Forum Index : Microcontroller and PC projects : Occasional MM corruption
Hi all, I'm getting an odd corruption on one of my MX170's every week or so. Always a similar scenario; resend the code & it's fine. Listing it when crashed I see junk. Downloaded the full contents of it this morning before reloading it. This is what I got: Interested in hearing comments. 4 ESP8266's sitting on devices here & this one seems to be the only offender. [Code] j=: sta(18:f'":66:4f) 146 > add if0 148 > f r-1, ets Jan 8 2013,rst cause:4, boot mode:(3,1) wdt reset load 0x40100000, len 1396, room 16 tail 4 chksum 0x89 load 0x3ffe8000, len 776, room 4 tail 4 chksum 0xe8 load 0x3ffe8308, len 540, room 4 tail 8 chksum 0xc0 csum 0xc0 2 nd boot version : 1.4(b1) SPI Speed : 40MHz SPI Mode : DIO SPI Flash Size & Map: 8Mbit(512KB+512KB) jump To run user1 @ 1000 rbr!!!a 93 > 93 > ** esp-link v2.1.7 - 2015-12-13 08:49:46 - cb75396 93 > Flash config restore ok 93 > CONN led=0 95 > Wifi init, mode=STA 97 > Wifi uses static IP 192.168.59.181 101 > "ip": "192.168.59.181" 104 > "netmask": "255.255.255.0" 107 > "gateway": "192.168.59.100" 110 > "hostname": "ESP_D4664F" 113 > sleep enable,type: 2 116 > Httpd init, conn=0x3fff293c 119 > Serbridge pins: reset=12 isp=13 swap=0 132 > Reset cause: 0=normal 132 > exccause=0 epc1=0x0 epc2=0x0 epc3=0x0 excvaddr=0x0 depc=0x0 133 > Flash map 1MB:512/512, manuf 0xE0 chip 0x4014 137 > ** esp-link ready 139 > MQTT_Init 141 > mode : sta(18:nm":66:4f)" 144 > add if0 146 > f r0, ets Jan 8 2013,rst cause:4, boot mode:(3,1) wdt reset load 0x40100000, len 1396, room 16 tail 4 chksum 0x89 load 0x3ffe8000, len 776, room 4 tail 4 chksum 0xe8 load 0x3ffe8308, len 540, room 4 tail 8 chksum 0xc0 csum 0xc0 2 nd boot version : 1.4(b1) SPI Speed : 40MHz SPI Mode : DIO SPI Flash Size & Map: 8Mbit(512KB+512KB) jump To run user1 @ 1000 rbr!!!a 93 > 93 > ** esp-link v2.1.7 - 2015-12-13 08:49:46 - cb75396 93 > Flash config restore ok 93 > CONN led=0 95 > Wifi init, mode=STA 97 > Wifi uses static IP 192.168.59.181 101 > "ip": "192.168.59.181" 104 > "netmask": "255.255.255.0" 107 > "gateway": "192.168.59.100" 110 > "hostname": "ESP_D4664F" 113 > sleep enable,type: 2 116 > Httpd init, conn=0x3fff293c 119 > Serbridge pins: reset=12 isp=13 swap=0 132 > Reset cause: 0=normal 132 > exccause=0 epc1=0x0 epc2=0x0 epc3=0x0 excvaddr=0x0 depc=0x0 133 > Flash map 1MB:512/512, manuf 0xE0 chip 0x4014 137 > ** esp-link ready 139 > MQTT_Init=` 141> mode : sta(18>s'":66:4f) 144 > add if0 146 > f r0, ets Jan 8 2013,rst cause:4, boot mode:(3,1) wdt reset load 0x40100000, len 1396, room 16 tail 4 chksum 0x89 load 0x3ffe8000, len 776, room 4 tail 4 chksum 0xe8 load 0x3ffe8308, len 540, room 4 tail 8 chksum 0xc0 csum 0xc0 2 nd boot version : 1.4(b1) SPI Speed : 40MHz SPI Mode : DIO SPI Flash Size & Map: 8Mbit(512KB+512KB) jump To run user1 @ 1000 rbr!!!a 93 > 93 > ** esp-link v2.1.7 - 2015-12-13 08:49:46 - cb75396 93 > Flash config restore ok 93 > CONN led=0 95 > Wifi init, mode=STA 97 > Wifi uses static IP 192.168.59.181 101 > "ip": "192.168.59.181" 104 > "netmask": "255.255.255.0" 107 > "gateway": "192.168.59.100" 110 > "hostname": "ESP_D4664F" 113 > sleep enable,type: 2 116 > Httpd init, conn=0x3fff293c 119 > Serbridge pins: reset=12 isp=13 swap=0 132 > Reset cause: 0=normal 132 > exccause=0 epc1=0x0 epc2=0x0 epc3=0x0 excvaddr=0x0 depc=0x0 133 > Flash map 1MB:512/512, manuf 0xE0 chip 0x4014 137 > ** esp-link ready 139 > MQTT_Init ` 141> mode : sta(18:n?":66:4f)" 144 > add if0 146 > f r0, Fatal exception 0(IllegalInstructionCause) 151 > epc1=0x40201340, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000 ets Jan 8 2013,rst cause:4, boot mode:(3,1) wdt reset load 0x40100000, len 1396, room 16 tail 4 chksum 0x89 load 0x3ffe8000, len 776, room 4 tail 4 chksum 0xe8 load 0x3ffe8308, len 540, room 4 tail 8 chksum 0xc0 csum 0xc0 2 nd boot version : 1.4(b1) SPI Speed : 40MHz SPI Mode : DIO SPI Flash Size & Map: 8Mbit(512KB+512KB) jump To run user1 @ 1000 rbrnn!!!a 94 > 94 > ** esp-link v2.1.7 - 2015-12-13 08:49:46 - cb75396 94 > Flash config restore ok 94 > CONN led=0 96 > Wifi init, mode=STA 98 > Wifi uses static IP 192.168.59.181 102 > "ip": "192.168.59.181" 105 > "netmask": "255.255.255.0" 108 > "gateway": "192.168.59.100" 111 > "hostname": "ESP_D4664F" 114 > sleep enable,type: 2 117 > Httpd init, conn=0x3fff293c 120 > Serbridge pins: reset=12 isp=13 swap=0 133 > Reset cause: 2=exception 133 > exccause=0 epc1=0x40201340 epc2=0x0 epc3=0x0 excvaddr=0x0 depc=0x0 134 > Flash map 1MB:512/512, manuf 0xE0 chip 0x4014 138 > ** esp-link ready 141 > MQTT_Init `j=: sta(18:fe:34:2 [/code] |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6515 |
Try swapping a couple of ESP8266's and see if the error follows the ESP8266. Jim VK7JH MMedit |
