Local Time 18:04 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM ANALOG POWER pins & additional serial
Posted: 12:28pm 21 Jan 2017
On the 28-pin micromite, can the Analog Power and Analog Ground pins be reconfigured as serial (or digital) pins if analog is not needed?
In the manual, in Appendix A, Serial Communications, it says: "Additional serial ports can be added to the Micromite by using the SerialTx and SerialRx embedded C modules. These are included in the "Embedded C Modules" folder in the Micromite firmware zip file."
Is the means of doing this explained in the referenced firmware zip file or somewhere else?
Posted: 12:54pm 21 Jan 2017
  lizby said   On the 28-pin micromite, can the Analog Power and Analog Ground pins be reconfigured as serial (or digital) pins if analog is not needed?
No they are power pins and cannot be reconfigured.
Information on how to use the C functions is covered in the Embedded C Modules folder of the firmware ZIP file
Posted: 07:44pm 21 Jan 2017
Hi.
Refer to the attached PDF files. They are included as part of the Micromite firmware download ZIP file, but you might not have downloaded that.
Serial transmitter for any I/O pin
Serial receiver for any I/O pin
The instructions are all in the PDF, and you just copy the C-Function text into your program, and when you run it, you will magically have as many serial port pins as you want.
