Local Time 18:07 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite Serial Baud Rate
hitsware
Posted: 02:01pm 28 Jul 2016
I have just found that in BBCBasic
( even though the manual gives the standard
baud rates ( as does the MMBasic manual ))
I can write :
port% = OPENUP("COM1: 31250,N,8,1")
and instruct a Midi device.
I had always thought deviating from the
given rates would error some way.
Will the Maximite do the same ?
If so I could put the Midi device in
the 'Sea of Holes' and have a slick unit :)
Posted: 02:11pm 28 Jul 2016
The Duinomite can on com3 and com4
I think the Maximite is restricted to the standard rates.
The micromites can use the SerialTx Cfunction which will do any baud rate up to a max limit.
hitsware
Posted: 04:56am 29 Jul 2016
Thank You Jim,
Yea, I remember the DuinoMite doing it now.
It might be better, since I could change 'shields'
(and synths) at whim.
I had one once but trashed it when the SD card holder
broke ..............
