Forum Index : Microcontroller and PC projects : MMedit Variable Usage Report.
Hi Jim, FYI I Just noticed this:- Variables which are only refered to in one line:
None 3 White 78 Reset 113 Lines of code referenced:- [Code] 3. Option Default None 78. Text MM.HRes/40, MM.VRes*5/8, "Therm Ohms", LM, 2, 1, RGB(White) 113. OneWire Reset PinTmp [/code] Also notice that the colours in the other TEXT ..... RGB(Colour) lines are listed as variables. Cheers Phil. |
What that indicates is the KEYWORDS are missing from the syntax file. I had already fixed the colours and RESET. NONE has now been fixed as well. The fixes will be in the next full update along with any more that are found. Jim VK7JH MMedit |
| Justplayin Guru Joined: 31/01/2014 Location: United StatesPosts: 330 |
Here is a couple more for you Jim. Variables which are only refered to in one line:
Restart 695 PU 846 Lines of code referenced: 695 CPU Restart
846 I2C Open 100, 200, PU Also, referred is misspelled in your Variable Report. --Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
RESTART I had, PU now added Spelling will be fixed. Thanks Jim VK7JH MMedit |
