Local Time 18:06 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GUI Control
palcal
Posted: 05:01pm 12 Apr 2017
Still having problems with this.
Can some one tell me what is wrong with my code.
OPTION EXPLICIT
COLOUR RGB(WHITE), RGB(BLACK)
' reference numbers for the controls are defined as constants
CONST numEntry = 1
DIM x AS INTEGER
CLS
GUI INTERRUPT TouchDown, TouchUp
Start:
GUI NUMBERBOX numEntry, 50,40,90,40,RGB(YELLOW),RGB(64,64,64)
CtrlVal(numEntry) = "##ENTER"
DO
LOOP until X>0
Print "Number = ";x
Pause 3000
Goto Start
SUB TouchDown
SELECT CASE TOUCH(REF) ' find out the control touched
CASE numEntry
PRINT "entering a number"
END SELECT
END SUB
' interrupt routine when the touch is removed
SUB TouchUp
SELECT CASE TOUCH(LASTREF) ' use the last reference
CASE numEntry ' was it the numEntry box
x = CTRLVAL(numEntry)
PRINT x
END SELECT
END SUB
Result.
  Quote  run
entering a number
123
Number = 123
[10] GUI NUMBERBOX numEntry, 50,40,90,40,RGB(YELLOW),RGB(64,64,64)
Error: GUI reference number #1 is in use
Thanks....Paul.Edited by palcal 2017-04-14
Zonker
Posted: 05:13pm 12 Apr 2017
When you first run things go ok until you force the "goto start"
You then try to "re-declare" the creation of your numberbox GUI object...
You can't do that. The program will "force stop" because you attempt to do so...
Just stay inside the Do-Loop after the GUI objects are created...
Posted: 05:22pm 12 Apr 2017
Completely agree with Zonker. You can't re-define controls that have already been defined - that is why it is moaning at the console with the error.
Zonker is also right about staying within the loop.
Don't despair - GUI programming takes a bit of head-scratching if you have not done it before. Edited by Grogster 2017-04-14
palcal
Posted: 05:58pm 12 Apr 2017
OK understand, but if I declare it at the start of the code, how do I get the
NUMBERBOX to appear every time I want to use it.
If it is not asking too much could you fix my code and post it back.
Paul.
Posted: 07:30pm 12 Apr 2017
Have a play with GUI HIDE and GUI SHOW
Create all the controls and hide the ones that are for later
when you want to see the control GUI SHOW
palcal
Posted: 08:05pm 12 Apr 2017
Ok tried the HIDE and SHOW but now I get an error with
x = CtrlVal(numEntry)
Error.. Expected a number
Paul.
palcal
Posted: 08:07pm 12 Apr 2017
I have worked on this on and off for over a month, I have read and re read the Manual
real Geoff's example code but I just can't get it right.
palcal
Posted: 08:33pm 12 Apr 2017
This is the code at the moment.
Option EXPLICIT
Colour RGB(WHITE), RGB(BLACK)
Const numEntry = 1
Dim x As INTEGER
CLS
Start:
GUI Hide numEntry
START:
GUI Show numEntry
Loop Until X > 0
Print "Number = ";x
Pause 3000
GoTo Start
Sub TouchDown
Select Case Touch(REF) ' find out the control touched
Case numEntry
Print "entering a number"
End Select
End Sub
Sub TouchUp
Select Case Touch(LASTREF) ' use the last reference
Case numEntry ' was it the numEntry box
End Select
End Sub
I am just trying to enter a number and print it over and over..
When I run this code the NUMBERPAD appears but the number does not enter when I
hit enter.
Paul
BobD
Posted: 08:46pm 12 Apr 2017
Paul
You have the labels START: and Start: in your program. That may confuse the interpreter.
Bob
BobD
Posted: 08:50pm 12 Apr 2017
Paul
Instead of
[code]
START:
GUI Show numEntry
Loop Until X > 0
Print "Number = ";x
Pause 3000
GoTo Start [/code]
What about this
[code]
GUI Show numEntry
Loop Until X > 0
Print "Number = ";x
Pause 3000
Loop [/code]
It gets rid of the GOTO
Bob
palcal
Posted: 09:05pm 12 Apr 2017
The first Start: was left there my mistake.
I will try your code and see what happens.
I probably am stupid but this GUI stuff is very confusing.
Paul.
Posted: 09:07pm 12 Apr 2017
This might be what you are after.
OPTION EXPLICIT
CONST numEntry = 1
DIM x AS INTEGER
CLS
'GUI Hide numEntry
START:
PRINT "Ready..."
x =
0
'GUI Show numEntry
CTRLVAL(numEntry) = "##ENTER"
DO
LOOP UNTIL X > 0
PRINT "Number = ";x
PAUSE 3000
GOTO START
SUB TouchDown
CASE numEntry
END SELECT
END SUB
SUB TouchUp
END SELECT
END SUB
I removed the first START:
The SHOW and HIDE aren't really needed for this simple program but I expect you will need them in the final code.
You had the line
in the middle of the DO LOOP
I cleared the X value to zero so it waits for a new entry. Without resetting X, the code kept going through the main loop.
palcal
Posted: 09:15pm 12 Apr 2017
Thanks a lot Jim, that works. Thanks to every one who chimed in, don't know
what I would do without you.
Now to see if I can implement that into my final code.
Watch this space!!!
Paul.
Posted: 12:03am 13 Apr 2017
[Quote=Paul]I probably am stupid but this GUI stuff is very confusing.[/Quote]
You are NOT stupid.
If it makes you feel any better, I was tearing my hair out when I first started working with GUI controls. They behave in and of themselves, quite differently to how you expect a normal sequential program to run, and so you have to deal with, and think about how MMBASIC is treating all these various interrupts causing the code to hop about the place in a somewhat random fashion - or so it seems at first, and yes - confusing as hell.....
HOWEVER, it DOES get easier the more you play with GUI, and as more and more members here start to play with the GUI controls ideas, you will get more and more people chiming in with ideas. For right now, GUI controls are still reasonably new to the MMBASIC user, and many people are probably frightened off by their complexity to some extent.
But hang in there - well worth the effort to learn the GUI stuff!
palcal
Posted: 11:13am 13 Apr 2017
Thanks Grogs, Geoff has done a wonderful job on the manuals and I don't want to knock but nowhere to my knowledge does it explain that the control can only be used once and once removed from the screen will throw the 'already in use' error when you bring it back up. I understand now how to hide and show so should be OK.
I don't know if this would work but could the CLS command also hide the control then when needed just use GUI show.
Paul.
Posted: 12:31pm 13 Apr 2017
From the Micromite Plus manual under "Using basic drawing commands"
  Quote  Note that the CLS command (used to clear the screen) will automatically set any GUI controls on the screen to
hidden (ie, it does a GUI HIDE ALL before clearing the screen)
When I started programming GUIs in Windows, I hated it. I still hate it at regular intervals. I haven't really started anything serious with micromite GUIs so I will be looking for some hair to tear out too.
Phil23
Posted: 12:51pm 13 Apr 2017
Hi Paul,
Yes CLS does seem to act the same as GUI HIDE ALL.
What worked for me was setting up pages after I defined the controls.
I defined 5 pages, 1,2,3,4 & 9 and are always displaying two at a time.
As in Page 1,9
Page 2,9 etc.
Have a look in this post for some ideas.
Ignore the 4th page as I'm breaking rules in that one & it could end up disastrous.
It's still work in progress & I'm now looking at it again after a 6 month break.
I just stuck a quick video of it up on YouTube.
Phil.
Edit:-
@Grogster....
Took me 20 minutes to finish this post including deciding to add the video.
Lol, wasn't intending on repeating what you said.
Edited by Phil23 2017-04-14
palcal
Posted: 02:23pm 13 Apr 2017
I was using CLS but then was re defining the control instead of using GUI show. Thus getting an error.
I am getting somewhere finally and have the NUMBERBOX working well
Thanks to all who have helped.
Paul.
Posted: 09:29pm 13 Apr 2017
Think of defining GUI's as the same kind of idea as defining a variable - you only ever do it once, usually at the top of your program.
If you define a variable with the DIM command, and then try to define it again later on, this will throw an error. GUI controls are exactly the same in that respect.
The only exception to that rule, is if you use the GUI DELETE command to delete a certain control and reference number. If you had control #5, and you deleted it somewhere in your code, you COULD then re-define it as #5 later.
This is probably not good practise though, and all GUI controls PROBABLY should be declared at the start of the program, and left alone - even if you only use that control once or twice in your code. Define it, and move along.
@ Phil23 - I love the GUI pages. They are awesome. With the simple PAGE command, you can select the controls you want to be seen, and hide all the others. If you have lots and lots of controls(I'm currently using about 150), breaking them up into pages makes drawing each screen of controls so simple. I love GUI pages in MMBASIC...
palcal
Posted: 09:42pm 13 Apr 2017
Thanks Grogs, I have my head around it now. All GUIs defined at the start with the rest of the setup. Then CLS and GUI SHOW.
My code is working now. I also found when using Ghost text in the NUMBERBOX that
"##" + String$ works.
Paul.
