Forum Index : Microcontroller and PC projects : FORMAT$ ?
BobC
Posted: 12:43pm 09 Aug 2017
All,
My first post here since getting into MM.
I've seen code posted on Fruit of the Shed that uses FORMAT$. I see that in later versions of MMBasic this seems to be gone. I'm trying to format some output from
an 18B20 to be "xx.xx". My current code outputs up to 4 digits right of the DP.
I'd like to trim that to just 2. I'm sure there is an easy way to do it, I've just not found it yet.
Not an expert Basic programmer here, still getting my feet wet with MMBasic.
I'm using Rob's E28 platform sampled by Stan/Rob and a few of Mick's MuP V2's that I've built. Great hardware! I am a convert from PICAXE and Arduino to MM's. Love them.
Thanks!
Bob
WA1EDJ
Monroe, GA USA
Posted: 01:08pm 09 Aug 2017
Welcome to the shed.
You are correct, FORMAT$ is only in the maximites (V4.5 and earlier)
Have a look at the options in STR$
That will do what you require and is a bit simpler to use.
You probably want STR$(x,3,2) if you allow for negative numbers.
BobC
Posted: 02:07pm 09 Aug 2017
Thanks Jim, I'll give it a try....Bob
palcal
Posted: 05:45pm 09 Aug 2017
If you want it to stay as a numeric variable you can use,
Temp = Int(Temp*100)
Temp = Temp/100
Paul.
