Forum Index : Microcontroller and PC projects : MMedit update for Micromite 5.2
| hzoli Newbie Joined: 01/07/2016 Location: HungaryPosts: 3 |
Hi! I have updeted my micromite hw to version 5.2+. It is better, thank you for your work!
But I haven't been able to find any upgrade for the MMedit Syntax file ~"Micromite_Plus_V5.2.dta" Could anybody help me? thx Zoli |
Sorry, I have been busy but hope to have the update in a week or so. Just use the 5.1 syntax file. The sntax files are only used for highlighting the keywords and for knowing what's a variable in the variable report. MMBasic and the micromite don't care. Jim VK7JH MMedit |
Hi Thank you for your answare! In this case ([The sntax files are only used for highlighting the keywords and for knowing what's a variable in the variable report.) I can use the 5.1 syntax file. But I am waitng for the new. :-) thx Zoli |
See TassyJim's post from 9th July TID=8823&PN=3">http://www.thebackshed.com/forum/forum_posts.asp?TID=8823&PN=3 You will need to copy the two DTA files into your data folder and the TKN file into your program folder. |
Corrected above link. Updated syntax file |
