 Just a design idea. You can get 3 of these out of a 100x100mm board. Not recommended for the W versions as the antenna is a bit close to other stuff. However, it should work with any other pin-compatible Pico clone, including the YD-RP2040 as pins 39 and 40 can be linked. This should also allow it to work with a USB hub. I don't think I'd like to use HDMI with it but it might work. The RTC is the tiny self-contained module that plugs onto the end if you want it. My usual idea, that you can fit an external battery when the little yellow one dies. JST 2 connector for a backup battery. QWIIC (if you ever use them - I never have). Depends on the RTC for pullups. WS2812 on the not much use GP22, however you can break a solder blob link to disconnect it and run a wire link from a pad to TP5 to run it from GP25 so that it doesn't use any pins. Obviously, it's not supported by Heartbeat so that has to be disabled. GP0-GP3 used for SD card GP20 & GP21 used for I2C GP22 used for WS2812 (but see above) You get all the rest. :) |
