Forum Index : Microcontroller and PC projects : The "Official" Raspberry Pi SD card....
Posted: 11:33am
27 Apr 2025
I see that RP produce their own special SD card for use in their PI's.
I am about to get a couple for experimenting on my new PI5(still in transit), but worndering if they are worth the hype?
I've always just used bog-standard SD cards on earlier PI's, but the PI5 is a bit of a new beast.  They are very cheap at $6 for the 32GB one, so I'll probably just get these, but I would be interested to hear from any other members on this.
Official RP SD card....
Posted: 05:03pm
27 Apr 2025
Peter63
I can only recommend these. I immediately noticed a difference in speed, as I saved and retrieved data from these. Have been using these for a while now and am very satisfied.
Peter63
Posted: 05:22pm
27 Apr 2025
  Quote  I am about to get a couple for experimenting on my new PI5(still in transit), but worndering if they are worth the hype?
On the Pi5 use an NVMe M2 SSD; massively faster than any SDcard. There are various nice boxes around for the Pi5 with all the wiring for the SSD to connect to the PCIe port on the Pi5. I use the Argon Neo M.2 NVMe PCIe.
Posted: 08:47pm
27 Apr 2025
toml_12953
  Grogster said  I see that RP produce their own special SD card for use in their PI's.
I have the 64K variant. It's a good card but no better than many other good quality cards out there. If you can get it at a price comparable to a good SanDisk, let's say, then go for it. Just don't pay a premium for the label.
Edited 2025-04-28 06:50 by toml_12953
Posted: 12:27am
28 Apr 2025
Thanks for that feedback.
I do have a case coming from WS - they do some nice cases too.
The one I got was option "C" here: (internal PCB for M.2 SSD)
CASE...
I have to read up about how you get the PI5 to boot from the M.2 SATA rather then the SD card, but I expect it can't be that hard....
Posted: 07:05am
28 Apr 2025
Looks like a nice case but its HUGE. At least double the size of the bare Pi5.
Posted: 11:39am
29 Apr 2025
Yep, and that's one of the reasons I like it.
I have a burning hate of those PI cases that try to squeeze everything into the smallest possible space.  Having a little room to move, makes the assembly process much easier and less stressful.
Don't get me wrong - there is a time and place for when it needs to be as small as possible, but in my build, that is not the case(pardon the pun!) - I'll hopefully be replacing a full-size PC desktop case with this thing, which is only a fraction of THAT size.
Edited 2025-04-29 21:49 by Grogster
Posted: 05:14pm
29 Apr 2025
toml_12953
  Grogster said  Thanks for that feedback.
CASE...
I boot from an official 512GB Raspberry Pi M.2 card. As long as you have a hat for connecting it, it's simple to set up. Heck, even I did it!
Just prepare the card with Raspberry Pi Imager then go into the Raspberry Pi setup program and change the boot device. Reboot and enjoy the higher speed. There's no need to manually edit configuration files anymore.
Posted: 01:56am
30 Apr 2025
Awesome!
Sounds like a breeze.
