Posted: 11:38am 15 Sep 2025
Copy link to clipboard |
Volhout Guru
Phenix, DC drift is not always specifically specified, but look at below datasheet. Typical 16 bit I2S DAC UDA1334  DC accuracy is +/-10% (0.5V+/-50mV), relates to 3.5bits DC DAC. If that is sufficient, then you can use it as a DAC in your loop. That is why it is normal to AC-couple AUDIO DAC outputs. DC drifts all over the place. Volhout |
