Forum Index : Microcontroller and PC projects : Arrows
Has anyone got any fonts or code for making arrows? I've tried using fonttweak but failed What I need is an arrow pointing up and one pointing down |
http://www.rinkydinkelectronics.com/r_fonts.php About 2/3rds down "Various Symbols" you'll need to download the font you want and convert it using the tools in the "Embedded Fonts" folder in the micromite Firmware distribution. hth |
Thanks I did see that but didn't know how to use it I've downloaded the font I need and converted it to .bas but how do I select the arrows? or tell the micromite I want to use the arrow pointing down in font #8 |
it's the character number; CHR$(x). I am guessing they start from 32 which is <space> and go up to 127 (32+95). Where the character you need occurs in the sequence depends on the fontpack you chose. Let's assume it's character 100, to use it, switch to the font you want and then use CHR$(100) on the panel. See the section "Using an LCD Panel" in the micromite manual, tells you how to work with different fonts. |
The file "various_symbols.bas" in the Micromite zip file (under Embedded Fonts) is a conversion of the Rinky-Dink various symbols file and it has arrows plus a lot of other useful symbols. Geoff Geoff Graham - http://geoffg.net |
Thanks Geoff I'm trying to figure out how to call the various fonts I've tried every combination of the following but I can't get the arrow to display or any other symbol, it only draws numbers PRINT FONT 8 chr$(80) which "should" be the arrow facing upwards This just prints 0 8P |
You can't use fonts to print to the console, only GUIs Look at the TEXT command TEXT x, y, string$[,justification] [, font] [, scale][, c] [, bc] You need something like: Text 100,120,chr$(80),LT,8,1,rgb(red),rgb(black) Jim VK7JH MMedit |
TassyJim you're a star Last question can you assign a variable to a chr$ ? for instance can I have something like the following or is there a better way to do it? dim string ZA = chr$(79) dim string ZB = chr$(80) Text 100,120,ZA,LT,8,2,rgb(red),rgb(black) Text 100,180,ZB(80),LT,8,2,rgb(red),rgb(black) [quote] it doesn't work doing it this way but I'm probably making a stupid mistake[/quote] |
dim string ZB = chr$(80) is fine but in your TEXT command you are trying to make ZB into an array with ZB(80) The TEXT command should be: Text 100,180,ZB,LT,8,2,rgb(red),rgb(black) Geoff Geoff Graham - http://geoffg.net |
