Posted: 07:51am 16 Mar 2026
Copy link to clipboard |
Volhout Guru
Hi Phil,
Initially measuring pulse width is better than the proposed serial port logic analyzer(*). Baudrates vary from 50 to 3meg. That is 1:80000 ratio. The logic analyzer would need to switch samplerates, for it not to run out of memory. But yes, when you are in the correct range it can be used to do some automatic determining of baudrate, 7/8 bits, 1/2 stopbits, parity, etc...
Volhout (*) but PicoLA is easier to "tune" and trigger. |
