Local Time 17:09 19 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PLAY VOLUME command....
Posted: 12:38am 07 Mar 2017
The PLAY VOLUME does not appear to work for the TONE command.
If I issue PLAY VOLUME 25, then issue PLAY TONE 1000,1000,500, the tone plays at maximum volume no matter where I put the volume number.
I guess that means that volume only works on WAV playback, but is there any way to make it change the volume of the PLAY TONE command? I have the volume control set via a spinbox control, and was thinking that PLAY VOLUME also worked for setting the volume of the PLAY TONE command also - apparently this is not the case.
As I have now built the PCB and the amp has no on-board volume control, is there any chance that the PLAY VOLUME command can be made to change the volume of the PLAY TONE command?
CaptainBoing
Posted: 01:00am 07 Mar 2017
I think this is a stock PWM output, if so, it is a square wave swinging from VCC to GND, no?
Posted: 12:12pm 07 Mar 2017
Record some suitable tones as WAV files?
Posted: 02:28pm 07 Mar 2017
Well, DUH, Grogster!!!!
Nice thinking Jim - so obvious.
Problem solved.
