OK, have HDMI output now, but no USB devices are detected at all. USB HUB switch is back in the ENABLE position.
ACTIVE LED starts flickering rapidly after a few minutes - it just gets more and more nuts in terms of the flickering. 2350 chip is cool to the touch, HDMI remains steady.
Perhaps bad SMD around that LED? I will check. This is the first board I have programmed out of the set of five, so I will do the others and make a mental note if any of the other boards do it.
USB console has a "> [?7h" prompt, no matter what I type, HDMI output does NOT show this, it just shows the normal "> " prompt - is that normal for this FW? |
