Local Time 18:06 21 Jun 2026 Privacy Policy
Forum Index : Electronics : Ripple-switch filter?
Posted: 06:38pm 15 Sep 2016
Does anyone know how you would go about filtering off the signal the power board sends down the mains to switch the hot-water cylinder off and on?
Here in NZ, it is about 1kHz by the sound of it, but it is a perfect frequency for getting into audio paths. My amplifier is always whining with intermittent ripple-switch tone bursts, as they manage the load on the network.
Is anyone aware of anything you can get/make/buy that will filter this out of the MAINS VOLTAGE, cos it is passing right through all transformers and PSU's, and ends up as a very annoying whirr noise on the stereo.
One way around that is to crank up the volume, but if you want the music quiet as background music, and that bloody ripple-switch noise keeps coming over the speakers - roughly 1kHz is not much fun as background music......
Madness
Posted: 10:52pm 15 Sep 2016
Have you considering making a complaint to the power company as they are the one causing it. You also could build an Inverter and have your own clean power source
Posted: 12:00am 16 Sep 2016
LOL - Love your comment about the inverter - funny you should say that......
Complaining to the power board would get me no-where. As every single house has a ripple-switch, they would just say it is your hard-cheese cos they ain't gonna change anything for one or two complaints about the ripple-switch noise.
I suppose I could ask them about it, but I seriously doubt they would do anything to help there.
Madness
Posted: 12:25am 16 Sep 2016
If they won't turn down the strength of it or supply a filter to stop they should at least provide you with details of what would stop it. Have you tried running the amplifier through a small computer UPS?
yahoo2
Posted: 12:34pm 16 Sep 2016
http://www.elec.uow.edu.au/apqrc/content/technotes/UOW019_Tech%20Note%2014_AW_screen.pdf
it says the ripple can be as high as 30 volt with a combination of underground and poles and wires causing amplification. interesting
Posted: 03:23pm 16 Sep 2016
They are called "zellweger relays" and a google search will give plenty of info about them but not a lot in ways to filter it out.
Back in my early days, the signals were generated by motor-generator sets.
Even then you could hear the 1050Hz signals if you were standing near the meter box when they went off.
They are used in most Australian states with a notable exception of Tasmania. We like to be different and switch our off-peak loads using time switches. A bit sad if the peak load period changes!
Phil23
Posted: 11:53am 17 Sep 2016
Hey Grog,
Just curious about how much current your audio system draws?
Don't suppose you can beg borrow or steal a 12V PSW inverter & they running it of that to see what happens?
Would need a fairly juicy 12V supply though, & maybe something like a SLA battery to buffer the peaks.
Might isolate whether it's getting in via the P/Supply or induced some other way.
Phil
Posted: 12:57am 20 Sep 2016
Well, Phil, the new one is currently under construction and uses +/- 32v AC supply, with 8.4A of capacity per rail - a 16A toroid from Germany is running the power amps side of things. A good 50% or more of that capacity will be used by the sub amps I would expect - they are the ones that suck most of the juice.
I am in the process of building one of those OzInverter beasts as described in the Electronics forum. So among other things, once that is up and running, I can chop off the street supply.
