Local Time 19:03 21 Jun 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite eXtreme V5.4.04
Posted: 12:42am 11 Jun 2017
Attached is the latest release 5.4.04 for the 100 and 144-pin parts
2017-06-11_103626_MMX5.4.04.zip
and for the 64-pin parts
2017-06-11_103529_MMX645.4.04.zip
This brings the MMX back in line with the Micromite and Micromite+
Many of the changes in the MM+ were already in the MMX in 5.3 but new features are:
Added the FIELD$() function which can be used to extract subsections (ie, fields) from a string that has each field separated by one or more specific characters (for example, commaseparated-values (CSV) files). This function is useful in splitting apart strings generated by GPS modules and test equipment.
Implemented MAX() and MIN() functions which will return the maximum or minimum
value of a series of numbers.
The TEMPR START command can now start temperature conversions on an unlimited
number of I/O pins simultaneously (previously it was limited to one pin at a time).
Added the NAME command for renaming files.
When a text or number box is touched the pen down interrupt subroutine will now be
called before the keypad is drawn. This gives the programmer the opportunity to redraw non GUI graphics to accommodate the keypad which is about to appear. When the touch is removed the pen up interrupt will be called after the keypad is removed so that any non GUI graphics can be redrawn. This is a key feature in allowing the mixing of non GUI graphics with GUI controls.
The virtual keyboard generated when the user touches a Number Box or a Text Box can be dismissed by the program using the commands GUI NUMBERBOX CANCEL or
GUI TEXTBOX CANCEL
BUG fixes as per MM+ 5.4.04
This release does include a lot of "cut-and-paste" so bugs are very possible - let me know anything you findEdited by matherp 2017-06-12
Zonker
Posted: 04:35pm 11 Jun 2017
Thanks Peter for the update... Will try loading tomorrow after work..!
IvDel
Posted: 05:51pm 13 Jun 2017
Hello!
@matherp, could you give me information if you're planning on publishing of the source codes for micromite Extreme on http://mmbasic.com/?
I saw that the last published version is 5.3.02 but the new version are commented about on the forum.
Thank youEdited by IvDel 2017-06-15
IvDel
Posted: 10:28pm 15 Jun 2017
Hello!
@matherp,Thanks, it's done!
CaptainBoing
Posted: 04:13am 16 Jun 2017
I am having a mare today
I cannot get the FIELD$ function to work. - even taking the example directly from the 5.0404 manual:
> PRINT FIELD$("aaa,bbb,ccc", 2, ",")
Error: Expected a number
> ? mm.ver
5.0404
this is on a Mk2 and MMX
any ideas?
Posted: 05:07am 16 Jun 2017
  Quote  any ideas?
Geoff hasn't included "FIELD$(" in 5.4.04 see this thread
I thought I had on the MMX but it looks like I only put it in the Pi-cromite
I'll include it in the next MMX release
CaptainBoing
Posted: 05:53am 16 Jun 2017
thank god for that, I thought I was going mental...
cheers
GoodToGo!
Posted: 03:33pm 16 Jun 2017
  CaptainBoing said   thank god for that, I thought I was going mental...
cheers
Ahhh yes. Glad I'm not the only one who got burnt by the missing FIELD command...
GTG!
CaptainBoing
Posted: 07:18pm 16 Jun 2017
LOL.
When I saw it in your code example for the SPLIT, I was convinced others had it working and it was only me! Thing is, I am becoming such a doddery old prat that I had completely forgotten the reason I posted that code snippet in the first place was because FIELD$ had been omitted... you might not have a monopoly on the goldfish thing
there is no hope for me. maybe it's time to sit in a chair with a rug over my knees and stare out the window Edited by CaptainBoing 2017-06-18
GoodToGo!
Posted: 12:17pm 17 Jun 2017
Absolute gold!
Don't forget to slowly rock back and forth! Can I get you a nice warm cup of hot chocolate for you to dribble on your blanky?
For the record, I'd like to see the field AND split commands in MMbasic.... very handy.
Cheers!
GTG!
Cherokeecruiser
Posted: 04:38am 03 Jul 2017
I am having difficulty making a count pin return a meaningful result, as it returns a decimal value less than 1. This value increases as the count increases, but never returns a whole count. Setting the pin to fin returns the correct frequency so I am assuing hardware is OK (possibly).
I am wondering if anyone else has had this behaviour for this firmware (I haven't flashed it backwards yet to confirm), or am I missing the obvious (quite likely)
Micromite eXtreme MMBasic Ver 5.04.04 @ 200MHz
Copyright 2011-2017 Geoff Graham
Copyright 2016-2017 Peter Mather
> setpin 6, cin
> print pin(6)
0.00961172
> setpin 6, din
> print pin(6)
0
> print pin(6)
0
> setpin 6, fin
> print pin(6)
2
> setpin 6, fin
> print pin(6)
2
> print pin(6)
2
> print pin(6)
5
> print pin(6)
58
> print pin(6)
18
> setpin 6, cin
> print pin(6)
0.0256313
> print pin(6)
0.0744908
> print pin(6)
0.113739
Posted: 05:08pm 03 Jul 2017
I agree, there is a problem with counting.
I looped pin 11 to pin 13 and ran the following:
  Quote   SETPIN 13, CIN
SETPIN 11, DOUT
DO
FOR n = 1 TO 100
PIN(11) = 1
PAUSE 10
PIN(11) = 0
PAUSE 10
NEXT n
PRINT PIN(13)
LOOP
The result was lots of zeros
Also tried pin 6 with the same lack of counting.
FIN works OK
Posted: 02:45am 04 Jul 2017
Please try the following and let me know the results - no access to H/W at the moment
SETPIN 13, CIN
SETPIN 11, DOUT
DIM INTEGER mycount
DO
FOR n = 1 TO 100
PIN(11) = 1
PAUSE 10
PIN(11) = 0
PAUSE 10
NEXT n
mycount=PIN(13)
PRINT mycount
LOOP
Posted: 11:55am 04 Jul 2017
Sorry Peter,
still no go.
HardingJohn
Posted: 05:50pm 27 Jul 2017
Would it be possible to write some functions for micromite extreme to make use of the PIC32MZ crypto engine. AES 128 bit key encryption and decryption or similar would be very useful. I read that it is not so easy to add C functions to MMBasic for the PIC32MZ compared to the PIC32MX. Will there be sufficient grunt to do achieve this or will the overheads of MMBasic even on a 250 Mhz MZ just make it impractical??
Your thought on the this would be greatly appreciated before I consider just using a SPI crypto chip.
thanks
Just know enough to get me in trouble, but not quite enough to get me out.
Micro-80
Posted: 09:49pm 27 Jul 2017
After setting the PIN as an analog input (SETPIN 20,AIN), any attempt to read this input (PRINT PIN(20)) causes the interpreter to be restarted. 100 pin chip used.Edited by Micro-80 2017-07-29
