Posted: 05:58pm 24 Oct 2026
Copy link to clipboard |
johansen Newbie
google "amp turns needed to generate 3T" and read the formulas.
Take the thickness of the magnet, plus the distance around the magnet, around the coil, and that's basically the effective distance needed to magnetize to 3T.
its 23,000 amp turns per centimeter.
Iron saturates at 2T so if you can build a solid steel cell to put a coil in it, and the magnet, then you can cut that number probably in half because the coil only has to boost the field from 2T to 3T for the distance and volume it takes to do so, integrals and all that.
so to give you a rough idea, you can generate about what feels like 1T, with a microwave oven primary coil, taken out of its core, and set it on a steel plate and run 120 amps dc through it, which is about 14,400 amp turns. -you need 3 times that.
the resistance of those coils is about 1 ohm (the aluminum ones) so to get 3T you might need a 500 volt power supply to send 500 amps through it, that's 250,000 watts, which my 2500 joule capacitor bank could hold up for.. less than half a millisecond when you include ramp up and down time. Edited 2026-10-25 04:00 by johansen |
