Forum Index : Microcontroller and PC projects : HDMI Colour Mapping ... no success
Posted: 09:10pm
30 Jul 2025
Amnesie
Hello,
obviously I am to stupid to understand colour mapping.
I am using picoMite HDMI, latest version on Resolution 848 in Mode 3.
I tried everything to pick a colour from the RGB palette but can't get ANY change in colour not grey not blue nothing. It doesn't react at all.
Testprogram:
This should print the last (15) colour in grey, instead of white.. But it doesn't. It prints white. But no matter what colour I pick as an RGB value, there is no change at all.
Then I tried out of couriousity:
MAP GREYSCALE
Doesn't work either: Syntax Error...
Also, I think in the manual is an error (typo?)
Page: 177
MAP(8),RGB(100,100,100)
MAP SET
Pixel x,y,map(8)
Shouldn't it be: MAP(8)=RGB(100,100,100)  ??
But even this example doesn't work.
I have no clue what to do. Could anybode please give me a working example of your choice?
Greetings
Daniel
Posted: 12:43am
31 Jul 2025
toml_12953
  Amnesie said  Hello,
You're mapping gray to color 15. After MAP SET when you specify color 15, you'll get gray. Instead of Map(15) at the end of the box statement, try just the number 15.
Box 200,200,10,10,1,1,15 'grey box
At least that's what I think the manual is saying.
Edited 2025-07-31 10:48 by toml_12953
Posted: 05:30am
31 Jul 2025
Peter63
I have tested MAP-change.
Using: PicoMiteHDMI MMBasic USB RP2350A Edition V6.00.03
OPTION RESOLUTION 640 = works
OPTION RESOLUTION 800 = does not work
Why that is, I don't know.
/Peter63
Posted: 05:45am
31 Jul 2025
Peter63
I change to OPTION RESOLUTION 800
and tested this...
> color rgb(red)
> map(8)=rgb(128,128,128)
Error : Invalid for this screen mode
Oohhh  I was in MODE 1 here...   so i tested this...
MODE 2
Color RGB(white),RGB(red)
Print "Some text to print..." ' print white text, RED background
Map(8)=RGB(128,128,128) ' change RED to gray
Map set
End
No change from RED to GRAY ??
/Peter63
Edited 2025-07-31 15:56 by Peter63
Posted: 07:28am
31 Jul 2025
There is bug in the map command for the newer resolutions. It works properly for 640x480, 1024x768 and 1280x720.
Obviously no-one has previously tried it before on anything else - will look at it
Posted: 08:44am
31 Jul 2025
Amnesie
Peter and Peter63,
thank you very much for confirming this
Now I tested the other resolution you have mentioned, they work indeed! And I thought that I am just too stupid. But anyways, at least I found a typo in the manual this way
Greetings
Daniel
Edited 2025-07-31 18:50 by Amnesie
Posted: 12:29pm
31 Jul 2025
Martin H.
Daniel,
maybe this  helps
Martin
Posted: 03:19pm
31 Jul 2025
Amnesie
Martin,
thank you for the link! Pretty amazing what you can do with it! I sucessfully tested it. Mapping is not working on the new resolutions, which I initially tested it with. But with the "old" resolution it works fine.
Greetings
Daniel
