Forum Index : Microcontroller and PC projects : Pico Gamer
   Page 1 of 4
Posted: 01:52am
20 Mar 2024
Geoffg
The April issue of Silicon Chip magazine is hitting the streets about now and it features the Pico Gamer.  This is a game playing console similar to the Nintendo Game Boy Advance but using the PicoMite.
It is based on thwill’s concept for the Game*Mite but with a 3D printed case, a different circuit and different firmware.  It is however software compatible, so games written for the Game*Mite will run unchanged on the Pico Gamer and vice versa.  The default firmware comes with most games available on the Game*Mite (with the authors' permission) plus my versions of Pac Man and Tetris.  Adding more games is easy, just copy them to the PicoMite’s drive A: and they will immediately appear in the menu.
An important component is the 3D printed case which can be made by many companies in China, typically costing less than US$20.  The case has a smooth rounded feel which sits well in the hands but it’s most important feature is that it holds the switch buttons steady – without this buttons have too much side to side “wobble” which ruins the game playing experience.  The design files are on my website ready to be sent to China.
A full description plus all the construction data and firmware is on my website at: http://geoffg.net/picogamer.html.
You can watch a short video describing the Pico Gamer here: https://youtu.be/Koi4JSnmtNg
Silicon Chip has made a video demonstrating the games: https://www.siliconchip.com.au/Videos/
Silicon Chip is selling full kits plus some components (PCB, case, etc) here: https://www.siliconchip.com.au/Shop/?article=16207
If you are going to build it you should also consider purchasing an electronic copy of the April magazine (AU$10) as it goes into more detail.  The online and downloadable versions of the April issue will be available from 28th March here: https://www.siliconchip.com.au/
I have a web page describing the design of the 3D printed case here: http://geoffg.net/3D_Printed_Cases.html
Credit to thwill for thinking up the Game*Mite.  It is a great concept.
Geoff
Edited 2024-03-20 16:51 by Geoffg
Posted: 07:55am
20 Mar 2024
Congratulations wit the new Pico Gamer !!
I looks very nice. And a good thing that you could keep it compatible with the Game*Mite. That will definitly help with growing a larger game base.
I also read your text about designing the case. That is something on my wish list for the comming year.
Posted: 07:59am
20 Mar 2024
Looks great - congrats!
Posted: 09:47am
20 Mar 2024
Very pretty.
"Imitation is the sincerest form of flattery ..."
- Oscar Wilde
Posted: 10:05am
20 Mar 2024
Sometimes I think 3D printing is a curse. Probably one of the worst that could be imagined for hobbyists. :(
Posted: 10:26am
20 Mar 2024
  Mixtel90 said  Sometimes I think 3D printing is a curse. Probably one of the worst that could be imagined for hobbyists. :(
I wonder about that too. Not only do we have to be programmers and electronic engineers (or pretend to be in my case) we also have to be mechanical engineers and learn to drive 3D CAD ... there aren't enough hours in the day.
It still looks great though .
Edited 2024-03-20 20:27 by thwill
Posted: 11:00am
20 Mar 2024
Martin H.
When I realized in 2016 that I had to change jobs again, I started working with 3d printing, as measuring/controlling/regulating was also part of my training, which I had completed in 1988. Just to see how it had developed over time. So for me, the printers were more self-study of the structure and technology than the actual 3D printing. That's why I was only marginally involved in creating 3D objects. And why I only use Tinkercad's online CAD and haven't yet found any motivation to familiarize myself with Fusion360.
Martin
Posted: 11:42am
20 Mar 2024
My CAD training was all 2D. I did occasionally attempt 3D, but I found it incredibly difficult. I'm not sure that my ancient brain ever got the 3D spacial system upgrade.
A custom case is great. It makes the use of buttons etc. so much easier. It also looks great. I've no problems with any of that. You can even use rubber buttons and printed contacts instead of tactile switches. But where do you stop? At what point does a hobbyist build become a commercial prototype?
Personally, I will only design around commercially available enclosures (or none). I don't have a problem with my designs looking home-made because that's what they are. :) Standard enclosures look expensive at first, but they aren't if you compare them to an equally complex 3D printed design. If you already have a good 3D printer and suitable filament then the cost reduces, but you still end up with a case that needs a lot of sanding and finishing if you want it to match the quality of most commercial enclosures.
Just a bit of a moan from someone brought up chassis-bashing aluminium sheet for valve amps and radios. :)  Times move on!
Posted: 01:12pm
20 Mar 2024
Geoffg
The thing that surprised me about the commercial Stereolithography (SLA) process was how perfectly smooth the finish was, no "lot of sanding and finishing" was required.  The result was also quite strong with no warping.  And this was for something that cost just US$17.50 for a one off print run.
Creating a 3D design does not require any special skills.  You start with a solid cube and then cut holes, extrude parts, bevel corners, etc until you get what you want.  The complex part is learning the software package but I would rate it as similar to the effort required when I first used a PCB design app.
I too grew up bending aluminium to make enclosures and for something like a PicoMite VGA design an ordinary plastic box is fine.  But the Pico Gamer demanded something much more sophisticated.
Now that I have put the time into learning the Blender app I'm going to be using more custom boxes... it is so easy.
Geoff
Posted: 01:17pm
20 Mar 2024
knivd
Looks great!
Posted: 01:26pm
20 Mar 2024
Martin H.
Geoff
ask a pianist if it is difficult to play the piano.
everything is easy for those who can do it
good Work geoff
Posted: 01:27pm
20 Mar 2024
Geoff
Just one comment on your website article
You state that the firmware can be upgraded. But 5.09 causes a complete reset of the flash (and has to) so the A: drive will be cleared. Tom has a mechanism of rebuilding the Game*Mite from the source programs. You may need something similar as new games may start to rely on 5.09 capabilities. Otherwise users will be locked into an older version of the firmware.
Posted: 01:45pm
20 Mar 2024
  matherp said  Tom has a mechanism of rebuilding the Game*Mite from the source programs. You may need something similar as new games may start to rely on 5.09 capabilities. Otherwise users will be locked into an older version of the firmware.
I believe Peter is referring to the instructions in "Appendix C - Alternative firmware and software installation instructions - Installing the GameMite software" of the Game*Mite User Manual.
Also note that the pieces of my software included in the Pico Gamer firmware do not appear to be the very latest versions:
https://github.com/thwill1000/mmbasic-gamemite/releases/download/v1.2.0/GameMite-1.2.0-alternative.zip
... and are all missing the MIT license line with my copyright.
Posted: 02:17pm
20 Mar 2024
Chopperp
@ Geoff
Is it possible to have a version of the lid with the lettering either recessed into the top or omitted altogether rather than sitting out proud so it can be printed face down flat with a standard printer if desired.
Your comments on printing rounded corners etc lead me to search & then find this for OpenSCAD.
Got it working OK on a test box.
Brian
Posted: 06:11pm
20 Mar 2024
LeoNicolas
Nice project.
I'm looking forward to have Knightmare running on it
Posted: 06:42pm
20 Mar 2024
Amnesie
Haha! For me, 3D printing is just ugly. Yeah there are methods to "clean" all those filament stuff but honestly, for me it is just a piece of plastic toy feeling to it. I much prefer proper CNC milling of steel, aluminium etc. Laser becomes cheaper and cheaper, too.
I really understand that it also has some benefits, it boosts creativity und a lot of people tinker with it and learn something on the way - epecially to design and work with all those CAD software.
But in the end it is an ugly piece of plastic. Often I see projects even gooped up with hot glue, too.
Awful, just awful.
Posted: 07:20pm
20 Mar 2024
knivd
One additional comment from me. I stopped playing portable gaming consoles long time ago in line with the prevailing trend to have the movement controls on the left hand.
Maybe there could be *one* exception where it is on the right?
Posted: 07:20pm
20 Mar 2024
stanleyella
guess which one I 3D printed. ha ha
ebay flatpack build yourself £80, it's not got auto levelling and you got to flash a sd card then transfer that to sd card slot on printer but 3 years ago it was ok for the money.
Posted: 01:15am
21 Mar 2024
SimpleSafeName
Awful, just awful.
It's hard to beat resin for the quality of its finish. There are a myriad of issues with resin, but the quality of its finish is not on that list.
Posted: 01:19am
21 Mar 2024
SimpleSafeName
  Chopperp said  @ Geoff
Brian
I was going to suggest OpenSCAD. You can easily import Geoffg's STL files (thanks for providing them Geoff!) and then remove the printing.
   Page 1 of 4
