Local Time 15:49 07 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Programming Proverbs
Posted: 02:21pm 11 Oct 2016
Back in the '70s there was a book called Programming Proverbs by Henry Ledgard
I was recently made aware of it and it does have a lot of ideas very relevant to today to both experienced and beginning programmers.
A blog on MSDN is worth a look, including the comments by others.
https://blogs.msdn.microsoft.com/alfredth/2007/01/19/programming-proverbs/
I would make a small change for the 'mites - test small code fragments so you know how to talk to the attached devices first. Then start again on the big program.
Posted: 11:43am 12 Oct 2016
Another useful link
https://ericlippert.com/2014/03/05/how-to-debug-small-programs/
  Quote  If your program still has a bug, obtain a rubber duck. Or if a rubber duck is unavailable, get another computer science undergraduate, it’s much the same. Explain to the duck using simple words why each line of each method in your program is obviously correct. At some point you will be unable to do so, either because you don’t understand the method you wrote, or because it’s wrong, or both.
paceman
Posted: 06:35pm 12 Oct 2016
Luvvit Jim - and I think (know... ) I'm guilty of many of the sins.
This quote from it is pretty good too.
If this sounds like a lot of work, that’s because it is. If you can’t do these techniques on twenty line programs that you wrote yourself you are unlikely to be able to use them on two million line programs written by someone else, but that’s the problem that developers in industry have to solve every day. Start practicing!
Greg
Posted: 02:16am 13 Oct 2016
a favourite one that is particularly salient when contemplating the merits (or otherwise) of modern object-orientated methodologies:
"Any programming problem can be solved by adding another layer of
abstraction. Except for the problem of too many layers of abstraction."
i believe the first sentence is a variation on a quote from a famous GDP (great dead programmer) by the name of David Wheeler. the (full) original quote may have been, "All problems in computer science can be solved by another level of indirection, but that usually will create another problem."
with some wisdom Bart Smaalders (not yet dead) quipped, "Layers are for cakes, not for software."
see: http://www.dmst.aueb.gr/dds/pubs/inbook/beautiful_code/html/Spi07g.html#layers_forever
rob :-)
Edited by robert.rozee 2016-10-14
paceman
Posted: 12:25am 14 Oct 2016
Geeze Rob, had a quick look at that article and decided having been a metallurgist was a lot more fun.
Greg
Posted: 10:45am 14 Oct 2016
I should give credit to the Liberty Basic forum.
This is where the debugging discussion started.
Same problems everywhere.
paceman
Posted: 01:29am 15 Oct 2016
Think the little two-box loop directly above "NO PROBLEM" doesn't have an exit condition. Mind you Jim, as I mentioned, I'm a metallurgist.
Greg
