Forum Index : Microcontroller and PC projects : MMEdit V5.3
Posted: 11:56pm
03 Apr 2025
I have released MMEdit5 V5.3.0
The syntax files need further updating. That will happen when time permits.
Changes:
MMCC random window closing hopefully fixed.
Bug in MMCC abort file transfer fixed.
MMEdit now highlights all occurrences of current word.
Picomite PIO code included in syntax
Numerous small bugs squashed.
It is available from
https://geoffg.net/mmedit.html
Thanks to Geoff for providing the hosting.
The only download is a single ZIP which contains:
MMEdit5_32_64.exe
If you are installing on a 64bit OS, the 64bit will be installed
otherwise the 32bit version is used. Not for XP.
MMedit5_XP_portable.zip
Extract to a writeable location. OK for XP and later.
The portable version writes to the application subdirectories only.
MMedit5.tar.gz
Suitable for Ubuntu 20.4 any probably later.
Posted: 12:11am
04 Apr 2025
PeteCotton
Fantastic. I will give it a try this weekend!
Thank you!
Posted: 12:37am
04 Apr 2025
Supertech
Thank You TJ     & Geoff for hosting TJ mmedit 👏 as it should be given toward your emence mmedit efforts.
You may not realize that it is very good in its own right of existence and from your skill invention that I for one very much appreciate, and that needs to be acknowledged!
There are others on this forum very willing to help (I can't), please, if you need it, take it, as they love use mmedit too.
Warm regards as we head into colder months TJ....
Take care.
Posted: 04:00am
04 Apr 2025
PeteCotton
  TassyJim said  I have released MMEdit5 V5.3.0
I've just had a quick play with it and it seems to work great (still).
I am a tiny bit disappointed that it no longer Transafer's files, and we have to settle for good old fashioned transfers  .
But all joking aside, once again thank you for this incredible piece of software. It truly brings the CMM2 to a whole new level, and is an absolute lifesaver on big projects.
Posted: 06:31am
04 Apr 2025
Hi Jim,
Tested with picomite on Ubuntu 20.04. All seems to work okay. Thanks for the highlighting of the new PIO assembler instructions. Also transferring big files works fine.
Great work !!
Suggestions:
If I may make 1 suggestion for PicoMite VGA/HDMI: In MMCC filemanager, when you open the filemanager, send "MODE 1" before you start the interaction with FILES and XMODEM.
When the VGA mite is in mode 2 (40 columns width) all filenames are wrapped to the next line.
MMCC Similar for "Send Listing To Editor", lines are wrapped with terminal (screen) width. If you would send "MODE 1:FONT 8" prior to the transfer no line wrapping would occur.
Edited 2025-04-04 17:19 by Volhout
Posted: 01:48pm
04 Apr 2025
ville56
@Vollhout,
MODE 1 FONT 8 is probably not a good idea ...
> option list
PicoMiteHDMI MMBasic RP2350B Edition V6.00.02RC9
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION PICO OFF
OPTION CPUSPEED (KHz) 324000
OPTION RESOLUTION 1024x768
OPTION DISPLAY 128, 0
OPTION HDMI PINS  1, 3, 7, 5
OPTION MODBUFF ENABLE  192
OPTION PLATFORM OLIMEX
OPTION DEFAULT FONT 3, 1
OPTION PSRAM PIN GP47
which ends up in a listing with is only 1 column wide. This is at least the situation with HDMI. Up to FONT 7 it seems to work, at lest it gives
OPTION DISPLAY 96, 170
Don't know if this is a bug in the firmware or intended behavior.
Gerald
Posted: 02:03pm
04 Apr 2025
Hi Gerald,
In my VGA (RP2040 VGA PS2) unit MODE 1: FONT 8 results in DISPLAY 80,160.
Maybe this is caused by the difference in resolution. Mine is 640x480, yours is 1024x768.
Posted: 04:07pm
04 Apr 2025
ville56
  Volhout said  Hi Gerald,
yes, quite possible. But i don't know how the firmware calculates the DISPLAY settings from the different parameters that may influenct them. The intersteing part is that with your lower resolution the resulting display setting makes more sense ....
Posted: 06:12pm
04 Apr 2025
It's a bug - will fix. Option.Width is defined as a char = 0-255. 1024/4=256 oops.
Edited 2025-04-05 04:12 by matherp
Posted: 09:01pm
04 Apr 2025
  Volhout said
Suggestions:
MMCC does change to MODE 1 but the decision if to change needs some work to allow for the new modes.
I don't have a working VGA or HDMI unit to test with and even if I did, I am well behind the current thinking.
I will get there eventually.
Posted: 09:28pm
04 Apr 2025
Andrew_G
Jim,
May I add my thanks to you for MMEdit/MMCC, TFTColour, FontTweak etc.(?).
It is amazing how you keep up-to-date (almost) with all the changes PLUS adding enhancements of your own.
Cheers,
Andrew
Posted: 02:26am
05 Apr 2025
Some of the changes to MMEdit need a bit of explanation.
There are 3 important text files in the data folder.
They are TAB separated lists best viewed and edited in a spreadsheet.
kw_list.txt
  Quote  ; This file (hopefully) contains the full list of keywords for all known variants of MMBasic. It is used by MMEDit and the standalone syntax lookup program.
;Blank lines and  lines starting with ; are ignored
; The format is TAB separated and is best edited in a spreadsheet program that handles text files.
; quotes are likely to be added around fields that contain a comma. This is OK and will be removed on loading
; The fields are keyword - keywords and parameters in upper case.
; the html column is the link to help pages in MMEdit. Not applicable when used standalone.
; syntax columns lists the appropriate syntax for the search keyword/phrase.
; the remaining columns are used to indicate if the keyword syntax is used in each variant. Additional columns can be added
; keyword fields starting with ZZZ are for general parameters which are used for multiple commands
I have a lot more to do to complete the list and when finished, Most syntax files can be regenerated from this file. This will make updating easier.
devicelist.txt
  Quote  ; New devices can be added and mapped to an existing syntax or a newly created syntax.
; If you add a new syntax, the file 'devicetypes.txt' will also need editing
; Lines starting with ; are comments and the remaining lines are TAB delimited
; blank lines are ignored.
; MM.DEVICE$ Syntax
ARMmite F407 ARMmite
Armmite F407xGT ARMmite
ARMmite H7 ARMmite
ARMmite L4 ARMmite
Colour Maximite maximite
Colour Maximite 2 CMM2
Colour Maximite 2 G2 CMM2
DOS DOS
DuinoMite maximite
Generic PIC32 maximite
Maximite maximite
Micromite micromite
Micromite Extreme micromite+
Micromite MkII micromite
Micromite Plus micromite+
MMBasic for Linux MMB4W
MMBasic for Windows MMB4W
PicoMite picomite
PicoMite RP2350A picomite
PicoMite RP2350B picomite
PicoMiteHDMI RP2350A picomiteVGA_HDMI
PicoMiteHDMI RP2350B picomiteVGA_HDMI
PicoMiteHDMIUSB RP2350A picomiteVGA_HDMI
PicoMiteHDMIUSB RP2350B picomiteVGA_HDMI
PicoMiteVGA picomiteVGA_HDMI
PicoMiteVGA RP2350A picomiteVGA_HDMI
PicoMiteVGA RP2350B picomiteVGA_HDMI
PicoMiteVGAUSB picomiteVGA_HDMI
PicoMiteVGAUSB RP2350A picomiteVGA_HDMI
PicoMiteVGAUSB RP2350B picomiteVGA_HDMI
WebMite webmite
WebMite RP2350A webmite
ATTiny85 ATTiny85
This reduces the number of syntax files to a manageable number. The armmites deserve a couple of types and it is not ideal but saves me a lot of work.
I have probably missed some device types.
Once we have the "family" names, the 3rd file devicetypes.txt is used to assign the capabilities of each type. This is needed for MMCC and the file manager.
  Quote  ; devicetypes.txt  Edit this file and devicelist.txt to add new devices.
; lines starting with ; are comments
; fields are separated by TAB to make editing in spreadsheet easier.
; mmDevice The string returned by PRINT mm.device$
; Fname The 'family' name grouping devices that have identical commands for file management.
; autostart The command to start saving a program
; autoend The command used to indicate the end of a program load - usually ^C
; autoName The CMM2 series require a file name when doing an autosave
; drives The number of 'drives' Usually 1 or 2 (A: and B:)
; xmName superseded
; filesCMD Files command usually 'files' except on the CMM2 which uses 'ls'
; filesAll superseded. leave at zero
; listAll LIST ALL will list the full program without waiting at each page
; flash The device has the ability to save programs in flash memory slots - picomite etc
; fnstart The character position of the file name with a files command
;Fname autostart autoend autoName drives xmName filesCMD filesAll listAll flash fnstart
ARMmite autosave \026 0 1 3 files 0 1 0 13
ATTiny85 0 0 0 0 0 0 0
CMM2 autosave \027[12~ 1 1 3 ls 0 1 0 30
command 0 1 0 files 0 1 0 0
maximite auto \003 0 2 2 files 0 0 0 0
micromite autosave \026 0 0 1 0 1 0 0
micromite+ autosave \026 0 1 3 files 0 1 0 0
picomite autosave \026 0 2 1 files 0 1 1 30
picomiteVGA_HDMI autosave \026 0 2 1 files 0 1 1 30
webmite autosave \026 0 2 1 files 0 1 1 30
There were a few hard-coded types in MMCC which I will correct in a day or two.
That will fix the failure to switch to MODE 1 when starting the file manager.
Posted: 04:01am
05 Apr 2025
javavi
Jim,
Is it possible to create such a font so that your MMCC terminal could correctly display all the symbols of the PicoMite VGA/HDMI FONT 1 encoding?
And if such a font already exists, how can it be configured?
Thank you.
Posted: 04:48am
05 Apr 2025
  Quote  Is it possible to create such a font so that your MMCC terminal could correctly display all the symbols of the PicoMite VGA/HDMI FONT 1 encoding?
Possible, Yes.
Easy, No
I haven't had much experience creating TrueType fonts but you could start with a font that has the line drawing characters.
Ubuntu Mono is a good start as I think it is not under copyright.
If you aren't concerned with copyright, Courier New has more of the other characters.
Once you have chosen your font to copy,
move the other characters that exist in the font to the correct character position for the MMfont. A lot of the MMfont characters are in many fonts, just not in the correct position.
You can then search the unicode library looking for the rest of the characters. Some will not be found.
Then you are left with the characters that need to be drawn by hand.
Easier would be to create a bitmap font but it would need a number of sizes to be of much use.
MMCC allows any TT font and Windows style bitmap fonts.
Setup menu
Terminal font...
Most other terminal programs let you change font.
FontForge is one Windows font program. It works but I don't like the interface much.
Posted: 05:25pm
06 Apr 2025
Xian
Hi Jim, (@TassyJim)
thanks for the update. I have only discovered the app recently and already love it! Of course i have not yet discovered everything.
Best regards,
Christian
Posted: 03:46pm
09 Apr 2025
pwillard
SIDEBAR: I have extensive experience with TTF font creation and own commercial font creation software, but I have little experience with the VGA/HDMI fonts.
Posted: 04:07pm
09 Apr 2025
javavi
  pwillard said  SIDEBAR: I have extensive experience with TTF font creation and own commercial font creation software, but I have little experience with the VGA/HDMI fonts.
Hi pwillard,
We need a font for a Windows computer with the same character encoding as PicoMite VGA/HDMI. If we have such a font, it can be selected as a font in the terminal program for the correct display of PicoMite VGA/HDMI program characters and on the PC console.
Posted: 04:51pm
09 Apr 2025
pwillard
Well, the glyph mapping would be a concern beyond the normal letter/number/symbol assignments. (meaning anything after the 'tilde' character.)
Though, this does have a lot of overlap with the DOS 437 font.
Edited 2025-04-10 02:53 by pwillard
Posted: 10:21am
11 Apr 2025
circuit
Just an expression of great gratitude for all the work you have put in over the years in creating this software.  Hardly a day goes by without me using MMEdit on one project or another.
I, like many others, really appreciate this stalwart of the MicroMite family which, I suspect, we usually rather take for granted, because it simply just does what it says on the tin - perfectly! It is functional, logical in design and reliable.
This updated edition follows in the line of many years of your excellent software authorship.
Again, with great respect for your talent, thank you.
Posted: 10:00am
12 Apr 2025
javavi
Installing the Perfect_DOS_VGA_437 font partially solves the problem of displaying the pseudographics symbols of the PicoMite encoding.
For some reason the font is displayed with a line break
Perfect DOS VGA 437.zip
