Local Time 20:13 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Displaying 2 DS18B20s
Desw
Posted: 09:00pm 27 Feb 2017
I cannot work out how to display 2 DS18B20 at the same time.1 is connected to pin16 the other to pin18.How do you give them seperate strings so they can be displayed seperately.
The code Im using is DS18B20$=(TEMPR(16))
Thanking you for your help
jman
Posted: 09:21pm 27 Feb 2017
Temp1$=TEMPR(16)
Temp2$=TEMPR(18)
Jman
Desw
Posted: 12:39pm 28 Feb 2017
I dont know wot Im doing wrong but I keep getting error: Expecting a string with this code
Love New Zealand have been there 2 times People very friendly
Posted: 12:55pm 28 Feb 2017
You have to convert the numerical value returned by TEMPR() to a string
Temp1$=STR$(TEMPR(16))
Temp2$=STR$(TEMPR(18))
If you want to display with a fixed number of decimal places, STR$() has options for that.
skylight
Posted: 04:02am 02 Mar 2017
If you wish to leave the result as a number,to perform maths on for conversion from centigrade to Fahrenheit for instance:
PRINT "Temperature in Degrees C = " TEMPR(16)
PRINT "Temperature in Degrees C = " TEMPR(18)
The result x1.8+32 gives the temperature in Fahrenheit.
Remember if there is an error in measurement the device will return 1000
so the above formula may give a ridiculous temperature result occasionally, you would need to code to ignore those errors.Edited by skylight 2017-03-03
