Forum Index : Microcontroller and PC projects : Automatic fish feeder
Posted: 11:15am
22 Mar 2026
Pico2 + Waveshare RTC + Pico-LCD-1.3 + Stepper driver module + TMC2209 driver
Everything 3D printed. STLs available if anyone wants them. Uses archimedian screw to deliver the food.
Runs with a CPU speed of 48MHz which results in a current draw of about 25mA at 12V so an old car battery should run it for a month easily.
option list
PicoMite MMBasic RP2350A V6.02.01RC8
OPTION SYSTEM SPI GP10,GP11,GP28
OPTION SYSTEM I2C GP6,GP7
OPTION AUTORUN  ON
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 48000
OPTION DISPLAY 64, 132
OPTION LCDPANEL ST7789, LANDSCAPE,GP8,GP12,GP9,GP13
' FishFeeder.bas
' Automated fish feeder UI for PicoMite (240x240 display + buttons/joystick)
' Navigation:
' A = next page, B = previous page
' CTRL = toggle edit mode on current page
' UP/DOWN = change selected field/value in edit mode
' LEFT/RIGHT = move field selection in edit mode
' X = manual feed now (from HOME page)
' Y = force RTC SETTIME (from CLOCK page)
Option Explicit
On Error Skip
Stepper Close
Font 1,2
Const a = "GP15"
Const b = "GP17"
Const xbtn = "GP19"
Const ybtn = "GP21"
Const up = "GP2"
Const down = "GP18"
Const leftpin = "GP16"
Const rightpin = "GP20"
Const ctrl = "GP3"
Const dir = "GP27"
Const steppin = "GP26"
Const enable = "GP22"
Const FEED_MAX = 6
Const FEED_DEFAULT_ON = 2
Const UNIT_MM = 2
Const STEP_FEEDRATE = 200
Const PRIME_STEP_MM = 5
Const PAGE_HOME = 0
Const PAGE_CLOCK = 1
Const PAGE_FEED0 = 2
Const PAGE_FEED_LAST = PAGE_FEED0 + FEED_MAX - 1
Const PAGE_HELP = PAGE_FEED_LAST + 1
Const PAGE_PRIME = PAGE_HELP + 1
Const PAGE_LAST = PAGE_PRIME
Const EV_NONE = 0
Const EV_A = 1
Const EV_B = 2
Const EV_X = 3
Const EV_Y = 4
Const EV_UP = 5
Const EV_DOWN = 6
Const EV_LEFT = 7
Const EV_RIGHT = 8
Const EV_CTRL = 9
Dim feedHour%(FEED_MAX)
Dim feedMin%(FEED_MAX)
Dim feedUnits%(FEED_MAX)
Dim feedEnabled%(FEED_MAX)
Dim page% = PAGE_HOME
Dim editMode% = 0
Dim fieldSel% = 0
Dim needRedraw% = 1
Dim lastFeedKey$ = ""
Dim startupMinuteKey$ = ""
Dim scheduleDirty% = 0
Dim ev% = EV_NONE
Dim notfirst% = 0
Dim setYear% = 2026
Dim setMonth% = 1
Dim setDay% = 1
Dim setHour% = 12
Dim setMin% = 0
Dim setSec% = 0
Dim prevA% = 0, prevB% = 0, prevX% = 0, prevY% = 0
Dim prevUp% = 0, prevDown% = 0, prevLeft% = 0, prevRight% = 0, prevCtrl% = 0
Dim primeEndpos! = 0
Dim backlightTimer% = 1500
InitPins
SeedButtonHistory
InitStepper
LoadSchedule
InitDefaults
LoadClockIntoSetFields
SetStartupMinuteKey
Backlight 100
 ev% = ReadEvent%()
 If ev% <> EV_NONE Then
   HandleEvent ev%
   needRedraw% = 1
   Backlight 100
 End If
 HandleXActions
 If XPressed%() Then
   Backlight 100
 End If
 CheckAutoFeed
 If scheduleDirty% Then
   SaveSchedule
   scheduleDirty% = 0
 End If
 If needRedraw% Then
   DrawPage
   needRedraw% = 0
 End If
 If backlightTimer% > 0 Then
   Inc backlightTimer%, -1
   If backlightTimer% = 0 Then Backlight 0
 End If
 Pause 40
Sub InitPins
 TrySetInput a
 TrySetInput b
 TrySetInput xbtn
 TrySetInput ybtn
 TrySetInput up
 TrySetInput down
 TrySetInput leftpin
 TrySetInput rightpin
 TrySetInput ctrl
 Pause 300
End Sub
Sub TrySetInput(pin$)
 On Error Skip 1
 SetPin pin$, DIN, PULLUP
End Sub
Sub SeedButtonHistory
 prevA% = SafeBtn%(a)
 prevB% = SafeBtn%(b)
 prevX% = XPressed%()
 prevY% = SafeBtn%(ybtn)
 prevUp% = SafeBtn%(up)
 prevDown% = SafeBtn%(down)
 prevLeft% = SafeBtn%(leftpin)
 prevRight% = SafeBtn%(rightpin)
 prevCtrl% = SafeBtn%(ctrl)
End Sub
Sub InitStepper
 Stepper Init
 Stepper Axis X, GP26, GP27, GP22, 1, 800, 100, 100
 Stepper Position X, 0.1
 Stepper Run 1
 Stepper gc g1 x0 f100
End Sub
Sub InitDefaults
 Local i%
 If notfirst% Then Exit Sub
 For i% = 1 To FEED_MAX
   feedHour%(i%) = 8 + i%
   If feedHour%(i%) > 23 Then feedHour%(i%) = feedHour%(i%) - 24
   feedMin%(i%) = 0
   feedUnits%(i%) = 1
   If i% <= FEED_DEFAULT_ON Then
     feedEnabled%(i%) = 1
   Else
     feedEnabled%(i%) = 0
   End If
 Next i%
End Sub
Sub LoadSchedule
'  On Error Skip 1
 VAR RESTORE
 NormalizeSchedule
End Sub
Sub SaveSchedule
 On Error Skip 1
 notfirst%=1
 VAR SAVE feedHour%(), feedMin%(), feedUnits%(), feedEnabled%(), notfirst%
End Sub
Sub NormalizeSchedule
 Local i%
   If feedHour%(i%) < 0 Then feedHour%(i%) = 0
   If feedHour%(i%) > 23 Then feedHour%(i%) = 23
   If feedMin%(i%) < 0 Then feedMin%(i%) = 0
   If feedMin%(i%) > 59 Then feedMin%(i%) = 59
   If feedUnits%(i%) < 1 Then feedUnits%(i%) = 1
   If feedUnits%(i%) > 20 Then feedUnits%(i%) = 20
   If feedEnabled%(i%) <> 0 Then
   Else
   End If
 Next i%
End Sub
Sub HandleEvent(ev%)
 If ev% = EV_A Then
   If page% < PAGE_LAST Then
     page% = page% + 1
   Else
     page% = PAGE_HOME
   End If
   editMode% = 0
   fieldSel% = 0
   Exit Sub
 End If
 If ev% = EV_B Then
   If page% > PAGE_HOME Then
     page% = page% - 1
   Else
     page% = PAGE_LAST
   End If
   editMode% = 0
   fieldSel% = 0
   Exit Sub
 End If
 If ev% = EV_X Then
   If page% = PAGE_HOME Or (page% >= PAGE_FEED0 And page% <= PAGE_FEED_LAST) Then
     ManualFeed
   End If
   Exit Sub
 End If
 If page% = PAGE_CLOCK And ev% = EV_Y Then
   ApplyRtc
   Exit Sub
 End If
 If ev% = EV_CTRL Then
   editMode% = 1 - editMode%
   Exit Sub
 End If
 If editMode% = 0 Then Exit Sub
 Select Case page%
   Case PAGE_CLOCK
     EditClock ev%
   Case PAGE_FEED0 To PAGE_FEED_LAST
     EditFeed page% - PAGE_FEED0 + 1, ev%
 End Select
End Sub
Sub HandleXActions
 If page% <> PAGE_PRIME Then Exit Sub
 If XPressed%() Then
   If primeEndpos! = 0 Then
   End If
   If Peek(STEPPER BUFFER) > 10 Then
     Inc primeEndpos!, 0.1
     Stepper GCODE G1, X, primeEndpos!, F, STEP_FEEDRATE
   End If
 Else
   primeEndpos! = 0
 End If
End Sub
Sub EditClock(ev%)
 If ev% = EV_LEFT And fieldSel% > 0 Then fieldSel% = fieldSel% - 1
 If ev% = EV_RIGHT And fieldSel% < 5 Then fieldSel% = fieldSel% + 1
 If ev% = EV_UP Then
   Select Case fieldSel%
     Case 0: Inc setDay%: If setDay% > 31 Then setDay% = 1
     Case 1: Inc setMonth%: If setMonth% > 12 Then setMonth% = 1
     Case 2: Inc setYear%: If setYear% > 2099 Then setYear% = 2000
     Case 3: Inc setHour%: If setHour% > 23 Then setHour% = 0
     Case 4: Inc setMin%: If setMin% > 59 Then setMin% = 0
     Case 5: Inc setSec%: If setSec% > 59 Then setSec% = 0
   End Select
 End If
 If ev% = EV_DOWN Then
     Case 0: Inc setDay%,-1: If setDay% < 1 Then setDay% = 31
     Case 1: Inc setMonth%,-1: If setMonth% < 1 Then setMonth% = 12
     Case 2: Inc setYear%,-1: If setYear% < 2000 Then setYear% = 2099
     Case 3: Inc setHour%,-1: If setHour% < 0 Then setHour% = 23
     Case 4: Inc setMin%,-1: If setMin% < 0 Then setMin% = 59
     Case 5: Inc setSec%,-1: If setSec% < 0 Then setSec% = 59
   End Select
 End If
End Sub
Sub EditFeed(idx%, ev%)
 If ev% = EV_RIGHT And fieldSel% < 3 Then fieldSel% = fieldSel% + 1
 If ev% = EV_UP Then
     Case 0: feedEnabled%(idx%) = 1: scheduleDirty% = 1
     Case 1
       Inc feedHour%(idx%)
       If feedHour%(idx%) > 23 Then feedHour%(idx%) = 0
       scheduleDirty% = 1
     Case 2
       Inc feedMin%(idx%)
       If feedMin%(idx%) > 59 Then feedMin%(idx%) = 0
       scheduleDirty% = 1
     Case 3
       Inc feedUnits%(idx%)
       If feedUnits%(idx%) > 20 Then feedUnits%(idx%) = 20
       scheduleDirty% = 1
   End Select
 End If
     Case 0: feedEnabled%(idx%) = 0: scheduleDirty% = 1
     Case 1
       Inc feedHour%(idx%),-1
       If feedHour%(idx%) < 0 Then feedHour%(idx%) = 23
       scheduleDirty% = 1
     Case 2
       Inc feedMin%(idx%),-1
       If feedMin%(idx%) < 0 Then feedMin%(idx%) = 59
       scheduleDirty% = 1
     Case 3
       Inc feedUnits%(idx%),-1
       If feedUnits%(idx%) < 1 Then feedUnits%(idx%) = 1
       scheduleDirty% = 1
   End Select
 End If
End Sub
Sub ApplyRtc
 Local ys%, ms%, ds%, hs%, ns%, ss%
 ys% = setYear%
 ms% = setMonth%
 ds% = setDay%
 hs% = setHour%
 ns% = setMin%
 ss% = setSec%
 RTC SETTIME ys%, ms%, ds%, hs%, ns%, ss%
 Pause 50
End Sub
Sub LoadClockIntoSetFields
 Local d$, t$
 d$ = Date$
 t$ = Time$
 setDay% = Val(Mid$(d$, 1, 2))
 setMonth% = Val(Mid$(d$, 4, 2))
 setYear% = 2000 + Val(Right$(d$, 2))
 setHour% = Val(Mid$(t$, 1, 2))
 setMin% = Val(Mid$(t$, 4, 2))
 setSec% = Val(Mid$(t$, 7, 2))
End Sub
Sub CheckAutoFeed
 Local t$, d$, hh%, mm%, i%
 Local key$, minuteKey$
 t$ = Time$
 d$ = Date$
 hh% = Val(Mid$(t$, 1, 2))
 mm% = Val(Mid$(t$, 4, 2))
 minuteKey$ = Right$(d$, 2) + Mid$(d$, 4, 2) + Left$(d$, 2) + Right$("0" + Str$(hh%), 2) + Right$("0" + Str$(mm%), 2)
 If minuteKey$ = startupMinuteKey$ Then Exit Sub
 startupMinuteKey$ = minuteKey$
   If feedEnabled%(i%) And hh% = feedHour%(i%) And mm% = feedMin%(i%) Then
     key$ = Right$(d$, 2) + Mid$(d$, 4, 2) + Left$(d$, 2) + Right$("0" + Str$(hh%), 2) + Right$("0" + Str$(mm%), 2) + Str$(i%)
     If key$ <> lastFeedKey$ Then
       DispenseUnits feedUnits%(i%)
       lastFeedKey$ = key$
     End If
   End If
 Next i%
End Sub
Sub SetStartupMinuteKey
 t$ = Time$
 d$ = Date$
 startupMinuteKey$ = Right$(d$, 2) + Mid$(d$, 4, 2) + Left$(d$, 2) + Right$("0" + Str$(hh%), 2) + Right$("0" + Str$(mm%), 2)
End Sub
Sub ManualFeed
 Local idx%, i%
 idx% = 1
 If page% >= PAGE_FEED0 And page% <= PAGE_FEED_LAST Then
   idx% = page% - PAGE_FEED0 + 1
   DispenseUnits feedUnits%(idx%)
   Exit Sub
 End If
   If feedEnabled%(i%) Then
     idx% = i%
     Exit For
   End If
 Next i%
 If idx% <= FEED_MAX And feedEnabled%(idx%) = 0 Then Exit Sub
End Sub
Sub DispenseUnits(units%)
 Local dist!
 If units% < 1 Then units% = 1
 dist! = units% * UNIT_MM
 Stepper GCODE G1, X, dist!, F, STEP_FEEDRATE
 Do While Peek(STEPPER ACTIVE)
End Sub
Sub DrawPage
 CLS
 Select Case page%
   Case PAGE_HOME
     DrawHome
   Case PAGE_CLOCK
     DrawClock
     DrawFeed page% - PAGE_FEED0 + 1
   Case PAGE_HELP
     DrawHelp
   Case PAGE_PRIME
     DrawPrime
 End Select
End Sub
Sub DrawHelp
 Text 4, 4, "HELP"
 Text 4, 28, "A NEXT PAGE"
 Text 4, 52, "B PREV PAGE"
 Text 4, 76, "CTRL EDIT"
 Text 4, 100, "UPDN CHANGE"
 Text 4, 124, "LR MOVE"
 Text 4, 148, "X FEED NOW"
 Text 4, 172, "Y RTC SET"
End Sub
Sub DrawPrime
 Text 4, 4, "PRIME"
 Text 4, 28, "HOLD X RUN"
 Text 4, 52, "REL X STOP"
 Text 4, 76, "CONT MOVE"
 Text 4, 100, "A/B PAGE"
End Sub
Sub DrawHome
 Local nexti%, i%, nowMins%, fm%, m%, t$
 Local dMins%, cH%, cM%
 t$ = Time$
 nowMins% = Val(Mid$(t$, 1, 2)) * 60 + Val(Mid$(t$, 4, 2))
 nexti% = 1
 fm% = 24 * 60 + 1
     m% = feedHour%(i%) * 60 + feedMin%(i%)
     If m% >= nowMins% And m% < fm% Then
       fm% = m%
       nexti% = i%
     End If
   End If
 Next i%
 If fm% = 24 * 60 + 1 Then
       fm% = feedHour%(i%) * 60 + feedMin%(i%)
       nexti% = i%
       Exit For
     End If
   Next i%
 End If
 Text 4, 4, "FISH FEEDER"
 Text 4, 28, Left$(Date$, 8)
 Text 4, 52, Left$(Time$, 8)
 Text 4, 76, "NEXT F" + Trim$(Str$(nexti%))
   Text 4, 100, "--:--"
   Text 4, 172, "IN --:--"
 Else
   Text 4, 100, TwoDigit$(feedHour%(nexti%)) + ":" + TwoDigit$(feedMin%(nexti%))
   dMins% = fm% - nowMins%
   If dMins% < 0 Then dMins% = dMins% + (24 * 60)
   cH% = dMins% \ 60
   cM% = dMins% Mod 60
   Text 4, 172, "IN " + TwoDigit$(cH%) + ":" + TwoDigit$(cM%)
 End If
 Text 4, 124, "EN " + Trim$(Str$(EnabledCount%()))
End Sub
Sub DrawClock
 Local m$, markX%
 markX% = 240 - (3 * MM.FONTWIDTH)
 If editMode% Then
   m$ = "EDIT"
 Else
   m$ = "VIEW"
 End If
 Text 4, 4, "CLOCK " + m$
 Text 4, 28, "D " + TwoDigit$(setDay%) + "/" + TwoDigit$(setMonth%)
 Text 4, 52, "Y " + Trim$(Str$(setYear%))
 Text 4, 76, "T " + TwoDigit$(setHour%) + ":" + TwoDigit$(setMin%)
 Text 4, 100, "S " + TwoDigit$(setSec%)
 Text 4, 124, "Y RTC SET"
 Text 4, 148, "C EDIT"
 If editMode% Then
     Case 0: Text markX%, 28, "<D"
     Case 1: Text markX%, 28, "<M"
     Case 2: Text markX%, 52, "<Y"
     Case 3: Text markX%, 76, "<H"
     Case 4: Text markX%, 76, "<N"
     Case 5: Text markX%, 100, "<S"
   End Select
 End If
End Sub
Sub DrawFeed(idx%)
 Local m$, en$, markX%
 If feedEnabled%(idx%) Then
   en$ = "ON"
 Else
   en$ = "OFF"
 End If
 If editMode% Then
   m$ = "EDIT"
 Else
   m$ = "VIEW"
 End If
 Text 4, 4, "FEED " + Trim$(Str$(idx%))
 Text 4, 28, "STATE " + en$
 Text 4, 52, "TIME " + TwoDigit$(feedHour%(idx%)) + ":" + TwoDigit$(feedMin%(idx%))
 Text 4, 76, "UNITS " + Trim$(Str$(feedUnits%(idx%)))
 Text 4, 100, "X TEST"
 Text 4, 124, m$
 If editMode% Then
     Case 0: Text markX%, 28, "<E"
     Case 1: Text markX%, 52, "<H"
     Case 2: Text markX%, 52, "<M"
     Case 3: Text markX%, 76, "<U"
   End Select
 End If
End Sub
Function TwoDigit$(v%)
 TwoDigit$ = Right$("0" + Trim$(Str$(v%)), 2)
End Function
Function EnabledCount%()
 Local i%, c%
 c% = 0
   If feedEnabled%(i%) Then Inc c%
 Next i%
 EnabledCount% = c%
End Function
Function ReadEvent%()
 Local aNow%, bNow%, xNow%, yNow%
 Local uNow%, dNow%, lNow%, rNow%, cNow%
 aNow% = SafeBtn%(a)
 bNow% = SafeBtn%(b)
 xNow% = XPressed%()
 yNow% = SafeBtn%(ybtn)
 uNow% = SafeBtn%(up)
 dNow% = SafeBtn%(down)
 lNow% = SafeBtn%(leftpin)
 rNow% = SafeBtn%(rightpin)
 cNow% = SafeBtn%(ctrl)
 ReadEvent% = EV_NONE
 If aNow% And Not prevA% Then
   ReadEvent% = EV_A
 ElseIf bNow% And Not prevB% Then
   ReadEvent% = EV_B
 ElseIf xNow% And Not prevX% Then
   ReadEvent% = EV_X
 ElseIf yNow% And Not prevY% Then
   ReadEvent% = EV_Y
 ElseIf uNow% And Not prevUp% Then
   ReadEvent% = EV_UP
 ElseIf dNow% And Not prevDown% Then
   ReadEvent% = EV_DOWN
 ElseIf lNow% And Not prevLeft% Then
   ReadEvent% = EV_LEFT
 ElseIf rNow% And Not prevRight% Then
   ReadEvent% = EV_RIGHT
 ElseIf cNow% And Not prevCtrl% Then
   ReadEvent% = EV_CTRL
 End If
 prevA% = aNow%
 prevB% = bNow%
 prevX% = xNow%
 prevY% = yNow%
 prevUp% = uNow%
 prevDown% = dNow%
 prevLeft% = lNow%
 prevRight% = rNow%
 prevCtrl% = cNow%
End Function
Function SafeBtn%(pin$)
 Local v%
 v% = 0
 v% = (Pin(pin$) = 0)
 SafeBtn% = v%
End Function
Function SafePin%(pin$)
 Local v%
 v% = 1
 On Error Skip 1
 v% = Pin(pin$)
 SafePin% = v%
End Function
Function XPressed%()
 XPressed% = SafeBtn%(xbtn)
End Function
Edited 2026-03-22 21:33 by matherp
Posted: 09:21pm
22 Mar 2026
circuit
Wonderful and really nicely engineered; I especially liked the "Citroen-style" herringbone gear system.  Just typical of Peter to use a complex (but appropriate) gear system instead of straight gears.  Lucky fish!
Posted: 10:38pm
23 Mar 2026
Click the "Stepper Driver" link on the first line of this thread, then click view details.
  Quote  Description
Name: 4988/8825 stepper motor drive module expansion board
Fixed: 3mm
Hole distance: 1400*1400mil (35.56*35.56mm)
Logic voltage: 5V
Input voltage: 12-30V
Port: Number
Interface: direction, enable, speed
Applicable modules: A4988, DRV8825
Note: Please pay attention to the direction when installing the driver module, otherwise the module will be burnt
This product is only an expansion board, does not include 4988/8825 drive modules
Looking at Peter's first photo a "Drive Module" is plugged into the top of that.
Another seller says:-
  Quote  Description
2 CH Stepper Motor Driver Expansion Board Stepper Drivers Module Modular DRV8825/A4988 for UNO R3 3D Printer
Feature:
On-board DIP switch, you can easily adjust the drive segments
Terminal power connector for easy connection drive power
Compatible with 12 / 24V drive scheme
Suitable for 42 stepper motor drive, for 3D printers and DIY
Specification:
Size: 42 x 42 x 15mm
Fixed: 3mm
Pitch: 1400 x 1400mil (35.56 x 35.56mm)
Logic voltage: 5V
Ports: Digital
Interface: Direction, enable, speed
Applicable module: A4988, DRV8825
Note: Please note the direction when installing the drive module, otherwise it will burn module
Package includes:
1 x 42 Stepper Motor Drive Expansion Board
And for the A4988 module to plug into it:-
  Quote  Description
report
Warm prompt: Dear buyer, Our cheapest transportation services Economic category logistics (SunYou Economic Air Mail ,China Post Ordinary Small Packet Plus ) can be traced only befor it arrive your country,please choose Standard category logistics if you want a full tracking info.
Brief introduction
A4988 is a complete microstepping motor driver with built-in translator for easy operation. This product is available in full, half, 1/4, 1/8 and 1/16 step modes operate bipolar stepper motors, output drive capacity of up to 35 V and ± 2 A. A4988 includes a fixed off-time current regulator, the regulator in slow or mixed decay modes. A4988 converter is the key to the easy implementation. As long as the "step" input inputting one pulse drives the motor one microstep. There are no phase sequence tables, high frequency control lines, or complex interfaces to program. A4988 interface is very suitable for complex microprocessor is unavailable or is overburdened.
In the micro-step operation, A4988 chopping control inside automatically selects the current decay mode (Slow or Mixed). In mixed decay mode, the device is initially set to a fixed downtime in some fast decay, then the rest of the slow decay downtime. Mixed decay current control scheme results in reduced audible motor noise, increased step accuracy, and reduced power consumption. Internal synchronous rectification control circuitry is provided to improve the pulse-width modulation (PWM) operation power consumption. Internal circuit protection includes: thermal shutdown with hysteresis, undervoltage lockout (UVLO), and crossover-current protection. Special power sequencing.
A4988 surface mount QFN package (ES), a size of 5 mm × 5 mm, nominal overall package height of 0.90 mm, with an exposed pad for enhanced thermal dissipation. This package is Pb (suffix-T), with 100% matte tin leadframe plating.
Features and Benefits
· Low RDS (On) Output · Automatic current decay mode detection / selection · Mix with slow current decay modes · Synchronous rectification for low power dissipation · Internal UVLO · Cross-current protection · 3.3 and 5 V compatible logic supply · Thermal shutdown circuitry · Ground fault protection · Load short-circuit protection · Optional step five modes: full, 1/2, 1/4, 1/8 and 1/16
Posted: 10:48pm
23 Mar 2026
dddns
Bigtree has nice drivers
