Ok. Having in my hands the RBpico Zero and the RBpico Pro Micro, due to the (somewhat strange, by the way) pin layout, I used the Zero. With the option to change the VGA output pins, I was able to make it work. First, I loaded the VGA USB firmware, then I connected a USB-to-serial adapter to provide 5V power and used the terminal to change the VGA pins. After that, it worked perfectly. A big advantage of this exercise is that if you have a “different” RBpico, you can make good use of it. What remained on was an RGB LED connected to GP16 (according to the RBpico Zero manual). Again, I thank you for your comments and help. I'm sharing an image of the test. My best regards.  |
