Local Time 15:34 07 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Why 64bit integers?
Tinine
Posted: 02:58pm 13 May 2016
Gotta be a bit of a memory hog, no?
Really starting to like this stuff, mind.
Posted: 04:53pm 13 May 2016
Hello. Welcome to the forums.
I am no expert, but as I understand it, the 64-bit integer support is just for those who need or want to work with such gigantic numbers directly without having to work with floating point or exponents. As far as I know, it is just a personal preference option that Geoff has put in the language so that if you want to work with large numbers easily, that is probably the way to do it. As to memory use, I have no idea, but I expect it can't be that horrific, or Geoff would not have agreed to do it. Someone with more knowledge then I will chime in with the correct answer for you, I'm just offering my thoughts.
Posted: 06:44pm 13 May 2016
Many times we were looking for 32 bit unsigned integers.
Having 64 bit signed lets us work with 32 bit unsigned easily without the need for too many types to worry about.
isochronic
Posted: 11:43pm 13 May 2016
Have a look at -
http://www.thebackshed.com/forum/forum_posts.asp?TID=7336&KW=64+bit+integer
Tinine
Posted: 01:05pm 14 May 2016
  Grogster said   Hello. Welcome to the forums.
Thanks for the welcome, it's a great place to visit
So, just to have say, a flag of 1 or 0, I have no option but to use 8 bytes?
I guess I can get a whole bunch of flags out of one variable using AND/NOT/OR.
You guys have any other speed/size optimization tricks?
Cheers!
Tinine
Posted: 02:31pm 14 May 2016
Well, you have a lot of RAM. Enough for over six thousand integer flags and if you use a float as your flag you get over twelve thousand without even using AND/NOT/OR.
That must be enough
  Quote  You guys have any other speed/size optimization tricks?
The Micromite is about ease of programming, not tricky programming. Try using it in a few practical applications and you will find that you have plenty of resources.
GeoffEdited by Geoffg 2016-05-16
Tinine
Posted: 11:05pm 14 May 2016
  Geoffg said  Try using it in a few practical applications and you will find that you have plenty of resources.
Yeah, I'm definitely hooked. Don't have hardware yet but for the first time since I don't when, I actually RTFM
Great product Geoff. Many thanks!
