Forum Index : Microcontroller and PC projects : PicoTab teaser
Posted: 02:27pm
28 May 2026
Posted: 02:29pm
28 May 2026
Posted: 03:29pm
28 May 2026
PhenixRising
Suggest Bsp instead of BS unless it's a shortcut to my code
Posted: 04:53pm
28 May 2026
No number keys?
Function keys after pressing Fn I asume?
But it looks Nice and compact. Could replace your picocalc design when touch works well enough.
If you need not redraw the keys often you could even put real artwork. Maybe you can find hires scans of Casio FX720 or similar.
Edited 2026-05-29 03:00 by Volhout
Posted: 05:02pm
28 May 2026
  Quote  If you need not redraw the keys often you could even put real artwork.
Problem is the keypad scales to the resolution so it will even work in 320x240, numbers are on the sym(bol) toggle. I'm just deciding whether these should toggle shift, sym and ctrl should toggle like a lot of on-screen keyboards or use multi-touch.
PS. The final S/W will be a bluetooth host/usb/hdmi build so you can select between the onscreen keyboard, physically connected usb keyboard or a bluetooth keyboard. S/W for this will be released next week. I'm assuming any of the cheap HDMI 1024x600 screens 7" or 10" will work as long as they have the USB touch capability. The frequency will be fixed (252MHz) which should allow me to run 1024x600, 512x300, 640x480, 320x240 all as modes available without reboot
Edited 2026-05-29 03:09 by matherp
Posted: 09:22am
29 May 2026
Videos:
https://youtu.be/lrpX17DAZkQ
https://youtu.be/8BSQiHhAZMc
Demo running 1024x600 with font 3. Switching to mode 3 for the gui demo (512x300).
Apologies for the dithering and video quality
Edited 2026-05-29 19:34 by matherp
Posted: 04:04pm
29 May 2026
Amnesie
Peter,
this is so cool! Now it is even more "stand-alone" and self stustained! Not even a real keyboard needed! Wow!
Greetings
Daniel
Posted: 04:15pm
29 May 2026
Peter63
Jepp,
