Forum Index : Microcontroller and PC projects : Waveshare RP2350-PiZero , dvi out compatible? Picomite and MIDI commun
Posted: 05:30pm
01 Feb 2026
amiga
Hi ,
i'm building several modules based on 'europi' modules .
Instead using analog components (i'm not an electro man) i try to use only digital components (digital encoder ky-040) input/output jack are used only as patch insertion detection .
All modules act only as hmi inpu/output and communication inter-modules is done with rs-485 .
The main module is "Waveshare RP2350-PiZero " act as a bridge for rs-485 -> midi and generate all midi-msg for an emulator of modular synth : VCVRack (simulate insertion and deconnexion patch,buttons ,etc..)
I want use PicoMite and a display 5" with hdmi/vga interface to monitor transactions and config between all modules.
For the moment VCVRack run on a little nuc intel j3710(aliexpress 75€) 8Gig Ram/SSD 256G.
All modules use cheap board pico 2350 with rs485 mod.
It's my first project in this area , very noob ..
Any advices are welcome .
Alfamiga
Posted: 06:38pm
01 Feb 2026
Your display options have to be thought out.
HDMI under MMBasic is only available when using a Pico 2 (RP2350) or similar as it uses the HSTX module of that device.
VGA or LCD displays can be used on any devices with enough available pins.
VGA is cheap and easy to set up, requiring only 4 resistors but the number of colours is restricted to 16.
LCD can be slow unless used in parallel mode, in which case it can use a lot of GPIO pins. However, LCD displays are the only ones that can handle a touch screen interface, if that's of any importance to you.
I've never heard of europi modules so I'm not of much help there. :)
Posted: 09:21pm
01 Feb 2026
amiga
  Mixtel90 said  Your display options have to be thought out.
Thanks for the reply ,
rpi23050
https://www.waveshare.com/wiki/RP2350-PiZero
https://files.waveshare.com/wiki/RP2350-PiZero/RP2350-PiZero.pdf
monitor used
https://www.aliexpress.com/p/tesla-landing/index.html?scenario=c_ppc_item_bridge&productId=1005007694800411&_immersiveMode=true&withMainCard=true&src=google-language&aff_platform=true&isdl=y&src=google&albch=shopping&acnt=615-992-9880&isdl=y&slnk=&plac=&mtctp=&albbt=Google_7_shopping&aff_platform=google&aff_short_key=_oFgTQeV&gclsrc=aw.ds&&albagn=888888&&ds_e_adid=&ds_e_matchtype=&ds_e_device=c&ds_e_network=x&ds_e_product_group_id=&ds_e_product_id=nl1005007694800411&ds_e_product_merchant_id=571564673&ds_e_product_country=ZZ&ds_e_product_language=nl&ds_e_product_channel=online&ds_e_product_store_id=&ds_url_v=2&albcp=23014796767&albag=&isSmbAutoCall=false&needSmbHouyi=false&gad_source=1&gad_campaignid=23004631182&gbraid=0AAAAA_TvRHrNFCXSjZLVaJK9xyy67MHv7&gclid=Cj0KCQiAkPzLBhD4ARIsAGfah8ilf2yFyxD83Hq2uc-i817dP8SaN1y2xyF7nxOGVGpdAd7rcWDnYhYaAkI7EALw_wcB
europi
https://github.com/Allen-Synthesis/EuroPi
VcVRack
https://vcvrack.com/
Picomite is it fast enought to ?:
- scan 12 jacks if connected or not
- 8 digital encoder (ky-040)
- 6 switch
- 0.9" i2c display
- 9 leds
This setup it's a mx component , some module require less component .
delay for a user good experience :best : < 10 ms.
Using PIO will help i think
AND of course update screen .
alfamiga (from Belgium , raining day 4°C)
.. sad day today as a fan of retrocomputing and old cars specially rallye car::
Legend Boucles Rally: Spectator fatally struck in Engreux (Houffalize), race cancelled.
Posted: 07:52am
02 Feb 2026
All completely foreign stuff to me. :(
I'm probably almost the least musical person you'll find. :)
Posted: 10:05am
02 Feb 2026
ville56
amiga,
did you already count how many I/Os you need? How many does the PiZero provide? Maybe you need to multiplex some of them with additional hardware. IMHO I think speed will not be the limiting factor in the first place. It depends a lot on your programming skills though.
Posted: 11:51am
02 Feb 2026
Hi Amiga,
Your requirements
- 6 switch
- 0.9" i2c display
- 9 leds
Is this what you intend ?
Requires many IO pins. The 8 digital encoders can be served with 2 PIO's (each PIO has 4 state machines, so you have 8 state machines, each serving one quadrature encoder) but this requires 8x2 = 16 IO pins directly off the RP2350/2040.
Scan 12 jacks, assuming these are jacks with built in switches, requires 12 slow inputs (From PCF8574's or so). PCF8574 are I2C devices.
Then there are 6 switches, the display, and the 9 LED's. Total discrete input/outputs is 27, so you need 4 PCF8574's (8 IO each) with different address setup. And the OLED display. Display preferably on a different I2C bus.
So your whole system would require a PICO, with 16 lines directly to the ky-040's quadrature outputs, and 2x I2C bus. These are 20 lines. I suggest you use a genuine RP pico(2). The zero does not provide sufficient pins on the headers, and you would need to solder to test points.
So much for architecture.
P.S. The ky-040's also support a push button switch. If you also want to support these switches, you need an additional 8 inputs (an additional PCF8574).
P.P.S. If you also want HDMI output you need an RP2350B, because you need additional 8 GPIO pins, directly from the RP2350, to support the monitor. You will have to use the RP2350B chip, look at the RP2350PGA board, that should provide with sufficient IO pins.
EDIT: this is a relatively large system. 35 slow IO, 16 fast IO, 2xI2C busses, HDMI. It will be a nice project to work on. Should keep you busy for half a year or so.
Edited 2026-02-02 22:34 by Volhout
Posted: 04:32pm
02 Feb 2026
amiga
  Volhout said  Hi Amiga,
Your requirements
- 6 switch
- 0.9" i2c display
- 9 leds
Hi ,
thanks for your advice ,
your picture it's one of use case .
signal from jack are fack ... i only detect which jack-in is linked to a jack-out .
i send a MIDI msg to VcVRack :
-- 'Mod/A/Jack/In/1 connected to Mod/B/Jack/Out/3 .
-- 'Mod/A/Pot/2 value '127'
-- 'Mod/A/Switch value '2'
etc...
name of Module is hardcoded in the code simulating the real HMI of this module
English is not my native language (i don't use IA .. for nothing : excepte as junior developper and only Claude Code ..).
Making PCB for each module will cost me a lot (JCLPCB ...
5 pcb for one modules) and i'm not an electronic guru...
i prefer less hardware and more software.
It's why i use 2 types of PCB :
-- master -> waveshare rpi 23050 (hdmi output,sdcard and raspi zero board format)
            HDMI , bridge between slave module rs485 <--> MIDI for VcVRack
-- slave  ->  HMI for VCVRack (emulate a specific synth modul only HMI part , not
             SOUND part ) .
             All use the same PCB ( WeAct RP2350B 16MByte QSPI Flash 48GPIO )
-- face plate -> (like you show in your answer) , will be printed on paper, and glued
                on a plexiglas sheet (not a PCB) .
               I make throught hole for potentiometer,jack,button and led.
               Componnent fixed, and connected with wire and connected to slave
               board .
I can easyly create a new face plate(very low cost) and use the same slave board .
Upload the code on a slave pcb ,the new functionnality is available for VcVRack . Cost of PCB is low .
5 same slave pcb and 5 differents face plate give me 5 different functions .
I can explore the sound creation without ruining myself.
Each action on each component of a module is a msg going throught the rs485 network
and the master module translate this msg finto a MIDI msg for VcVRack.
And accordind your advice , i use analogique potentiometer with multiplex .
i think with 'WeAct RP2350B' and their '48 GPIO' is enought for my need (for the moment..)
now the big challenge for me : is protecting jack from input 10V (coming from analogic module) ..
in my daily use .. never happen ,cause  not owning analogique module.
I think hardware is not very complicated (all digital)...
but software is more challenging ,managing an rs485 network like old days ..
I try to finish my schematic and create the first fake module to test bridging rs-485  <--> MIDI
Have a nice day ,
alfamiga
Posted: 08:32pm
02 Feb 2026
Hi alfamiga,
The WeAct RP2350B 16MByte QSPI Flash 48GPIO is a nice board, very similar to the one I suggested, but half the price. Good choice.
The physical jacks can be purchased with built in switches, isolated from the jack connections. So you can use these to switch 3.3V signals, independent of the levels at the jack contacts.
On this forum there is a thread that shows how to use PIO to decode quadrature encoders.
source code pio
Edited 2026-02-03 06:35 by Volhout
Posted: 08:55pm
02 Feb 2026
amiga
  Volhout said  Hi alfamiga,
source code pio
board very cheap , i use it as piggyback on a very simple pcb with only connector,some smd resistor,capacitor and lot of JST XH 2.54mm Connector . Waiting order from Ahhhli . and pcb from JCLPCB
have a nice day/night ...
alfamiga
Posted: 01:06am
03 Feb 2026
  amiga said
  Volhout said  The WeAct RP2350B 16MByte QSPI Flash 48GPIO is a nice board
alfamiga
The WeAct RP2350B 48GPIO looks like a very good board to build out from. Can you share a picture of your PCB layout (e.g., from JLC's orders page)?
Did you get JLC to make a footprint for the module? They will do that.  Or was one available for, say, EasyCAD? I'll ask them if you haven't--unless you'd like to go ahead and ask them.
Posted: 07:49am
03 Feb 2026
RE:
  Quote  https://www.waveshare.com/wiki/RP2350-PiZero
Note that the HDMI output from this Waveshare module is incompatible with MMBasic.
MMBasic uses the HSTX module of the RP2350 on GP12 to GP19 and, as far as I'm aware, it isn't possible to use the HSTX on other pins, only swap pairs around in this block. The Waveshare module is using GP32 to GP39 for HDMI. Even worse, they've used some of the HSTX pins for other purposes so the HSTX module is unavailable to the user.
You can still get VGA out of it or attach a SPI LCD display, of course. You can also, with care, use the HDMI connector to get access to the GPIO pins that have been used.
Edited 2026-02-03 17:52 by Mixtel90
Posted: 09:04am
03 Feb 2026
amiga
  Mixtel90 said  RE:
thanks for your advice , if mmbasic can't manage HDMI directly for this board , i discard it , the cost is +/- 15€ .
a question for the core developper : is it possible to assign the gpio of module HSTX to adapt it to a specific HDMI layout ?
alfamiga
Posted: 09:12am
03 Feb 2026
The HSTX device on the rp2350 is always on pins gp12-gp19. Within this you can think of 4 pairs 12,13  14,15  16,17  18,19 These pairs can be allocated to any of the 4 DVI channels R, G, B, clock. See the manual page 103 for more details
Posted: 09:14am
03 Feb 2026
amiga
alfamiga
hi ,
i use easycad pro , in schematic the layout is ::
and PCB foot print ...
Hope help you,
alfamiga
Posted: 10:21am
03 Feb 2026
@alfamiga,
If you desire to use PIO to read the ky-040 encoders, you may need to plan what pins to use. The PIO state machines have limitations in the choice of pins to use.
It is wise to connect the quadrature ky-040 A/B output to adjacent GPIO pins (i.e. GPIO1 and GPIO2, not GPIO 1 and GPIO 37)
If you plan to use analog potmeters, the same is valid. Not all pins have ADC's attached.
Posted: 11:01am
03 Feb 2026
The RP2350B has 8 ADC inputs on GP40 to GP47. The WeAct module uses GP0 for PSRAM select so they are all available. The ADC inputs will accept 0 to 3V3 so you can put up to 8 ordinary pots between GND and 3V3 with a wiper onto each ADC input to read them (100nF capacitors between GND and each input are a good idea to reduce wiper noise). They are very easy to connect and use, but you obviously don't get the flexibility of encoders.
Posted: 02:09pm
03 Feb 2026
  amiga said  i use easycad pro , in schematic the [WeAct] layout is ...
Thank you. Super. That's only the outer pins, though, isn't it? Or is the V10 device the one to use for all pins?
A question for Peter (or anyone): what does 16MB PSRam do for us on this WeAct module?
[In EasyEDA Pro, I'm not finding the part. Any clues on how to look?
Edited 2026-02-04 00:46 by lizby
Posted: 02:32pm
03 Feb 2026
ville56
FYI, I possess two of these WeAct modules. Mine have a CPU stepping A4 and 8Mb PSRAM. The PSRAM was retrofitted by me as well as the missing pullup for the CS signal. The problem I have with this modules is, that none of the usual "nuke" programs seems to work on them. So if you set the options to something you cannot recover from without nukeing the flash it is a bit cumbersome. I usually flash some other, much older version of MMBasic over the failing one. That did work so far as it seems to change the options store to something that allows to reflash and go ahead. The behavior is independent of the PSRAM. The new, untouched modules behaved the same.
Posted: 04:56pm
04 Feb 2026
amiga
  ville56 said  FYI, I possess two of these WeAct modules. Mine have a CPU stepping A4 and 8Mb PSRAM. The PSRAM was retrofitted by me as well as the missing pullup for the CS signal. The problem I have with this modules is, that none of the usual "nuke" programs seems to work on them. So if you set the options to something you cannot recover from without nukeing the flash it is a bit cumbersome. I usually flash some other, much older version of MMBasic over the failing one. That did work so far as it seems to change the options store to something that allows to reflash and go ahead. The behavior is independent of the PSRAM. The new, untouched modules behaved the same.
oups .. thanks for the info .
i ordered 1 module for testing , if not work , take the highway to my museum  .
it's the version of the pico 2 (chip RP2350B0A4) not compatible picomite or buggy silicon?
after some optimisation due to the form factor (100mm*100mm) for jclpcb i shrinked my new version to 28 gpio .. in this case i have more choice for the pico 2 boards, but wich chip version with less buggy?
alfamiga
Posted: 05:50pm
04 Feb 2026
ville56
RP2350B0A4 is the latest silicon and should have the least bugs. Don't know why the nukes don't work. Stepping A2 does not show this issue. If the issue is because of the stepping anyway ....
