Local Time 15:33 07 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Compatibility of 4.5 and 5.3 code.
Paul_L
Posted: 12:13am 02 Apr 2017
In an effort to make code written for MMbasic v5.3 run under the MMbasic.exe v4.5 interpreter I have found what I believe might be a snag.
In 5.3 you dimension and assign initial values to variables like this:
OPTION EXPLICIT : DIM a=22, b=33, c$="Hi there."
Q1: Will 4.5 fail if you try to DIM other than array variables?
DIM a, b, c$
Q2: Will 4.5 fail if you try to assign initial values in a DIM statement?
Q3: Under 4.5 should you just assign initial values in separate statements, without using DIM, like this?
'DIM a, b, c$
a=22:b=33:c$="Hi there."
Q4: In an attempt to include conditional statements which will select versions based on where the code is running will the following work?
'OPTION EXPLICIT:DIM MM 'comment this line out for 4.5, leave in for 5.3
MM=4.5 'substitute 4.5 or 5.3 for different versions
if MM=4.5 then
else
endif
Paul in NY
Posted: 04:13pm 02 Apr 2017
You can do it the 'slow and steady' way to work for both versions.
  Quote   DIM a,b,c$
a=
22: b=33: c$="Hi there."
You think you have problems,
With MMEDit, I have to cater for 6 different devices, all with multiple versions of MMBasic on them.
Paul_L
Posted: 09:57pm 02 Apr 2017
Hi Jim. The reason I asked this question is that the manual for 4.5 does not mention using DIM to declare simple variables. It says:
  Quote  DIM var(dim) , [var(dim)]...
Specifies a variable that is an array with one or more dimensions. The
variables can be numbers or strings with multiple declarations separated
by commas.
I guess that if DIM will work with simple variables then Geoff just must have figured that nobody would bother to use it to pre-declare variables because he hadn't introduced OPTION EXPLICIT yet.
Paul in NY
Paul_L
Posted: 12:56am 04 Apr 2017
Some more interesting tidbits.
1. Using a "?" as an abbreviation for "PRINT" is interesting. If you follow the "?" with a quoted string no space is required but if you follow the "?" with a variable name you have to include a space after the "?". In other words this code
?"-----------":k=4:?k
produces
[2]k=4:?k
Error: Invalid character
but this code
?"-----------":k=4:? k ' space has been added after the "?"
produces the expected
4
2. Version 4.5 will apparently follow the old microsoft convention of allowing a single variable name to be used simultaneously for different types. In other words you can have an H$ and an H! (float single precision) and they are different variables! I think Geoff "separated" the variable name from the type designator after this version. This means that you have to use the type designator when you call the string variable even if there is no float variable with the same name.
For example:
H$="eleven":H=11:? H$:? H:H$="twenty two":H=H+11:? H$:? H
produces
eleven
11
twenty two
22
and this
i$="this is another string":?"-------------"::? i
produces
0
instead of the possibly expected
Very interesting.
Paul in NY
Edited by Paul_L 2017-04-05
