Forum Index : Microcontroller and PC projects : MMBASIC Error glossary....
Hello folks.
Prompted by some comments by some of our newer users of MMBASIC, I have contacted Geoff, and although he is still on holiday, he very kindly took the time to send me a list of all the possible error messages that MMBASIC can throw up at you, so I am working on making a document which will contain a description of each of those errors, and what they mean in "Plain English" for the newer members of our MicroMite family. The document will include examples of the error in each case where possible. The document will not be anything that special, but perhaps can form the basis of an error glossary that could even be expanded on by those more in the know on certain errors then I, and I think in any form, it will be useful not just for the newbies, but also some of the rest of us too!
This is very much a work in progress, and I will post the file on this thread when I have finished at least a basic(no pun intended - well, maybe just a little!) version of it. There are 194 different error messages, so this WILL take a little time, even for the first version, but just so those who have asked about this aspect of using MMBASIC know that there is action happening on this behind the scenes....... Smoke makes things work. When the smoke gets out, it stops! |
| atmega8 Guru Joined: 19/11/2013 Location: GermanyPosts: 738 |
Thank you Grogster!!! |
For those who aren't aware of it, the "Beginning Maximite Programming and Interfacing" manual by CircuitGizmos is certainly worth a look. Even though it's written for the Maximite & Version 4.3, it's still 550 pages of good stuff that's definitely got relevance. Cheers. |
Yes indeed - nice one, Phil!
I forgot about that manual that CG wrote, and it is a BEAST. As to this project, it has been suggested to me in PM's that I break this down into a few sections, then others can work on it. This is a good idea, and I think what I will do at this point, is get approval from the forums as to the layout of each error description. That way, anyone who wants to submit a definition for any error keeps the same layout so that the entire document has the same "Flow" to it, but several different people could be contributing to the end result - if anyone else wants to help with this, please add your support here to this thread. Next thing I will do, is publish the full list of error messages here on this thread, so that those who want to take on any of them for descriptions, can do whichever ones they want. I suggest a very basic text-only format, with nothing more then bold, itallic and underline used - we don't want to have to do a heap of re-formatting. Done this way, I can just copy-and-paste to a master document, and each time I post the update, I can list the commands that have NOT yet been documented - something like that - open to suggestions from the members here as to if they have a better way to do it that I have not thought of. My idea for a format would be something like: NUMBER OUT OF BOUNDS. A reference to a number that is invalid was made in your code on this line. The interpreter has stopped with this error message, as you have tried to reference an invalid number within a command on this line of your code. EXAMPLE: PRINT INPUT$(0,#1) - This will throw up this error, because you are trying to print ZERO bytes from the serial port handle #1, when the number MUST be >=1. Zero is not valid, so the code will stop with this error. Something along those lines, anyway - KISS approach. We don't want complicated formatting, as that just adds to the time needed to compile the document. KISS makes it easy for everyone to read too. Suggestions? Comments? Smoke makes things work. When the smoke gets out, it stops! |
If you are really bored and looking for something to do, These are the functions that return "number out of bounds" and what it means for each one: There are still 'commands', I2C External, MM_Misc, Onewire, PWM, SerialFileIO and MMBasic source files to go through. Writing a program to scan the source and list the lines with error messages in them is easy but converting the output into plain English (or Nu Zelund) is what takes time. Jim VK7JH MMedit |
A program sounds a good idea. You probably already thought of it but saving its output, however verbose etc it is, would be useful. Then when anyone makes a newer MMBasic the program can be re-run and the differences hint at any new error messages. John |
Well, here is the list of error messages, where "$" means string, and "%" means number: $ already declared $ already declared with a different type $ not declared % is invalid (valid is % to %) % out of bounds A sub/fun has the same name: $ Already open Argument list Array dimensions Baud rate too high Cancelled by remote Cannot change a constant Cannot continue Cannot find $ Cannot find a matching FOR Cannot find label Cannot find matching END SELECT Cannot re dimension array Click option not set Conflicting variable type Console baud rate too high Console pins are in use Control #% does not exist CPU speed too low Display not configured Divide by zero DO without LOOP Duplicate name Error closing Expected a number Expected a string Expected an array Expected closing bracket Expression is too complex Expression syntax File number #% is not open File number is already open File number is not open Flash write Floating point variable required Font is too large FOR with misplaced = or TO FOR without matching NEXT GUI reference number #% is in use I2C is busy IF without THEN In use by the console Incompatible type Incompatible type in argument Incompatible types in expression Inconsistent type suffix Incorrect argument count Incorrect expression syntax Incorrect number of arguments Index out of bounds Insufficient array size Insufficient data Insufficient space in array Internal fault (sorry) Invalid 7 bit device address Invalid address Invalid argument Invalid argument count Invalid character Invalid character: @ Invalid colour: $ Invalid COM port Invalid COM specification Invalid command Invalid configuration Invalid constant Invalid CPU speed Invalid date Invalid dimensions Invalid display type Invalid eight digit hex word Invalid file access mode Invalid file number Invalid flag combination Invalid flag specification Invalid font #% Invalid font format Invalid font number #% Invalid function definition Invalid function name Invalid in a program Invalid inside THEN ... ELSE Invalid justification Invalid line number Invalid mask Invalid mode Invalid name Invalid number of parameters Invalid operator Invalid option Invalid option $ Invalid options Invalid orientation Invalid prefix Invalid size Invalid speed Invalid string size Invalid syntax Invalid time Invalid type Invalid type specification Invalid variable Invalid variable name Invalid variable type Invalid x coordinate Invalid y coordinate Label too long Landscape only LCD Panel not configured Library space occupied Line is too long LOCAL invalid here LOOP has a WHILE test LOOP has an UNTIL test LOOP without a matching DO Missing END declaration Multiline IF without matching ENDIF Multiple spaces between keywords Must be before DIM or LOCAL Negative argument No closing bracket No DATA to read No DO loop is in effect No FOR loop is in effect Not enabled Not enough data Not enough initialising values Not enough memory Not in interrupt Not in slave read state Not in slave send state Not open Nothing to return to Number out of bounds Number too large Old and new filenames are the same Overflow Pin % is in use Pin % is invalid Pin % is reserved on startup Pin % not input Pin % not output Pin % used by ICSP Pin is in use Pin is not an input Pin is not an output Remote did not respond RTC not responding Same colours Serial port used for the console Slave enabled Slave not enabled SPI is open SPI2 is in use SSD1963 display only SSD1963 display required String is too long String too long Syntax error Too many concurrent PULSE commands Too many errors Too many files open Too many files to list Too many initialising values Too many interrupts Too many lines Too many nested DO or WHILE loops Too many nested FOR loops Too many nested GOSUB Too many SUB and FUN Too many subroutines and functions Touch hardware Touch hardware failure Touch not calibrated Touch not configured Touch option not set Type specification is invalid Type specification is invalid: @ Type specified twice Unexpected text Unexpected text: $ Unknown command Unrecognised option Variable name too long Variable not found Variable type not specified Variables already defined WHILE without WEND Zero length argument ...rather a-lot of them..... Smoke makes things work. When the smoke gets out, it stops! |
What does Inconsistent type suffix mean? |
For example: DIM AS INTEGER t$ The $ symbol means that it is a string but it was defined as an integer. Geoff Geoff Graham - http://geoffg.net |
What exactly does "Incorrect argument count" mean? |
It means the parameters after a command are wrong. Maybe missing one or there are to many. |
| mobluse Newbie Joined: 10/02/2013 Location: SwedenPosts: 24 |
Which commands are "Invalid in a program"? I have noticed that Files is. E.g. 10 files run [1] Files Error: Invalid in a program I thought that Files was useful in a program to select a file by typing it in and it worked in version 2.7A. Maker Pi Pico Rev1.2, DuinoMite-Mini, Raspberry Pi 0-4, iCE40HX8K, Arduino Uno, VM111, STK500, ZX81 |
| Andrew_G Guru Joined: 18/10/2016 Location: AustraliaPosts: 883 |
Grogs, A great initiative! As a recent editor of a 200 page book with a dozen contributors, may I humbly suggest a simple "style guide" to include font types, sizes, how to treat <tab>, bullets etc. It might help to ensure it is compatible with listing here or in MM manuals. Even with a guide it quickly becomes time consuming to get it right. Such a guide might be useful for future TBS initiatives? Cheers, Andrew (The book was for a not-for-profit association, has sold >2500 with all proceeds going to the Association) |
Grogs, Did this ever get off the ground, I notice it was first posted in Aug. 2016. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Palcal, I hadn't noticed the dates ( 1) of the post and 2) Today's !!! Andrew |
No, essentially the concept was dropped cos I had too many other things to do. If someone wants to pick up where I left off..... ![]() Smoke makes things work. When the smoke gets out, it stops! |
| miyek.ard Newbie Joined: 31/03/2018 Location: MalaysiaPosts: 24 |
Hi, where can I get the document as stated? |
See my post just above yours. ![]() In other words, this document/project has been abandoned. It is something I would still like to do, but finding the time to do it is the main problem. ![]() Smoke makes things work. When the smoke gets out, it stops! |
I see.. This document will helps a lot. I wish you all the best!! |
| SimpleSafeName Guru Joined: 28/07/2019 Location: United StatesPosts: 351 |
Poking through 4.5c I get these error messages: Number out of bounds All root directory entries are taken Already open An internal error was trapped and your program has been lost (sorry). Array index out of bounds Array must be dimensioned first Battery Backed Clock Not Set CAN not supported in this version COM port is already open Cancelled by remote Cannot access the SD card Cannot change option more than 9 times - reflash MMBasic to reset Cannot continue, program changed Cannot find END SUB or FUN Cannot find a matching FOR Cannot find file Cannot find label Cannot find or create directory Cannot find variable Cannot open file Cannot re dimension array Cannot read from file Cannot rename across drives Cannot unload this font Cannot write to file Cannot write to flash memory Command not valid on A: Command table too large Corrupt file Corrupt sprite file DE is invalid DO without matching LOOP DS18B20 not responding Directory not empty Divide by zero Error closing communications Exit and discard all changes (Y/N): Expected a comma Expected a number Expected a string Expected closing bracket Expected opening bracket FILE NOT FOUND FOR with misplaced = or TO FOR without matching NEXT File is read only File name already exists File number is already open File number is not open Filename must be quoted Flash memory write failure Flow control not available Font is not loaded Font number is in use Format specification not found I2C is busy IF without THEN Illegal character in format specification Illegal character in variable Incompatible arguments Incompatible types in expression Incorrect argument count Incorrect expression syntax Incorrect number of arguments Input line is too long Insufficient data Insufficient space in array Internal fault (sorry) Invalid 7 bit device address Invalid COM specification Invalid Filename Invalid I/O pin Invalid Syntax Invalid address Invalid argument Invalid array dimension Invalid baud rate Invalid character Invalid colour Invalid configuration Invalid date Invalid file access mode Invalid file number Invalid file or directory name Invalid flag combination Invalid flag specification Invalid font file format Invalid font file parameters Invalid font number Invalid format Invalid function Invalid in a program Invalid input pin Invalid inside THEN ... ELSE Invalid line number Invalid mask Invalid mode Invalid number of bits Invalid number of parameters Invalid operator in expression Invalid options Invalid output pin Invalid palette Invalid pin Invalid scale Invalid search specification Invalid speed Invalid sprite file Invalid string size Invalid syntax Invalid time Invalid type specification following & Invalid use of an array Invalid variable LINE IS TOO LONG LOOP without a matching DO Label is too long Library not loaded Library uses line numbers Line is too long Line is too long to edit Local invalid here MARKED TEXT EXCEEDS 255 CHARACTERS Matching LOOP also has a WHILE test Matching LOOP also has an UNTIL test Mode not valid on A: Multiline IF without matching ENDIF Multiple spaces between END SUB Negative argument to SQR() No DATA to read No DO loop is in effect No FOR loop is in effect No closing bracket in expression No error No function call to return to No space on media No variables to read Not a directory Not a file Not enabled Not enough memory Not in slave read state Not in slave send state Not open Nothing to return to Number of colours Number of dimensions Number out of bounds Number out of range Number too large for an integer Numeric variable required OPTION BASE must be before DIM or LOCAL OUT OF MEMORY Old and new filenames are the same Only drive A: is valid Only one flash file can be accessed at a time Only one format specifier (%) allowed Only one internal flash file can be open at a time PCF8563 not responding Pin is allocated to a communications function Pin is in use Pin is not an input Pin is not an output Pin is not configured for output Pin not configured for input Pin not configured for output Program in memory not saved Remote did not respond Return from interrupt when not in an interrupt SD card is write protected SD card not found Slave enabled Slave not enabled Source and destination are the same Sprite is in use Sprite is not on Sprites already loaded Sprites not loaded Stack overflow. Expression is too complex String is too long String too long String variable required Syntax error The WATCHDOG command timed out and restarted the processor. The serial console is already open This font is in use Token table too large Too many SUB and FUN Too many arguments Too many concurrent PULSE commands Too many dimensions Too many errors in transmission Too many files open Too many files to list Too many nested DO or WHILE loops Too many nested FOR loops Too many nested GOSUB Too many nested sub/function Too many string expressions Unexpected text Unknown command Unrecognised drive letter Unrecognised option Valid in MODE 1,7 only Variable already Local Variable name too long Variable not found Video is not enabled WHILE without matching WEND Write to flash memory failed to verify correctly Zero length argument And I'm not sure that all of them count as errors. And some only apply to the internal editor. |
