Forum Index : Microcontroller and PC projects : Cant display temterature
Desw
Posted: 07:05pm 25 Feb 2017
This is my first post to any forum.Have taken up interest in the Micromite since reading about it in Silicon chip.Have worked with the picaxe but liked the idea of touch screen control.My problem is getting a DS18B20 to display its temperature on the LCD.Using the code TEXT MM.HRes/2,MM.VRes/4,DS18B20$,CM,1,4,RGB(CYAN),RGB(BLUE)does not return any errors but will not show temperature reading.Have spent a lot of time trying to figure out how to without any luck Would be very thankfull if some one could help out. Hardware is working as the temp shows up on the conscole.
Posted: 07:15pm 25 Feb 2017
Welcome to the forum.
Can you get any text to display on the LCD?
Can you get the temperature to display on the console as a string?
DS18B20$ = str$(TEMPR(pin_number))
PRINT DS18B20$
That will confirm the reading part.
Only then can you try and display it.
Desw
Posted: 07:30pm 25 Feb 2017
Thanks for replying
Have displayed text time date etc on LCD
Have displayed temp on console
Will try with your code
Thanks again
Desw
Posted: 08:19pm 25 Feb 2017
Thank you TassyJim
Tried your code it worked
Are u from Tasmania by any chance
Posted: 09:12pm 25 Feb 2017
What makes you think that?
North-West.
