Forum Index : Microcontroller and PC projects : Silicon Chip Pico 2 Computer (April 2025 )
| Page 1 of 2 |
I see Silicon Chip has an article (April 2025 copy) " PICO/2/Computer Design and firmware by Peter Mather Words and MMBasic by Geoff Graham " Presumably that is the PicoMiteHDMIUSB motherboard reference design here + following pages ? Are there any changes ? The article says two pre-populated pcbs as a kit with spares can be ordered from their supplier in China for about $150 AUD. Edited 2025-03-27 12:30 by zeitfest |
Yes, the magazine project is the same as Peter's PicoMiteHDMIUSB motherboard reference design. As the article says, you can buy two assembled versions from JLCPCB for approx Aust$150 or, as I understand it, Silicon Chip will be selling the assembled version individually (I'm not sure of the cost). There are no changes from Peter's original design. But since that version Peter has made some further changes as detailed in that thread. Geoff Edited 2025-03-28 08:06 by Geoffg |
They also have the bare PCB for $5 + P&P. |
They are selling! When I bought one yesterday there were 15 available. Now there are 7. Bill |
G'day All, Checked Tuesday they had 20 available Ordered mine on Friday, they had 4 left Just checked and only one left Hopefully being this popular they will get another batch made. I'd get in quick if you are procrastinating.... Regards, Lyle. |
I am wondering if SC is doing a pico 2 W or 2350B project already, given the three month publication lag, which would then supersede it . |
I just received mine today. Assembly was straight-forward. However, I might have a bad RP2350. Getting a "Device Descriptor Request Failed" message from Windows 11 Device Manager when trying to upload the firmware. Probably should have checked it before soldering it to the motherboard. I have a stand-alone RP2350 that works fine. David |
Have you removed the links on CN2? You can't upload with them in place |
Yes, the jumpers are removed. |
Hi, I also purchased a pre assembled board from SC for $81. RP23500B chip already soldered in. I used the firmware PicoMiteHDMIUSBV6.00.01.uf2 from SC which worked ok. Also set the DVDD volts to 0.1V above the 1.0V as stated. The only problem i had was there was no HDMI output. Console was OK. Eventually tracked it down to Setting OPTION HDMI PINS 1, 3, 5, 7 The wiring of the new on board to the HDMI was different from the old board with the plugin pico. Don't know if there will be a revised firmware for newbies like me. At least i have found this forum which is great. Peter |
On the board, there should be a OPTION RESET command silkscreened. If you execute this at the command prompt it should fully configure the board for you. Note that for higher HDMI resolutions you will need to set DVDD to 1.3V. measure between the DVDD test point and any convenient ground (SDcard socket cover) |
Thanks for the reply. Yes I tried OPTION RESET HDMIUSBI2S and it wouldn't accept the command. It replied invalid board for this firmware. I tried OPTION RESET HDMIUSB and it worked but did not show or set the HDMI pin option. After i entered it manually it worked. May have to get an updated firmware. I tried PicoMiteHDMIUSBV6.00.03.uf2 from https://geoffg.net/picomitevga.html but it did not work (heartbeat LED did not start after loading). May have to look around for a more compatible version on the forum Yes i did also find i had to slightly increase the DVDD voltage when using 1024 x 768 the pico was stopping without it. just in the process of getting the SD card to work and it looks like i have to change the GPIO pins from 22, 26, 27, 28 to 29, 31, 30, 32. I found the schematic which helps greatly. Thanks for the tips. Peter. |
Please post a picture of the board so I can help further. |
November SC has the updated version (I2S audio) fully assembled PCB $AU90, front and back panels $AU7.50 + P&P. |
Hopefully the pics are OK. Also the following is the options list > option list PicoMiteHDMI MMBasic USB RP2350B Edition V6.00.01 OPTION SERIAL CONSOLE COM2,GP8,GP9 OPTION SYSTEM I2C GP20,GP21 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION KEYBOARD US OPTION PICO OFF OPTION CPUSPEED (KHz) 315000 OPTION HDMI PINS 1, 3, 5, 7 OPTION SDCARD GP29, GP31, GP30, GP32 OPTION AUDIO GP10,GP11', ON PWM CHANNEL 5 OPTION RTC AUTO ENABLE OPTION MODBUFF ENABLE 192 OPTION PLATFORM HDMIUSB > Hope that helps. Cheers Peter |
Upgrade to a later version of the software. V6.01.00RC4 that I have just posted seems robust so try that. Then do the OPTION RESET HDMIUSBI2S and you should get OPTION SERIAL CONSOLE COM2,GP8,GP9 OPTION SYSTEM I2C GP20,GP21 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION KEYBOARD US OPTION PICO OFF OPTION RESOLUTION 640x480 @ 252000KHz OPTION DISPLAY 24, 80 OPTION HDMI PINS 1, 3, 5, 7 OPTION SDCARD GP29, GP30, GP31, GP32 OPTION AUDIO I2S GP10,GP22', ON PWM CHANNEL 11 OPTION RTC AUTO ENABLE OPTION COUNT GP0,GP1,GP2,GP3 OPTION MODBUFF ENABLE 512 OPTION PLATFORM HDMIUSBI2S OPTION HEARTBEAT PIN GP25 |
Awesome thanks, could not find V6.01.00RC4 but found V6.01.00RC5 unzipped and uploaded PicoMiteHDMIUSBV6.01.00RC5.uf2 OK. Noticed the heartbeat led did not start but the console session worked after dip switched restored and restarted. did the OPTION RESET HDMIUSBI2S and WOW Yes all the following happened. Only issue is the USB devices will not work. No green LEDS and keyboard not working. SD CARD works though which is a bonus. PicoMiteHDMI MMBasic USB RP2350B Edition V6.01.00RC5 OPTION SERIAL CONSOLE COM2,GP8,GP9 OPTION SYSTEM I2C GP20,GP21 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION KEYBOARD US OPTION PICO OFF OPTION RESOLUTION 640x480 @ 252000KHz OPTION DISPLAY 24, 80 OPTION HDMI PINS 1, 3, 5, 7 OPTION SDCARD GP29, GP30, GP31, GP32 OPTION AUDIO I2S GP10,GP22', ON PWM CHANNEL 11 OPTION RTC AUTO ENABLE OPTION COUNT GP0,GP1,GP2,GP3 OPTION MODBUFF ENABLE 512 OPTION PLATFORM HDMIUSBI2S OPTION HEARTBEAT PIN GP25 > |
Just found the USB problem. Programming cable was still plugged in. Now All good Much appreciated. |
Make sure you have unplugged the micro-usb and plugged in a USB-C to provide power. Also make sure the switches are both set to on |
I just ordered 5 boards (the latest PicoMiteHDMIUSB design from Peter) from JLCPCB. I don't need 5, so I would be happy to give 2-3 away for the cost price (~40 €) to people in Germany/ the EU. |
| Page 1 of 2 |
