Just upgraded to LMDE7, and that all went smoothly enough, but now MMEdit won't run. Trying to run it from the terminal, revealed that the libraries that MMEdit needs, were obviously removed during the upgrade. I tried to add them back in the usual way, but LMDE7 reports that one of the packages no longer seems to exist. Any ideas? Is there a specific repository I should be including? It's just the default LMDE7 ones at the moment.
Smoke makes things work. When the smoke gets out, it stops! |
