Local Time 18:06 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : FontTweak extra feature request
kiiid
Posted: 03:50am 03 Sep 2016
I guess this message mainly concerns TassyJim.
Playing at the moment with FontTweak and trying to use it to create a custom font. It has very good functions, however I found impossible to change the size of the image matrix. For example if I load a font which is 16x16, I can't convert that to say 16x24 or 12x20 or something else. Basically that comes down to adding or trimming the needed number of lines/rows to or from the bit matrix. Would there be any possibility for this to be added? I believe there will be a very good use for it.
Thanks!
http://rittle.org
Posted: 12:24pm 03 Sep 2016
It is something that is on the 'probably' list.
I just need to get back to work on this and most other 'mite related software.
Phil23
Posted: 02:41pm 03 Sep 2016
Hi Jim,
Been thinking about writing a Font Preview program to demonstrate various fonts on the different screens.
Was think along these lines;
[Code]
Sub Whatever
HWidth=MM.HRes\MM.FonWidth
VRows=MM.VRes\MM.Font Height
[/code]
Then print a few sample strings & report the Text Res (Rows & Columns) at minimum spacing.
But when I think a bit further I wonder if it would be easier for someone to do it in software.
If the app could create a window appropriately sized, 320x240, 800x480 etc & just display a sample & report the resolution.
Only other input it might be good for it to accept would be line spacing, either as Pixels or % of MM.FontHeight.
Alternatively, is there anything already out there that does something similar.
Phil.
