Local Time 19:04 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Parallel port
kermess
Posted: 09:46pm 26 Jul 2016
I need to manipulate ten bits in parallel and I think this is the command for this.
PORT(start, nbr [,start, nbr]…) = value
I want to move a five-phase stepper motor with 5 chips of this type L9110H
These are the ten bits in order according to my scheme.
15, 16, 23, 2, 4, 5, 6, 7, 9, 10
This is the minimum program
Setpin 15, dout
Setpin 16, dout
Setpin 23, dout
Setpin 2 dout
Setpin 4 dout
Setpin 5, dout
Setpin 6 dout
Setpin 7 dout
Setpin 9 dout
Setpin 10 dout
do
Port (15,2,23,1,2,1,4,4,9,2) = & B0101010101
Pause 200
Port (15,2,23,1,2,1,4,4,9,2) = & B1010101010
Pause 200
'Flicker bits
explanation
15, 2 = 15,16
23,1 Only 23
2,1 Only 2
4,4 = 4, 5, 6, 7
9.2 = 9, 10
RESULT
Error: Unknown command:
Question … ? ... .. Has anyone used this command.
What is the correct way to use ..?
I am using Windows 10.
PIC32MX170F
MIcromite 5.1 V.
Saludos
David.
from Barcelona.
Posted: 09:51pm 26 Jul 2016
Hi David,
In your code, do you have a space character between the '&' and the 'B' as shown above?
If so, then this is likely to be your issue
WW
kermess
Posted: 07:57pm 27 Jul 2016
Hello WW.
It seems to be separate but in the code within the program all together.
Another way in which I tried the code is this:
port (15,1,16,1,23,1,2,1,4,1,5,1,6,1,7,1,9,1,10,1)=&B0101010101
port (15,2,23,1,2,1,4,4,9,2)=&B0101010101 .... This looks good.
And so it is exactly.The same error.
Thank you.
David
Posted: 09:36pm 27 Jul 2016
You have a space between port and (
port (
kermess
Posted: 10:29pm 27 Jul 2016
YES.
I think that this construction would be normal,
port (15,2,23,1,2,1,4,4,9,2)=&B1001010101
This is the error.
Without space.
port(15,2,23,1,2,1,4,4,9,2)=&B1001010101
run ok ..... but also a different error.
When you run the line in question.
!!! Reset ¡¡¡
This is the result.
Micromite MKII MMBasic Ver 5.1
Copyright 2011-2016 Geoff Graham
...... David
Greg Fordyce
Posted: 12:44am 28 Jul 2016
Try using this command as a test.
port(15,2)=&B10
Maybe there is a limit to the number of arguments the port command can handle. If that works gradually increase the arguments until you find the limit.
kermess
Posted: 10:42am 28 Jul 2016
Hi, Greg
No, it does not work
I have tried different ways to test the port and these are the results.
'Port(15,2)=&B10 ' Pin 15 not output
'port (15,2)=&B10 ' Error: Unknown command
'Port(16,1)=&B1 ' Pin 16 not output
'port (16,1)=&B1 ' Error: Unknown command
'port (23,1)=&B0 ' Error: Unknown command
'port (4,4)=&B0110 ' Error: Unknown command
This is what I need.
' port (15,2,23,1,2,1,4,4,9,2)=&B1010101010
This works fine, but I think it is much slower
'pin(15)=1:pin(16)=0:pin(23)=0:pin(2)=0:pin(4)=0
'pin(5)=1:pin(6)=0:pin(7)=1:pin(9)=0:pin(10)=1
Muchas gracias.
David
Greg Fordyce
Posted: 11:05am 28 Jul 2016
  Quote  Port(15,2)=&B10 ' Pin 15 not output
Did you set pins 15 and 16 as digital outputs first before trying the command?
kermess
Posted: 08:48pm 28 Jul 2016
Yes ....
SetPin 15,dout
SetPin 16,dout
SetPin 23,dout
SetPin 2,dout
SetPin 4,dout
SetPin 5,dout
SetPin 6,dout
SetPin 7,dout
SetPin 9,dout
SetPin 10,dout
I tried it with definitions previously and also without defining them.
For try everything.
This is the minimum expression of the program.
SetPin 15,dout
SetPin 16,dout
Print "Mini_port.bas"
port (15,2)=&B10
Print "END"
Thank you
David.
Posted: 10:24pm 28 Jul 2016
Can you update to V5.2
I don't have any 5.1 available but it runs OK on 5.2 (provide you get rid of that space between port and (
> AUTOSAVE
SetPin 15,dout
SetPin 16,dout
port(15,2)=&B10
Print "END"
Saved 88 bytes
> RUN
Mini_port.bas
END
kermess
Posted: 05:57am 27 Sep 2016
Hello, I upgraded to version 5.2 and the "PORT" command works correctly.
Thank you very much to all.
David.
redrok
Posted: 07:50am 27 Sep 2016
Hi kermess;
Just a technical detail.
The port command is much faster at sending the bits out
than using individual pin commands.
However.
They aren't switched simultaneously as with a normal
parallel port.
There is a bit of delay, a few uS or so, between the bits.
This is not a problem with mechanical things like
stepper motors and such.
To get true parallel port switching an external clocked
register would be required. Of course even a parallel port
isn't truly synchronous as there are propagation delays.
redrok
