Local Time 10:47 19 Jul 2025 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic for DOS Beta 6
     Page 5 of 5
Geoffg
Posted: 11:12pm 18 Sep 2017
  flip said  This bug is very tiny, a SUB or FUNCTION in first line is not recognised by the interpreter.
Wow! That is a subtle one. Thanks for finding it and thanks for the demo code.
Geoff
Geoffg
Posted: 11:18pm 18 Sep 2017
  Peter63 said  I missed a way to send in a default string to input -command?
s$="default string"
input"Default string to be edit or not";s$
print s$
Any trix or fix?
If the user just hits enter the variable will be set to an empty string or zero. So I normally do something like this:
if s$ = "" then s$="default string"
print s$
Geoff
twofingers
Posted: 11:35pm 18 Sep 2017
Hi Peter,
this is not the solution for Micromites (or MMBasic for DOS)! But for Maximites I wrote a function called "LineEdit". Maybe is it a inspiration to do it on Micromites (or MMBasic for DOS)?
2017-09-19_093400_LineEdit2.zip
MichaelEdited by twofingers 2017-09-20
Peter63
Posted: 08:25pm 19 Sep 2017
Hi, Geoff
Yes, this is a way, to do it .
But i missed the edit part of the string .
print s$
Is sending in default-string to buffer before input a way?
MM.keybuf$="default string"
print s$
Peter
Peter63
Posted: 08:44pm 19 Sep 2017
Hi Michael,
  Quote   I wrote a function called "LineEdit".
This is a way to do it . I have a Sub i called sinput that
works like this .
2017-09-20_064054_sinput.zip
This (sinput) Sub return exit keystoke
Peter
twofingers
Posted: 12:38am 20 Sep 2017
Hi Peter,
this is excellent! Good job! Maybe something for the MMBasic Library?
MichaelEdited by twofingers 2017-09-21
Geoffg
Posted: 03:09am 20 Sep 2017
  Peter63 said  Is sending in default-string to buffer before input a way?
print s$
No, all that would do is allow you to backspace over the string (not very useful) - plus it is not a good thing to complicate the language with extra speciality constructs like this when the same outcome can be achieved using ordinary BASIC programming.
GeoffEdited by Geoffg 2017-09-21
CaptainBoing
Posted: 04:18am 20 Sep 2017
I have never met a Basic where you could provide a default string to the INPUT statement - happy to be shown otherwise but it defo isn't Microsoft standard from where MMBasic draws its inspiration (and a lot of look 'n' feel of the language).
Years ago (QB5 days) I had a function called EDIT$ that did very much the same as Michael's LineEdit above. INPUT never had the flexibility for really nice character screen handling... "Redo from start" and scrolling, limiting string length and the ? prompt etc.... EDIT$ allowed you to edit a string at a position on the screen with a maximum length etc.
Edited by CaptainBoing 2017-09-21
Posted: 08:49pm 20 Sep 2017
the following comes close to what is being asked for:
Z$="default value"
getstring("some string = ", Z$)
Print "<" Z$ ">"
Print
Loop Until Z$="quit"
End
Sub getstring(A$, B$)
Print Chr$(13) A$ B$ Chr$(13) A$;
I=Asc(Inkey$)
Loop Until I=13 Or I=8
If I=8 Then
For J=1 To Len(B$): Print " ";:Next J
For J=1 To Len(B$): Print Chr$(8);:Next J
Input "", B$
Else
Print
EndIf
End Sub
you have the choice of pressing the enter key to accept the current default value, or press the backspace key and entering a new value. in order to get away without needing to press the backspace key, there would need to be some way of peeking into the keyboard input buffer without removing the next character from it. but pressing backspace first is really a pretty minor 'cosmetic' issue.
rob :-)
Peter63
Posted: 11:18pm 21 Sep 2017
Hi Michael,
  Quote  this is excellent! Good job! Maybe something for the MMBasic Library?
sinput - it's uploaded to (Fruit of The Shed) now
Peter
twofingers
Posted: 03:20am 22 Sep 2017
Thanks Peter!
BTW.
I find my MaskEdit$-Function also very useful (for MAXIMITES) if you have to get some file names or something like that ...
I needed it for my Maximite File Selector.
'* MASKEdit$ V.95
'* mod of LineEdit()
'* MMBasic 4.5/Maximite
'* line editor for small strings (e.g. file names
'* time$, date$ ...)
'* MASKEdit$("12:45:56",1,"##.##.##")
'* MASKEdit$(" TEST.BAS",1," . ")
'* Special mask characters:
'* " " any ascii character
'* "#" any number(0-9)
'* "." skip char will be ignored/skipped
'* "@" numbers & letters (not yet implemented!)
'* Used functions: FindLeft,FindRight,IsNum
'* Limit:
'* The string must not exceed the width of screen
Function MaskEdit$ edText$, cursorp, edMask$
Local hpos, vpos, p, ep, keyvalue, enterPressed
Local text$,ltext$,mtext$,rtext$,C$,M$,Mask$
Local TRUE, FALSE
TRUE=1
FALSE=0
hpos=MM.HPos:vpos=MM.VPos ' save print position
text$=edText$ ' use local copy of text$ string
MaskEdit$=edText$ ' backup edText$ for Esc
enterPressed=FALSE ' Flag to EXIT the loop
escPressed=FALSE ' a Global var
ep=Len(text$) ' end pointer
C$="." ' prohibited/skipped char
p=cursorp:If Not p Then p=1 ' cursor pointer
Mask$=edMask$ ' local copy
If ep<>Len(Mask$) Then Mask$=Space$(ep)
Pause 200 ' es gibt einen Zeitfaktor fuer keyboard input buffer ~140ms
ltext$=Mid$(text$,1,p-1)
mtext$=Mid$(text$,p,1)
rtext$=Mid$(text$,p+1,ep-p)
Print @(hpos,vpos)ltext$;
Font#1,,1
Print mtext$;
Font#1
Print rtext$;
Do:keyvalue=KeyDown:Pause 50:Loop While keyvalue=0
If keyvalue=130 And p>1 Then
p=FindLeft(Mask$,C$,p) 'p=p-1 'left arrow
EndIf
If keyvalue=131 And p<ep Then 'p=p+1 'right arrow
p=FindRight(Mask$,C$,p)
EndIf
If keyvalue=13 Then
enterPressed=TRUE 'Enter
EndIf
If keyvalue=27 Then 'Esc
Print @(hpos,vpos)MaskEdit$;
escPressed=TRUE
EndIf
If keyvalue=134 Then 'Home
p=1
If Mid$(text$,p,1)=C$ Then
EndIf
EndIf
If keyvalue=135 Then 'End
p=ep
EndIf
EndIf
If keyvalue>=32 And keyvalue<127 Then 'all ASCII chars
M$= Mid$(Mask$,p,1)
If m$=" " Or (m$="#" And IsNum(Chr$(keyvalue))) Then ' num mask, only numbers
If p<ep Then
ltext$=ltext$+Chr$(keyvalue)
If Mid$(Mask$,p+1,1)=C$ Then ltext$=ltext$+Mid$(Text$,p+1,1)
rtext$=Mid$(text$,p+1)
Else
ltext$=Left$(text$,p-1)
mtext$=Chr$(keyvalue)
rtext$=""
EndIf
EndIf
ElseIf keyvalue=132 Then 'insert, when dot is on the right _and_
If mask$=" . " And p<9 Then ' mask$=" . "
mtext$=" "
ltext$=Mid$(text$,2,p-1)
EndIf
ElseIf keyvalue=127 Then 'Del
If p>1 Then
mtext$=Mid$(text$,p-1,1)
ltext$=" "+Mid$(text$,1,p-2)
Else
mtext$=" "
EndIf
EndIf
ElseIf keyvalue=8 And p>1 Then 'Bsp, delete left space
mtext$=" "
Else
If p>=ep Then p=ep
ltext$=Mid$(text$,1,p-1) 'move cursor / over write
EndIf
Font#1,,1
Print mtext$;
Font#1
Print rtext$;
text$=Left$(ltext$+mtext$+rtext$,ep)
Pause 125 ' some wait states to slow down key input
Loop While Not enterPressed And Not escPressed
If Not escPressed Then
MaskEdit$=ltext$+mtext$+rtext$
EndIf
End Function
Function IsNum(Num$)
IsNum=(Asc(Num$)>=48) And (Asc(Num$)<58)
End Function
Function FindRight(S$,C$,p)
Local i
If p<=Len(S$) Then
For i = p+1 To Len(S$)
If Mid$(s$,i,1)<>C$ Then Exit For
Next i
EndIf
If i=0 Then i=p
FindRight=i
End Function
Function FindLeft(S$,C$,p)
Local i
If p>1 Then
For i = p-1 To 1 Step-1
Next i
EndIf
If i=0 Then i=p
FindLeft=i
End Function
'--^^^^^^^ used by MaskEdit ^^^^^^--
Maybe someday we can convert it to MMBasic for DOS.
Michael
Peter63
Posted: 11:40am 22 Sep 2017
Hi Michael
  Quote  I find my MaskEdit$-Function also very useful
jepp, this is useful function... have not tested it yet...
I have tested out Beta 7, version little bit more.
add in three basic program
2017-09-22_213558_coldemo.zip Color-demo program
2017-09-22_213617_psmenu.zip Simple menu-routine
2017-09-22_213648_sortname.zip Sort name inside strings
Peter
Peter63
Posted: 11:54am 22 Sep 2017
Hi Michael, all
add in one more test-program for Beta 7, i wrote...
2017-09-22_215047_sort1.zip Sort strings based on a number inside the strings
This will i used in my Polis Scanner UNIDEN UBC780XLT project
Peter
     Page 5 of 5
© JAQ Software 2025
