCLUDE to the crunched one. It shouldn't cause any grief for other users. It will add more time delays every time users do a 'save'. Jim VK7JH MMedit |
Hi Jim, I just use the crunched one, hardly ever use the other so that's not a drama. Its just that I have started using the Library memory area in the Umite and being able to add in include files that I know are change free to the one main file would be really useful. Perhaps an option switch? Cheers Mike Codenquilts |
