Forum Index : Microcontroller and PC projects : PIC32MX170 + PIC16F1455
| kermess Regular Member Joined: 04/04/2013 Location: SpainPosts: 48 |
Hi, good afternoon. I am interested in using these two chips in the same circuit. In the WEB there is a lot of information and the truth is that I get lost and perhaps with this help I can advance a lot. That is ... CPU + USB serial. I want to use the PICKIT3 to program the two chips separately. For PIC32 it is simply the basic outline of the Geoffg manual, Follow the instructions and program the chip with the latest firmware. So far so good. Now the problems come. 1. --- Now what I need is the programming hardware schema link of the PIC16F1455 with the PICKIT3 2. --- The link for the last ".HEX" file to be programmed with the PICKIT3. 3. --- And of course the actual connection scheme of the PIC16F1455 in which all the connections From the USB connector to pins 12 and 13 of the PIC32MX170. ------- Thank you very much to all. A greeting. David |
For the PIC16F1455, Geoff's Microbridge is essential reading http://geoffg.net/microbridge.html Jim VK7JH MMedit |
And this page tells you all about connecting the PIC32MX170 and PIC16F1455. http://geoffg.net/MicromiteBackpack.html Geoff Graham - http://geoffg.net |
