Posted: 04:24pm 27 Jul 2025 Copy link to clipboard
Mixtel90 Guru
TCA9548A Modules are very cheap on AE. Basically, it splits a single I2C port into eight. You send it the board's address and the number of the port you want access to. It then connects the ports together until a different one is selected. It's more than that though. All the ports are open drain (like they should be) so you can add your own pullups. So you can have a mixture of 5V and 3V3 I2C ports. The module can be powered from 1V8 to 5V and the level shifting is automatic and invisible, just connect the input port pullups to your system voltage. Looks interesting, I might get one to play with.
Posted: 05:09pm 27 Jul 2025 Copy link to clipboard
stanleyella Guru
https://www.ebay.co.uk/itm/335701328995 why do we need it when you can connect multiple i2c anyway?
Posted: 06:22pm 27 Jul 2025 Copy link to clipboard
Mixtel90 Guru
You can only connect multiple devices if they all have different addresses. The WII game controllers only have one or possibly two addresses. If you want three on the same machine (as on the later CMM2) you can't unless you have three I2C ports. Using this module you could have eight on a single I2C port of a Pico. And another eight on the other. :)
Note that you could also, if you level shift to get the I2C connection up to 5V from the Pico, mix 5V, 3.3V and 1.8V I2C devices on the eight I2C lines. I don't think it supports 3V3 output with 3V3 input, unfortunately, I think you have to level shift. I'm still investigating the data sheet.
Oh, and you can get five for that price on AE. :)
Posted: 06:50pm 27 Jul 2025 Copy link to clipboard
Volhout Guru
Yes that works. 3v3 in and 3v3 out in any mix. We use them with I2C devices a lot. Specifically those that have a default I2C address that can be re-programmed in sw. We always keep them on default since there is no surprise if you ever need to replace one.
Example: the melexis thermal cameras, like MLX90614.
Volhou
Posted: 01:53pm 28 Jul 2025 Copy link to clipboard
PhenixRising Guru
Is there such an animal for UART?
Posted: 02:06pm 28 Jul 2025 Copy link to clipboard
Posted: 07:45pm 28 Jul 2025 Copy link to clipboard
stanleyella Guru
I ordered a TCA9548A. I will probably ask for help cos don't use i2c much. V53L0X, MCP23017, ssd1306
Posted: 06:49am 29 Jul 2025 Copy link to clipboard
Mixtel90 Guru
The info for using I2C is in the manual, Appendix B, and it's pretty good! It's not much more difficult than using a COM port. The main thing is that it's up to you to create the protocol that you want for a particular job.
The module is easy to work with. If the address pins are all grounded it's address is &h70 The individual channels are then &h0 to &h7 so you send &H70 for the first, &h71 for the second, &h72 for the third etc. There are no other registers in it. Once you have selected the channel like that you just use the I2C as normal to talk to the device that you want.
I found that, for me, the best way to play was to use two Picomites as master and slave. Set the slave up to print whatever it gets over I2C then send it stuff from the master. That way you have full control over setting the number of bytes sent and received and how they are handled - and how the 7-bit addressing system works! .
Posted: 03:31pm 29 Jul 2025 Copy link to clipboard
stanleyella Guru
dunno if a0 to a2 are hardwired or go to gp pins.
Posted: 03:35pm 29 Jul 2025 Copy link to clipboard
Volhout Guru
Easy, connect the module to your desired I2C bus, and run an I2C scan. From the address found you know the wiring.
Posted: 07:39pm 29 Jul 2025 Copy link to clipboard
stanleyella Guru
this is just the devices i2c addresses itself which can be 0x70 to 0x77. mines in the post. solder it up and post
Posted: 07:13pm 31 Jul 2025 Copy link to clipboard
stanleyella Guru
I don't get this. the tca has address so writing 2 bytes to it to set up a device and the register so what channel conected to for each device
Posted: 09:21pm 31 Jul 2025 Copy link to clipboard
Mixtel90 Guru
It's easy enough. You are sending one byte (B7-B0) to the address of the TCA.
The TCA address is [0]1110[A2][A1][A0] - that's 70 to 77 depending on the address pins. The next bit is 0 to read from it or 1 to write to it. You are selecting a device, so this will be a 1 so that you can write to the device select strobe. The next 8 bits after the ACK (which is automatic) are the device strobes, one per I2C port. So a 1 on B0 will select port 0, a 1 on B1 will select port 1 etc. All non-used ports have their strobes set to 0.
It's possible to select two I2C ports at the same time (not sensible for many devices) by setting both their strobe bits high. . Edited 2025-08-01 07:23 by Mixtel90
Posted: 08:29pm 01 Aug 2025 Copy link to clipboard
stanleyella Guru
thanks Mick. wish I hadn't bought it. thought it was pointless unless connecting devices with same address.
Posted: 08:52pm 01 Aug 2025 Copy link to clipboard
Volhout Guru
It also level shifts. If you have 5v serial lcd or pcf8574 io expanders this is usefull.
Posted: 09:00pm 01 Aug 2025 Copy link to clipboard
Mixtel90 Guru
That's what it's intended for. Of course, it doesn't care what the addresses of the I2C devices are. You can also mix 3V3 and 5V I2C devices without any level shifters - the Pico sees them all as 3V3.
Confusingly, there are two "standards" (Qwiic and Stemma QT) that use I2C on the same 1mm pitch JST connector but with different coloured wires. One is 3V3 and the other is 5V. Using one of these modules and a link system would let you mix and match any of either sort of module. :)
