Local Time 04:03 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sending control commands to console
mikeb
Posted: 02:37pm 31 May 2016
Hi all,
Sorry for the total 'newbie' questions but I have only ever worked with 'integer'
programming (PICbasicPro) and a completely different function set.
How do I send control commands to the console ? (eg, CLS, HOME, LF, CR).
I know to use the 'colon' character, at the end of the line to suppress the
'auto generation' of CR and LF, but this does not give me the results I require.
I would like to send an output string and then have a CR so the next output string
overwrites the previous one rather than have an ever expanding list in the console.
Also, how best to 'truncate' a floating point number to a particular decimal place
or pad a number to same. I see having varying lengths of data problematic when it comes to file storage and retrieval. I've been scouring the forum and example code, I like to try and sort things out myself first, but I'm becoming entirely confused.
Thanks in advance. Edited by mikeb 2016-06-02
Posted: 03:03pm 31 May 2016
Are you using a terminal program on a PC or a display attached to the mite?
If its a VT1oo terminal program, you need to learn a few VT100 commands.
For formatting numbers, look at the STR command
mikeb
Posted: 06:08pm 31 May 2016
Thanks for the reply Jim.
At the moment I'm just looking at the console output in MMedit straight from the MMII or MM+. I know I should be using decimal 10(LF) and decimal 13(CR) for what I want to do but don't know how to format it to stop the decimal number from being printed.
It will be easy on the display as I have (x), (y) co-ordinates to play with
My code is simply this -
DO
PRINT "Temperature: " DS18B20(30) " C";
**********need CR command, with no LF here*************
pause 1000
LOOP
I would like to overwrite Temperature [value] C each second, hence the need for a CR. Purely for testing purposes.
I'll have another look at the string command as you suggest.
Reghards, Mike B.
Posted: 06:18pm 31 May 2016
How about:
DO
PRINT CHR$(13);
pause 1000
LOOP
"PRINT CHR$(13);" will print one single CR character/byte on the end of your temperature. Each time you run that loop, it SHOULD overwrite the last figure for you. Untested, but it should work.
Posted: 06:36pm 31 May 2016
MMEdit is a (very poor) VT100 terminal so if you want to locate text on the display, you will need to learn the VT100 commands.
Google will give you a few lists to play with.
You can also do colours etc, not just placement.
Do not leave MMEdit running for a very long time in VT100 mode. If you weant to do that, it is much better to use TeraTerm.
PRINT CHR$(27)+"[37;41;1m"
PRINT "Hello World"
DO:LOOP UNTIL INKEY$<>""
PRINT CHR$(27)+"[0m"
PRINT "Hello World"
Most terminal programs let you set what happens when a single CR is received so I wouldn't rely on Grogster's method.
JimEdited by TassyJim 2016-06-02
mikeb
Posted: 06:47pm 31 May 2016
A big thanks Jim, and Grogs, for pointing me in the right direction. Sometimes I can't see the wood for the trees. I just love 'learning curves' at 55.
Also got my resolution sorted. I think I'll use a 'timer tick' once my program evolves.
DO
TEMPR START 22,3
PRINT "Temperature: " str$(TEMPR(22),0,1) " C";
PRINT CHR$(13);
LOOP
The "PRINT CHR$" works perfectly in Tera Term but not in the MMedit 'chat window'.
Never mind. They both have their uses. Learn't something else today. Thanks Guy's.
Posted: 11:24pm 31 May 2016
GDay Jim,
  TassyJim said   MMEdit is a (very poor) VT100 terminal
Have you thought, well is it possible, to configure MMEdit to use TeraTerm as the terminal?
I say that because as much as I love MMEdit, I hate its terminal window and invariably have auto run turned off, shut down the mini window and then load TT to do my ... whatever I do.. If you could automate that process it would be fantastic, even to the extent of shutting TT before it sends more code to the device.
Does that make sense?
Kind Regards,
Posted: 11:53pm 31 May 2016
  bigmik said   GDay Jim,
Kind Regards,
I have tried a few times.
There are a couple of issues that the TeraTerm authors don't want to address (due to security worries).
Also, people keep asking for more 'features' that don't help the integration.
Have you tried the macro methods - see the MMEdit help - Using the terminal/Teraterm
I can try a method that copies your program (crunched etc if that's what you have set) to the clipboard with a small header to start the transfer process.
All you have to do then is right click in TeraTerm and your program is pasted into TeraTerm and uploaded using autosave.
This works well provided you have a suitable line delay set in TeraTerm.
My preferred option is to get off my bum and put out a working version of MMEdit compiled with a decent compiler instead of the interpreted Basic I use now. It will still be my lousy programming but a lot faster.
Phil23
Posted: 12:31am 01 Jun 2016
I use something like this for debugging purposes,
not the best choice but does the job.
[Code]
Dim string Esc=Chr$(27)
Print Esc+"[f";
Print "Lounge Temp = ", Str$(TempLng1,2,1)
Print "Bedroom Temp = ", Str$(TempBed1,2,1)
Print "Ambient Temp = ", Str$(TempAmb1,2,1)
Print "Roof Temp = ", Str$(TempRoof,2,1)
Print
Print "Maximum & Minimum Temps"
Print "Lounge Max = ", Str$(TempLng1Max,2,1)
Print "Lounge Min = ", Str$(TempLng1Min,2,1)
Print "Roof Max = ", Str$(TempRoofMax,2,1)
Print "Roof Min = ", Str$(TempRoofMin,2,1)
Print
Print "System Status:-"
Print "Current Up Time is:- ", Time$
[/code]
I create the Esc variable just for readability,
and then ESC[2f takes the cursor back to the home position before each screen write.
The Str$(ABCD,2,1) basically says turn the number into a string & display it with 2 digits left of the decimal, and 1 to the right.
Edited by Phil23 2016-06-02
paceman
Posted: 02:33am 01 Jun 2016
  mikeb said   Also, how best to 'truncate' a floa - ting point number to a particular decimal place or pad a number to same.
@Mikeb
The TEMPR() function returns a floating point number with a 0.25o resolution and accuracy of 0.5o. The others have mentioned to use the STR$ function to format it for output. If you wish to report the result to just a whole number, then before you use the STR$ function you should use the CINT function to round the result, otherwise you can be reporting a number 0.75o out, i.e. it will be truncated, not rounded.
GregEdited by paceman 2016-06-02
redrok
Posted: 02:22pm 02 Jun 2016
Hi All;
This is my personal list of VT100 Escape codes.
http://www.redrok.com/ESCape-Codes.txt
ESCape codes and special characters for
ANSII terminal and MicroMiteII
PRINT CHR$(7); REM BELL
PRINT CHR$(11); REM LF
PRINT CHR$(13); REM CR
PRINT CHR$(27); REM ESC
PRINT CHR$(44); REM , Comma
PRINT CHR$(46); REM . Full stop
PRINT CHR$(124); REM | Pipe
PRINT CHR$(126); REM ~ Tilde
PRINT CHR$(27);"D"; REM Role Up 1 line
PRINT CHR$(27);"E"; REM Move to Next line
PRINT CHR$(27);"M"; REM Role Down 1 line
PRINT CHR$(27);"[0K"; REM clear-EOL
PRINT CHR$(27);"[0m"; REM Cursor Normal (Reset)
PRINT CHR$(27);"[4m"; REM Underline Mode
PRINT CHR$(27);"[5m"; REM Blinking Mode (Doesn't Work)
PRINT CHR$(27);"[7m"; REM Reverse Video
PRINT CHR$(27);"[8m"; REM Invisable Mode
PRINT CHR$(27);"[1;1f"; REM Cursor to Home
PRINT CHR$(27);"[1K"; REM clear-BOL
PRINT CHR$(27);"[2J"; REM Erase Display, Pause 500mS
PRINT CHR$(27);"[2K"; REM Erase Entire Line
PRINT CHR$(27);"[3A"; REM ^ Curser Up 3
PRINT CHR$(27);"[4B"; REM v Curser Down 4
PRINT CHR$(27);"[5C"; REM -> Curser Forward 5
PRINT CHR$(27);"[6D"; REM <- Curser Backward 6
PRINT CHR$(27);"[f"; REM Curser to Upper Left Corner
PRINT CHR$(27);"[;f"; REM Curser to Upper Left Corner
PRINT CHR$(27);"[Line;Column f"; REM Curser to Screen Position
PRINT CHR$(27);"[H"; REM Curser to Upper Left Corner
PRINT CHR$(27);"[;H"; REM Curser to Upper Left Corner
PRINT CHR$(27);"[Line;Column H"; REM Curser to Screen Position
PRINT CHR$(27);"7"; REM Save Cursor Position & Attributes
PRINT CHR$(27);"8"; REM Restore Cursor Position & Attributes
PRINT CHR$(27);"[s"; REM Save Cursor Position
PRINT CHR$(27);"[u"; REM Restore Cursor Position
PRINT CHR$(27);"[1m"; REM Bold
PRINT CHR$(27);"[30m"; REM Black
PRINT CHR$(27);"[1;30m"; REM Bold Black
PRINT CHR$(27);"[31m"; REM Red
PRINT CHR$(27);"[1;31m"; REM Bold Red
PRINT CHR$(27);"[32m"; REM Green
PRINT CHR$(27);"[1;32m"; REM Bold Green
PRINT CHR$(27);"[33m"; REM Yellow
PRINT CHR$(27);"[1;33m"; REM Bold Yellow
PRINT CHR$(27);"[34m"; REM Blue
PRINT CHR$(27);"[1;34m"; REM Bold Blue
PRINT CHR$(27);"[35m"; REM Magenta
PRINT CHR$(27);"[1;35m"; REM Bold Magenta
PRINT CHR$(27);"[36m"; REM Cyan
PRINT CHR$(27);"[1;36m"; REM Bold Cyan
PRINT CHR$(27);"[37m"; REM White
PRINT CHR$(27);"[1;37m"; REM Bold White
I like to use this form for control with uMITE and TeraTerm
UL1$=CHR$(27)+"[4m" :REM Underline Mode
NM1$=CHR$(27)+"[0m" :REM Cursor Normal (Reset)
BK0$=CHR$(27)+"[0;30m" :REM Bold Black actually White
RD0$=CHR$(27)+"[0;31m" :REM Bold Red
GR0$=CHR$(27)+"[0;32m" :REM Bold Green
YE0$=CHR$(27)+"[0;33m" :REM Bold Yellow
BU0$=CHR$(27)+"[0;34m" :REM Bold Blue
MG0$=CHR$(27)+"[0;35m" :REM Bold Magenta
CY0$=CHR$(27)+"[0;36m" :REM Bold Cyan
WH0$=CHR$(27)+"[0;37m" :REM Bold White actually Gray
BK1$=CHR$(27)+"[1;30m" :REM Bold Black Lighter Black
RD1$=CHR$(27)+"[1;31m" :REM Bold Red
GR1$=CHR$(27)+"[1;32m" :REM Bold Green
YE1$=CHR$(27)+"[1;33m" :REM Bold Yellow
BU1$=CHR$(27)+"[1;34m" :REM Bold Blue
MG1$=CHR$(27)+"[1;35m" :REM Bold Magenta
CY1$=CHR$(27)+"[1;36m" :REM Bold Cyan
WH1$=CHR$(27)+"[1;37m" :REM Bold White actually heavy Black
ER1$=Chr$(27)+"[2J" :REM ERACE DISPLAY
HM1$=Chr$(27)+"[f" :REM Curser to Upper Left Corner
UP1$=CHR$(27)+"[1A" :REM ^ 1 Line
PRINT ER1$;HM1$;
PRINT BK1$;"BK1$ ";BK0$;"BK0$ ";RD1$;"RD1$ ";RD0$;"RD0$ ";
PRINT GR1$;"GR1$ ";GR0$;"GR0$ ";YE1$;"YE1$ ";YE0$;"YE0$ ";
PRINT BU1$;"BU1$ ";BU0$;"BU0$ ";MG1$;"MG1$ ";MG0$;"MG0$ ";
PRINT CY1$;"CY1$ ";CY0$;"CY0$ ";WH1$;"WH1$ ";WH0$;"WH0$ ";
PRINT BU1$
Send the specified byte values to the display driver. The specific
control codes, their parameters, and their meaning depend on the
display driver. See the display driver documentation for
descriptions. See:
http://ascii-table.com/ascii.php
http://ascii-table.com/ansi-escape-sequences.php
http://ascii-table.com/ansi-escape-sequences-vt-100.php
Everything including the QUOTES must be included in the statement.
The QUOTES are not sent.
redrok
Posted: 08:44pm 02 Jun 2016
@redrok
Thanks for this very useful summary list
Posted: 09:02pm 02 Jun 2016
  redrok said   Hi All;
redrok
LF should be 10
